Local Time 07:12 15 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Electronics: what should I be using as a flux cleaner ?
Posted: 02:10am 24 Feb 2023
Hi Lads,
I use chemtools flux remover spray can Link
Which works well with an old tooth brush.  The result can be tacky but this dries away after an hour or so, but IPA will remove the tackiness if you need it cleaned quicker.
CircuitGizmos
Posted: 09:07pm 25 Feb 2023
CircuitGizmos
Posted: 09:08pm 25 Feb 2023
Posted: 09:25pm 25 Feb 2023
Creative product name.
We have local a product similar to "Aerostart" called "Start Ya Bastard". The lawn mower gets to hear that a lot on cold mornings!
Paul_L
Posted: 03:09am 04 Mar 2023
  thwill said  Hi folks,
What should I be using as a flux remover?
Any suggestions ?
Are you ready for a good laugh?
Tektronic used to clean oscilloscopes in a bath tub!
Google "tektronix oscilloscope cleaning". You tube videos are available!
At Pan Am we found that a good soak for a few hours in reverse osmosis filtered water and a dish washing detergent followed by a thorough rinse and a few hours in an oven at 125° F is an excellent solvent for most flux deposits. Water dissolves the flux but not the board and component coatings.
Sometimes the simplest approach is the best.
Paul in NY
Edited 2023-03-04 13:29 by Paul_L
Posted: 08:16am 04 Mar 2023
I knew about Tektronic. Bathtubs aren't a bad idea even now, but you do need very good drying. Great for cleaning keyboards! I've done it myself, and it's kinder than a dishwasher. I've still to experiment with taking a couple into the shower...
Ah... those were the days...
When a single bit of water seeping into a so-called "sealed" pot didn't short it out. :)
zeitfest
Posted: 12:41am 05 Mar 2023
Approx 20 years ago, in a different place, I experimented with using hot solvent to melt the solder and de-flux PCB's at the same time.
There was a commercial fluorinated fluid used for the purpose, but very expensive.
Neat Glycol (pure  antifreeze) will clean the board well but also swells/dissolves epoxy (aka PCB material) to some extent. Also toxic and passes through skin easily - not good, don't try it.
Glycerol (glycerine) worked well, melted the solder and also cleaned the board, at least prior to having to clean the glycerol off of it. Boiling glycerol starts to decompose to noxious products so I would not use it further.
Sadly hot glycerol is used in "fog juice". My trial formed a misty fog which widely dispersed through the flat making many surfaces sticky until cleaned up !!
So I stopped at that point   .
The rosin/flux sounds like it will dissolve in alcohols and water, I think people originally used methylated spirits (?) Maybe carefully try a metho/glycol mix.
Edited 2023-03-05 16:25 by zeitfest
