Local Time 22:03 14 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : port expander
stanleyella
Posted: 08:21pm 11 May 2023
@lizby - hi. I tried your code and it works. Thanks, it would have taken me ages and then probably give up.
I used a picomite non vga set up for ssd1306 oled pins 21 and 22 so had to comment some of your code.
You've given me the code to use this device. I will test for input.
Useful for others. Nice one sir :)
const mcp23017 = &h20 ' A2, A1, A0, R/W all connected to 0V
Const i2caddr=mcp23017
const IODIRA = &h00 ' Port A IO Direction register DEFAULT = I/P
const IODIRB = &h01 ' Port B IO Direction register DEFAULT = I/P
const IOCON = &h0A ' IO Expander config register - address &h0B accesses  same register
const GPIOA = &h12 ' Port A General purpose register
const GPIOB = &h13 ' Port B General Purpose register
const OLATA = &h14 ' Port A latch register
const OLATB = &h15 ' Port B latch register
const GPUPA = &h0C ' Port C pull-up register
const GPUPB = &h0D ' Port B pull-up register
I2C WRITE MCP23017,0,2,IODIRA,0 ' set direction to output
I2C WRITE MCP23017,0,2,IODIRB,0 ' set direction to output
do
mcp17
loop
sub mcp17
for i = 1 to 6
  I2C Write MCP23017,0,2,OLATA,&b10101010 '
  I2C Write MCP23017,0,2,OLATB,&b01010101 '
  PAUSE     1000
  I2C Write MCP23017,0,2,OLATA,&b01010101 '
  I2C Write MCP23017,0,2,OLATB,&b10101010 '
  PAUSE     1000
Next i
I2C Write MCP23017,0,2,OLATA,0 ' turn all off
I2C Write MCP23017,0,2,OLATB,0 ' turn all off
pause 1000
end sub
