Local Time 23:05 14 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMiteVGA: Format of BMP files for LOAD IMAGE
Martin H.
Posted: 07:31am 04 May 2023
yes 32 Sprites of that size uses Memory
As the inner Graphic of the Cards 2 to 10 are (monochrome), you might use much less memory, if you store them in a String and place them via "GUI BITMMAP" in the Cente of your Card.
just my 2 cent ;-)
Edited 2023-05-04 17:31 by Martin H.
'no comment
Posted: 08:20am 04 May 2023
If you don't need all the cards perhaps edit the excess out of the large image. With luck the remainder can be rearranged to fit in 320 x 240.
Posted: 10:24am 04 May 2023
For my chess program I have a file on disk (b:) for every chess piece.
I simply load from disk the required picture when needed. That is fast enough.
If you combine it with the framebuffer, you never see the update happen.
Maybe a: drive is even large enough to hold all the card pictures as separate files.
Hawk
Posted: 10:42am 04 May 2023
  phil99 said  If you don't need all the cards perhaps edit the excess out of the large image. With luck the remainder can be rearranged to fit in 320 x 240.
Yeah, that’s what I ended up doing.  The file was only big, storage wise, because sprites need to be loaded from a 24bit RGB image.  When I upgrade to the new release, hopefully compressed bitmaps will be supported for sprites.
Hawk
Posted: 10:47am 04 May 2023
  Volhout said  For my chess program I have a file on disk (b:) for every chess piece.
This was my backup plan.  I wasn’t sure how long it would take to load each file, but I figured for a card game it would be fast enough.
While I was typing a previous post, I realised that I don’t want to load all the card faces at the same time.  They should all start as a card back and only load the face when it gets turned over.  This method will work for me at this stage, as I am not using a full deck.  If I decide to make another card game after this one that uses a full deck, then I will probably go to the method you suggest.
Hawk.
Hawk
Posted: 10:55am 04 May 2023
  Martin H. said  yes 32 Sprites of that size uses Memory
just my 2 cent ;-)
At least I know that if it runs on my PicoMiteVGA, then it will run on all PicoMiteVGAs.  One of the advantages in a standardised system.  For the moment there seems to be enough memory, and as mentioned earlier, if I load the card faces as I need them, then the loading time will be dispersed throughout the game.
I guess I should check to see if the sprite memory cuts down one the available program storage memory or working memory.  I may find out that I run out part way through my implementation.  Let’s hope I don’t have to cross that bridge.
Hawk.
