Local Time 07:12 15 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : OPTION DISPLAY VALUES
Posted: 07:17pm 07 Mar 2023
I started with the framework by shed user "flip" (who I think has not posted in a long time) here: MMBasic Multi-window Framework
Posted: 07:34pm 07 Mar 2023
  Mark said  thwill:  Thanks for the tip. The code does work. I send an escape sequence to position the cursor to row 999 and column 999. I then send an ESC [6n to get the cursor position (thanks Captain), it then prints "[48;160R" on the screen matches my terminal set up.
The question now is how do I read that "[48;160R" into my program and not have it display on the screen?
I've never done it in MMBasic, only C, but my guess is that if it is possible then you do it using the INPUT$() function to read from file #0.
Mark
Posted: 09:01pm 07 Mar 2023
Print Chr$(27) "[999;999H" Chr$(27) "[6n"
Dim rows% = 0
Dim cols% = 0
Dim ic$
Dim v%
Dim rc% = 0
 ic$ = Inkey$
Loop Until Len(ic$) > 0
 ic$ = Inkey$
 If Len(ic$) = 0 Then
   Exit
 EndIf
 If ic$ = ";" Then
   rc% = 1
 Else
   v% = Asc(ic$) - 48
   If v% < 10 Then
     If rc% Then
       cols% = cols% * 10 + v%
     Else
       rows% = rows% * 10 + v%
     EndIf
   EndIf
 EndIf
Here's a snippet that I found works to get the terminal rows and columns.
Mark
Posted: 09:42pm 07 Mar 2023
It would be interesting to know if that will work generally. It wouldn't surprise me if some terminals didn't work with 999,999.
Posted: 09:45pm 07 Mar 2023
It doesn't look very robust timing-wise!
I'd want to delay a bit to give a chance for the whole response string to come in.
CaptainBoing
Posted: 09:49pm 07 Mar 2023
  Mixtel90 said  It would be interesting to know if that will work generally. It wouldn't surprise me if some terminals didn't work with 999,999.
tried it here with '170, and puTTY with VT100 emulation - following code:
Dim Integer rows,cols
Dim a$,l$
Print Chr$(27)"[999;999H"Chr$(27)"[6n"
'response looks something like ESC[28;1R   - rows;cols and no CRLF
Do While a$<>"R"' grab the response up to the "R"
a$=Inkey$
If a$<>"" Then l$=l$+a$
If Left$(l$,2)=Chr$(27)+"[" Then
rows=Val(mid$(l$,3))
cols=Val(Mid$(l$,Instr(l$,";")+1))
Print rows,cols
End if
works just fine (nice work Mark, good find Thwill) but then it has to if the VT100 emulation is good.
Edited 2023-03-08 08:12 by CaptainBoing
Posted: 10:07pm 07 Mar 2023
My version
There seems to be a large number of chr$(0) sent before the data is returned. This is with TeraTerm (and MMCC) under Windows 11.
How many depends on the response time.
You also have to be prepared for very slow responses now that some end-users are playing with TCPIP.
 PRINT "we are here"
 PRINT CHR$(27)+"[6n";
 DIM locate$ = ""
 DIM n
 DO
   k$ = INKEY$
   INC n
   'print asc(k$);" ";
   IF k$<>CHR$(0) AND k$<>CHR$(27) AND k$ <>"" THEN locate$ = locate$ + k$
 LOOP UNTIL k$ = "R" OR LEN(locate$) > 10 OR n > 1000000
 IF LEFT$(locate$,1) = "[" THEN
   col = VAL(MID$(locate$,2))
   row = VAL(FIELD$(locate$,2,";"))
 ENDIF
 PRINT "Terminal says "+locate$, row,col, n
