Forum Index : Microcontroller and PC projects : hid2cdc - USB keyboard and mouse for picomite VGA
| lizby Guru Joined: 17/05/2016 Location: United StatesPosts: 3878 |
A function returns a value and requires something to put that value in, for instance mik: do a$=_inkeych$() if a$<>"" then print asc(a$);" "; endif loop PicoMite, Armmite F4, SensorKits, MMBasic Hardware, Games, etc. on FOTS |
Hi Lizby, All, I replaced my snippet at the start with yours and I now get this error RUN [12] If Loc(#1)>0 Then Error : File number is not open what file # is this referring to? Mick . Mick's uMite Stuff can be found >>> HERE (Kindly hosted by Dontronics) <<< |
| phil99 Guru Joined: 11/02/2018 Location: AustraliaPosts: 3377 |
The console is #0. This seems to work. Below is the output of the F-keys from TeraTerm, 3 characters each F1 to F9 and 4 characters each F10 to F12. > LIST Do b$ = _inkeych$() ' I thought this would run the function If b$<>"" Then Print Asc(b$) ' Print Asc(a$) ' ignore as superflous at this stage Loop Function _inkeyCh$() Local ky$ If Loc(#0)>0 Then ky$=Input$(1,#0) ' get a character Else ky$=Inkey$ EndIf If Asc(ky$)=27 Then ' escape sequence Pause 20 ' await additional characters ky$=Input$(1,#0): ky$=Input$(1,#0): ky$=UCase$(ky$) If ky$="A" Then: ky$=Chr$(128) ' up arrow ElseIf ky$="B" Then: ky$=Chr$(129) ' down arrow ElseIf ky$="D" Then: ky$=Chr$(130) ' left arrow ElseIf ky$="E" Then: ky$=Chr$(131) ' right arrow ElseIf ky$="1" Then: ky$=Chr$(134) ' home ElseIf ky$="4" Then: ky$=Chr$(135) ' end ElseIf ky$="5" Then: ky$=Chr$(136) ' pgup ElseIf ky$="6" Then: ky$=Chr$(137) ' pgdn ' Function keys are ??? EndIf EndIf _inkeyCh$=ky$ End Function > RUN 134 49 126 134 50 126 134 51 126 134 52 126 134 53 126 134 55 126 134 56 126 152 50 48 126 50 49 126 155 50 52 126 |
Hi Phil, That `almost works', thank you. I am currently only testing directly on the console, (NOT with HID2CDC connected). This is what I am getting with just `slow, careful' presses of just the F1 key. Note the key MOSTLY returns 134 49 126 but every now and then it returns a solitary 145 134 49 126 134 49 126 134 49 126 145 134 49 126 134 49 126 145 134 49 126 145 134 49 126 I will try on the HID2CDC anyway to see what occurs Regards, Mick . Mick's uMite Stuff can be found >>> HERE (Kindly hosted by Dontronics) <<< |
Hi All, I have tested the above code on the HID2CDC and every key that doesn't work returns a solitary 0 The Ctrl key sends nothing and with CTRL-c it returns 99 which is the same as c by itself. I have also noticed some instability in getting the HID2CDC up and running. Initially, yesterday it wouldn't work at first but then replugging keyboard and the HID2CDC would bring it up and running, it then appeared very stable for my testing. Just now I went through the same hoops and fences to get it running and in the process lost the file in Memory. I think it may be the length of leads (about 1m and rather thin) that are powering the HUB and kb. (Power originates from the PicoVGA). If it persists I will just make some short cables. Regards, Mick Mick's uMite Stuff can be found >>> HERE (Kindly hosted by Dontronics) <<< |
hi mick, give this a try, based upon lizby and phil99's code: Do I=Timer Do If Loc(#0)=0 Then a$="" Else a$=Input$(1, #0) Loop Until a$<>"" If Timer-I>100 Then Print If a$=Chr$(13) Then Print "<cr>"; ElseIf a$=Chr$(10) Then Print "<lf>"; ElseIf a$=Chr$(27) Then Print "<esc>"; ElseIf (a$<Chr$(32)) Or (a$>Chr$(126)) Then Print "<";Hex$(Asc(a$),2);">"; Else Print a$; EndIf Loop it looks like on the picomite Inkey$ pre-processes some (but not all) VT key sequences into a single character with the top bit set, while Input$(1, #0) allows access to the raw data. cheers, rob :-) |
Rob, All, This will be the last test I can do this year, I have to prep the BBQ for tonight's NY celebrations. OK, I went through `A LOT' of instability ie. getting the setup to work and recognise the kb. I am sure that is to do with cable lengths and power distribution, something I will address in the coming week when time permits. Anyway I finally got there, this is what the HID2CDC reports ESC <esc> F1-F12 <00> numlk, Prnt scn, Scrl lk, Pause/break all report <00> backspace <08> home <00> ~ (displays a degrees symbol) tab <09> Pg up/down, end, home, 4 arrows all <00> Caps, Shift, Alt and Ctrl no response at all | (ruler) <00> Windows key no response I hope that helps with the project. Regards, Mick EDIT*** When I have the HID2CDC setup working I can plug an extra keyboard in and both work, could be great for 2 player games. Mik Edited 2023-12-31 15:04 by bigmik Mick's uMite Stuff can be found >>> HERE (Kindly hosted by Dontronics) <<< |
Sorry, Mick. In that code, I was looking for input either from a serial port or from the console. When posting, I forgot to note that in your case, the serial port would not have been opened--I should have omitted that part of the code. Looks like you have made progress and it appears that the Function keys and other important keys do not return anything (as passed through your HID device--unlike straight from a keyboard or as passed through TeraTerm to the MMBasic console). PicoMite, Armmite F4, SensorKits, MMBasic Hardware, Games, etc. on FOTS |
