Local Time 11:50 14 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : SetPin(GPnn), FIN query
Posted: 12:18am 28 Aug 2023
  Quote  My immediate solution is to monitor the inputs with other input pins set to PIN (or FIN) to check that there is a signal there or not.
While waiting for Volhout's answer, you don't need the "other" pins. As noted in Volhout's post your program can read the same pins as the PIO - provided you aren't also using them for the PWM test signal, which you could move to other pins while developing your program.
carlschneider
Posted: 01:30am 28 Aug 2023
  Chopperp said  Is there a way of inhibiting the output (or something else) if there is no signal input? My immediate solution is to monitor the inputs with other input pins set to PIN (or FIN) to check that there is a signal there or not.
How about taking the reading and then
PIO Stop 0,0
PIO Start 0,0
I notice that, even although Volhout has dropped the first result as noise and only used 3+latest, I'm also getting first result from PIO being noisy. To overcome this I do a dummy run of the PIO read and discard it.
Hope this helps [Blind leading the blind here for sure :)]
Cheers Carl
Retirement is tough on Hobbies without a day job
carlschneider
Posted: 01:40am 28 Aug 2023
Or maybe use the PIO init to clear everything and then PIO start...
Cheers Carl
Chopperp
Posted: 02:12am 28 Aug 2023
OK, thanks Phil
Re-read the posts to see if I could make more sense of it. I had  missed the bit where Volhout said that the PIO stuff could be assigned to any pin. I thought they were limited to GP0 & GP1 (On the standard 2040).
I assigned the PIO to GP6 & GP8 & initially assigned these two pins to PIN (don't ask) as well.
I was able to measure both the frequencies via the PIO & periods via PIN. Unfortunately, using PIN didn't work too good when the signal was disconnected so I tried FIN on both & that worked OK. The frequencies dropped to 0 when disconnected.
I now do have a loss of input detector.
Thanks again
Brian
EDIT. Bit slow for your relies Carl. Thanks. Had thought of those things. Might wait until Volhout replies
Edited 2023-08-28 12:16 by Chopperp
ChopperP
Posted: 07:33am 28 Aug 2023
The PIO program fills the FIFO with results from edges of the input signal.
When there are no edges, nothing will be put in FIFO. But unless FIFO is actively cleared, the old data remains.
So there are 3 ways to solve this.
1 - let MMBasic monitor the pin as well, and see that there is no signal.
'PIO frequency counter for PICOMITE MMBasic
'PIO program
'this PIO program samples the GPx pin for edges in 2 loops
'that are 2 instructions per loop so the resulting count is in
'ticks that are 2/f seconds. Each GPx period is 2 instructions off.
PIO assemble 0,".program period"
PIO assemble 0,".line 0"
PIO assemble 0,".wrap target"
PIO assemble 0,"mov X,!null"
PIO assemble 0,"posloop:"
PIO assemble 0,"jmp pin negloop"
PIO assemble 0,"jmp x-- posloop"
PIO assemble 0,"negloop:"
PIO assemble 0,"jmp x-- next"
PIO assemble 0,"next:"
PIO assemble 0,"mov isr ,!x"
PIO assemble 0,"push noblock"
PIO assemble 0,".wrap"
PIO assemble 0,".end program list"
'configure pio0
e=Pio(execctrl gp0,Pio(.wrap target),Pio(.wrap)) 'use gp0 for PIN
f=133e6                     '133MHz @ 2 instr per loop
'program pio0 and start
PIO init machine 0,0,f,0,e
PIO start 0,0
'pio fifo register
Dim h%(4)
'use MMBasic to detect input signal
SetPin gp0,intl,INT_0
cnt%=0
'read counted time, average over 4, and convert to frequency
 If cnt%>0 Then
   PIO read 0,0,5,h%()
   period=(h%(1)+h%(2)+h%(3)+h%(4))/4 + 2    'skip h%(0) = rubbish
   frequency=f/(2*period)                    'convert to the Hz
 Else
   frequency=0
 EndIf
 Print frequency;" Hz"
 cnt%=0
 Pause 1000
Loop While Inkey$=""
End
Sub INT_0
 Inc cnt%,1
End Sub
Note that is used an interrupt. Not the FIN function. Pico can only use the FIN  at a limitted set of pins. The interrupt can be used at any pin. So whatever pin you choose. When frequencies are high the interrupt may mis some edged, but that is not important here. We only need to distinguish between 0 and non-zero.
