Forum Index : Microcontroller and PC projects : MMB4W Controller interface
Thanks everyone, I've seen an SC project that uses an Arduino to simulate a keyboard but that's not for me. C is in my past and will remain there. If someone else wants to run with that I'd be pleased to help if I can. The HT82K629A keyboard chip is more my speed but once you have chosen the keys and hardwired them there is little scope for flexibility. Jim's Serial to HID Keyboard emulator requires something (a 'mite?) to convert the button press to serial and that would mean an extra lag. It does allow some flexibility though and the lag may be negligible. Thanks again. Bill Keep safe. Live long and prosper. |
| Mixtel90 Guru Joined: 05/10/2019 Location: United KingdomPosts: 9123 |
I don't think there's going to be any appreciable lag from a serial-HID keyboard converter if the serial port is reasonable. After all, it basically *is* a keyboard. I might consider one of the designs using a pico to do the keyboard emulation. It's probably faster than the arduino and I prefer Python to C. :) Mick Zilog Inside! nascom.info for Nascom & Gemini |
Importantly, I meant whatever the device is it should have the same buttons etc as you'd use with a Game*mite. That way anyone could develop software on MMB4W if they wished before changing it minimally to work on an actual Game*mite. It would be even better if NO changes were needed but that's not possible due to the lack of GPIO etc on a standard PC. John |
It looks relatively easy to emulate Game*Mite controls using keyboard emulation. No reason why you couldn't have a Game*Mite-type board but with the Pico emulating a USB keyboard rather than driving a display. The PC would be set to use keyboard input, of course, and would "see" the expected keys being pressed. That doesn't mean it *is* easy, of course. :) Mick Zilog Inside! nascom.info for Nascom & Gemini |
There's no existing USB-oriented code to run on the Pico to do that, is there? Whereas using a USB serial or similar device the non-PC (e.g. Pico) end just has to send chars over a serial interface - trivial in MMBasic, for example. John |
Not in MMBasic, no. There is in Circuit Python though. Mick Zilog Inside! nascom.info for Nascom & Gemini |
After you with that... John |
I've made a start by downloading Thonny. :) ============================ Edit: Yes, it can definitely be done in Circuit Python. I'm just playing with the early stages of using my prototype PZ Control to send alphanumeric characters (e.g. W,A,S,D) to a PC. It's probably possible to send any character or string that a PS2 keyboard can send. Not experimented with special characters like the arrow keys yet. EDIT 2: Yes! The Keycode library supports things like RIGHT_ARROW, F1 and TAB so this is looking easier. :) Should be feasible to use a (real 16-bit) SNES controller or a PZ Control natively on a Pico or CMM2 and via a Pico or similar to a USB input on a PC. Programming in Python is strange after MMBasic. Edited 2023-12-13 02:10 by Mixtel90 Mick Zilog Inside! nascom.info for Nascom & Gemini |
Hi Mick, Do you intend to carry on with this? I would like to achieve some useable end result out of it. Please let me know if you are not and I will muddle along in my own way. But it won't involve Circuit Python. Bill Keep safe. Live long and prosper. |
Please go ahead if you wish. :) I used Circuit Python for one particular reason - it has HID support which MMBasic hasn't. You can squirt characters out to the console via USB, but AFAIK MMB4W has no way of seeing them from within a game. I might be wrong. Using HID allows me to simulate key presses on the keyboard so it will work with any game that has keyboard support. I'm not at all fluent in Python so it's not a quick job. In addition I've also been trying to sort out the mechanical aspects of controllers. I now have PZee Control, which needs a little more polish to check the positions of the shoulder buttons, I think. Apart from that it's ready to get some boards made, but that won't be until the new year now. Mick Zilog Inside! nascom.info for Nascom & Gemini |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 11833 |
MMB4W has full support for serial ports so a Pico outputting on the console port would wotk fine |
That makes things *much* easier. Thanks Peter. :) Mick Zilog Inside! nascom.info for Nascom & Gemini |
The trouble as I see it is - what port will Windows decide to allocate to the com port? It may be different sometimes on the same PC let alone different PCs. That means you can't hard code it into a game. This post has led me to believe that, providing the PC will happily accept having two keyboards, then emulating a keyboard or HID (Human Interface Device) is the best plug and play solution. You can't unplug the existing keyboard on a laptop. Possible methods are: The Pico can be programmed to look like an HID using Circuit Python as Mick is looking at. That would be a viable option if it comes to fruition but I don't like Mick's keypad layout (sorry Mick). Tom and Big Mick went to a lot of trouble to get that layout the best it could be and that's what I like. 'Tis a pity that MMBasic on the Pico doesn't support operation as an HID. Some versions of the Arduino can made to do HID emulation also. But not by me. The "Serial to HID Keyboard Emulator" that Jim linked to is an option but needs an additional device to scan the buttons and convert the button selection to ASCII. A PicoMite or a Micromite could do that to keep it in the family. The HT82K629A keyboard chip or similar wired up to a Game*Mite type keypad seems to be the simplest option and is probably what I will look at. Bill Keep safe. Live long and prosper. |
