Local Time 08:08 15 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Problem with the "TRIANGLE" instruction.
stanleyella
Posted: 06:20pm 23 Feb 2023
Hi paul, I updated to VGA V5.07.07b18 and have the same problem ie it fills the triangle with the triangle colour not the fill colour.
Did filled triangle work in V5.07.07b18 for you or did you mean hoping it would fix the problem?
Bowden_P
Posted: 11:40pm 25 Feb 2023
Hi Stan,
I was running v5.07.06 on a standard Picomite when I noticed this problem, so updated to v5.07.07b18 hoping that would fix it - but no, unfortunately. Will await Peter's analysis and update.
Sorry about the late reply, Paul.
Nothing so constant as change.
nbrok
Posted: 05:19am 26 Feb 2023
  Bowden_P said  Hi Stan,
The triangle problem has been fixed read here : https://www.thebackshed.com/forum/ViewTopic.php?TID=15457&P=9
Edited 2023-02-26 15:23 by nbrok
Greetings,
Nick de pe1goo
Bowden_P
Posted: 05:01pm 26 Feb 2023
Hi nbrok,
Thanks for drawing my attention to Peter's latest beta. Have just run it and all looks good now!
With best regards, Paul.
Bowden_P
Hi nbrok,
p.s. Not sure where the double post came from!
Edited 2023-02-27 03:03 by Bowden_P
stanleyella
Posted: 11:36pm 26 Feb 2023
b24 fixed the triangle problem.
The coloured tiles are now 8x8 so going to try mode 0 sprites, 16x16, moving at 8 pixels and see if they can be more colourful. 4 tiles per sprite.