2 - let the PIO indicate it has seen edges, by using a second pin as a status pin.
 MMBasic can use the pin to decide there is new data in FIFO. You can also attach a
 LED to that pin to signal there is input signal.
3 - make the PIO flush the FIFO. This is dangerous, since there is no indication
 whatever is in fifo is correct. And you have to STOP-INIT-START the PIO for it to
 work. But it can be done.
Edited 2023-08-28 17:35 by Volhout
carlschneider
Posted: 09:02am 28 Aug 2023
Hi Volhout
Can you please confirm that you are using OPTION BASE 0.
Cheers Carl
Posted: 09:12am 28 Aug 2023
Hi Carl,
Yes, OPTION BASE 0
Otherwise you would have to skip h%(1) since it contains rubbish...
The array h%(4) contains 5 values. h%(0),h%(1),h%(2),h%(3),h%(4)
Each time you start the PIO, you could be in the middle of a 50Hz cycle, so the count of the first FIFO value h%(0) could be anything.
h%(1), h%(2), h%(3) are valid values stored in the fifo (fifo size is 4 values)
h%(4) is either
- a new value that has been send to FIFO by the PIO during execution of the PIO READ command
- when PIO does not send a new value, h%(4) contains a repeat of h%(3) (the last value read from fifo).
Good question though...
Posted: 09:41am 28 Aug 2023
Carl,
Just in case you are interested in building a universal counter (2 channel frequency, ratio, pulse, period, pause, etc..) here is a PIO core that does it.
This is written for VGA picomite (uses PIO-1) so if you need it to run on PIO 0 you will have some work to do.
It is WIP (work in progress) so the core functions work, but it does not have a GUI (user interface) yet.
freq_counter13.zip
It does not use the build in PIO assembler, since the build in PIO assembler cannot use .WRAP from one state machine in another state machines configuration. But it is commented quite extensively, so you should be able to understand what it does.
If you are not interested, ignore this message.
If you plan to make a GUI, let me know.
Chopperp
Posted: 11:26am 28 Aug 2023
Hi Volhout
  Quote  1 - let MMBasic monitor the pin as well, and see that there is no signal.
Thanks for the first method using the interrupt. Food for thought.
My test set-up was already wired for GP6, GP7, GP8 & GP9 so I don't have any problems using any of them for FIN (at this stage).
Keep up the great work
Brian
ChopperP
carlschneider
Posted: 01:52pm 28 Aug 2023
  matherp said
The web version uses PIO 1 to interface the web chip so only PIO 0 is available
I’m curious as to what else PIO1 is being used for and is the Dallas 1-wire driver in there too?
Cheers Carl
carlschneider
Posted: 02:18pm 28 Aug 2023
Hi Volhout
I am most definitely interested so I won’t ignore the message, however I’m currently sitting in Saskatoon with basically a laptop, a USB cable and a Pico W.
When you say GUI does this include the possibility of a html page served by the Pico W?
I am currently redoing a running ESP32 project back home using the Pico W, namely excess PV diversion to hot water storage, solar water heater controller and air tempering, from functional block memory. Part of the functionality is to review/set parameters through an html page which is what I’m currently eyeing. Ultimately I’m looking to do some remote control by writing modbus tcp registers in an SMA battery inverter triggered from the html page served by the Pico. Could this dev be leveraged into the GUI you seek?
I have read your thread dealing with the PIO and it makes things a little clearer but will definitely require a few rereads before it sinks in. Certainly reminds me of programming in mnemonics then converting to binary and inputting on an 8080 using toggle switches. The whole board and switches mounted in a clear Perspex box, fondly referred to as Snow White and the seven dwarves, for I know not what reason. Sleeping beauty would have been more appropriate given the transparent box :)
Thanks again for all your input and efforts, they are truly appreciated.
Cheers Carl
Posted: 04:05pm 28 Aug 2023
Hi Carl,
The Webmite has the possibility to generate graphics on a shadow screen, and send that over html to a pc.
So yes, it is possible..
But for a frequency counter you do not need graphics, numbers are all.