You can have any keypad layout you like providing you stick within the pin capabilities of the device you are using. PZee Control only has a lot of buttons to make it easy to use with Pico PETSCII, which struggles with the Game*Mite keypad. It would be very easy to make a Game*Mite controls compatible version. The Circuit Python code is easily changed, you simply specify which pins are inputs and which sends which character. At the moment I only have it sending single characters. That needs changing to handle multiple button presses - especially a Game*Mite version. If I could arrange the insides of a consistent version of the SNE controller then PZee Control wouldn't exist. :) Mick Zilog Inside! nascom.info for Nascom & Gemini |
I found this today. I looks very simple to use, just connect a USB cable, wire up a few switches and away you go. KB103 - powered by USB it looks almost too easy. ![]() I may have to buy a couple. Bill Keep safe. Live long and prosper. |
That is a good find Bill. It would be ideal for interfacing a few buttons or digital joystick (if both sides of the buttons are available). My option would suit converting a wii or nunchuk using a pico. I originally purchased it to simulate high speed typing to test MMEdit cos my typing is way too slow for stress testing. I wouldn't be too concerned about serial ports and finding them. Even MMB4W could scan each com port in turn skipping over errors and looking for a suitable response. You wold only have to do it when the remembered port doesn't respond. Jim VK7JH MMedit |
Handy device for using up that stock of 1.8mm pitch card edge connectors. :) You may need the "with socket" version to stand a chance. Nice little module. It actually does a lot more than we need though as it's a full x-y matrix keyboard scanner. You can hard wire particular keys but you can't redefine a key for a different game very easily. That's relatively easy in software. ======================================== EDIT: Game*Mite version of PZee Control is on the other thread now. :) Edited 2023-12-18 18:39 by Mixtel90 Mick Zilog Inside! nascom.info for Nascom & Gemini |
| darthvader Senior Member Joined: 31/01/2020 Location: FrancePosts: 101 |
@Jim , If you dont have it done , here is my Wii joystick drivers for STM32 from 2014 wii_cc.zip And how to use it : #include "stm32f4xx.h" #include "wii_cc.h" char StrNumber[40]; WII_CC_DATA wii_data; void Wii_Classic_Controller_Test(void); int main(void) { // Init the Wii Classic Controller wiiCCInit(); Wii_Classic_Controller_Test(); } void Wii_Classic_Controller_Test(void) { while(wii_data.buttons.a != 1) { wiiCCRead(&wii_data); sprintf(StrNumber, "left analog x : %d", wii_data.left_analog_x); sprintf(StrNumber, "left analog y : %d", wii_data.left_analog_y); sprintf(StrNumber, "right analog x : %d", wii_data.right_analog_x); sprintf(StrNumber, "right analog y : %d", wii_data.right_analog_y); sprintf(StrNumber, "buttons a : %d", wii_data.buttons.a); sprintf(StrNumber, "buttons b : %d", wii_data.buttons.b); sprintf(StrNumber, "buttons right : %d", wii_data.buttons.right); sprintf(StrNumber, "buttons left : %d", wii_data.buttons.left); sprintf(StrNumber, "buttons up : %d", wii_data.buttons.up); sprintf(StrNumber, "buttons down : %d", wii_data.buttons.down); sprintf(StrNumber, "rtrigger push : %d", wii_data.buttons.rtrigger_push); sprintf(StrNumber, "ltrigger push : %d", wii_data.buttons.ltrigger_push); sprintf(StrNumber, "buttons home : %d", wii_data.buttons.home); sprintf(StrNumber, "buttons minus : %d", wii_data.buttons.minus); sprintf(StrNumber, "buttons plus : %d", wii_data.buttons.plus); sprintf(StrNumber, "buttons x : %d", wii_data.buttons.x); sprintf(StrNumber, "buttons y : %d", wii_data.buttons.y); sprintf(StrNumber, "buttons zr : %d", wii_data.buttons.zr); sprintf(StrNumber, "buttons zl : %d", wii_data.buttons.zl); delay_ms(25); } } It worked very well. You can check the result here at 2m47 , "sorry for the crap video" wii test youtube Cheers. Edited 2023-12-19 09:05 by darthvader Theory is when we know everything but nothing work ... Practice is when everything work but no one know why ;) |
That is true but do you really want to modify the controller to suit each game? There are not many controllers that you can reconfigure as far as I know. Much easier to just modify the game and only have to do it once. Yes, One could make something like this Which supposedly works on a PC but I can't find any useful information. Maybe Xbox? Bill Keep safe. Live long and prosper. |
That should be usable provided you can get to all the switch terminals and cut out the existing electronics. Hopefully there is room to squeeze the other board in as well. Jim VK7JH MMedit |