Grogster![]() Admin Group Joined: 31/12/2012 Location: New ZealandPosts: 10037 |
What a fascinating thread, now that I have just got to the end of it. A quite brilliant idea to use a PICO module as a kind of USB interpreter with the output always via a USB serial adaptor via a hub all controlled by the PICO module - very clever of the fella over a Github and thanks to Rob for pursuing this idea with him. I can see some potential out of this, especially after seeing all of bigmik's testing showing some very promising results. Watching this thread with interest. Happy new year. Smoke makes things work. When the smoke gets out, it stops! |
No problems Lizby, It is all a learning exercise for everyone at the moment. I have had a thought about the instability I have been experiencing and I think I know what it is. I have a barrel Jack for 5v input on my PicoMuP (configured as a PicoMiteVGA) that I use to power everything. I have been generally powering the lot by flicking the power switch on the wall where the plugpack is plugged into the wall socket. I have just realised that, I think, when I do get it working I plugged the (already powered) plugpack into the barrel Jack. Possibly the plugpack doesnt power up very cleanly. I will investigate that because when it does work it works very well. @Rob, anyone else. What should the power up procedure ideally be? Ie HID2CDC first then PicoVGA or vice versa? Regards, Mick . Mick's uMite Stuff can be found >>> HERE (Kindly hosted by Dontronics) <<< |
Hi All, I have hit on the instability issue I was having. It IS indeed the powering of the plugpack via the mains switch that causes it to occur, by directly plugging the `hot' plug into the Barrel Jack on my PicoMuP, I have successfully powered the setup 9 times out of 10, given the length of leads I figure that this is proof positive. The powering via the mains power point was to try to power everything up in a `safer' manner, it appears that I actually introduced the instability by doing so. @Rob, Incidentally, Rob, on my small keyboard (without keypad) two LEDs light up (caps lock and what I think is scroll lock, it has a down pointing arrow sort of like an LED symbol) on the larger keyboard no LEDs light up. Even though caps lock illuminates it is in lower case mode. Now to work off my hangover from last year. Kind Regards, Mick (the Big one) . Edited 2024-01-01 11:34 by bigmik Mick's uMite Stuff can be found >>> HERE (Kindly hosted by Dontronics) <<< |
i would suggest feeding 5-volts directly into VBUS (pin 40, ground return to pin 38) of the HID2CDC pico. this will then flow directly into your USB hub and from there power the attached devices (picomite VGA and keyboard). do you have a reset button fitted to your picomite VGA? if things don't power up correctly, you could try tapping that; my guess is that the USB hub and keyboard will have fairly robust reset circuitry built in, while the two picos less so. as i recall, USB keyboard LEDs are usually controlled by the host - one way i use to see if a desktop PC is still alive is tapping the caps lock key and see if the corresponding LED changes state. so i wouldn't worry about the LEDs, they will be something for NoOne to fix later. at the moment, i've asked (on github) that the next thing to be got going is the CONTROL key, which will then see us being able to run the picomite's editor. cheers, rob :-) Edited 2024-01-01 12:26 by robert.rozee |
| Mixtel90 Guru Joined: 05/10/2019 Location: United KingdomPosts: 9123 |
One of the test points under a Pico (TP5) goes to the anode of the heartbeat LED. You can use this to get an extra output. It has a 470R resistor to GP25. You could try this. On the "first to start" Pico: Connect TP25 to the 3V3EN pin on the "to be delayed" Pico. Disable heartbeat. Start the program with a short PAUSE then set GP25 high. do another PAUSE to allow the other to boot. In theory 3V3EN should be low enough to prevent the Pico from powering up. You may need a 470R resistor from 3V3EN to GND, although it's worth trying without first. When the first Pico has booted it will enable the delayed one by putting about 1V8 on its 3V3EN input. The switcher spec specifies a min. of 1.2V for logic high and a max. of 0.4V for logic low. You can't depend on the Picos to boot at the same speed even if powered simultaneously. They are running from different clocks. The best you can manage is a controlled start. Edited 2024-01-01 19:01 by Mixtel90 Mick Zilog Inside! nascom.info for Nascom & Gemini |
further posting from NoOne on github: https://github.com/No0ne/hid2cdc/issues/1 he suggests mass storage devices (USB flash drives) with xmodem transfer should be possible. mouse support is a litle more complex, though i have an idea myself how it may be achieved in a VT-aware manner. cheers, rob :-) |
Hi Rob, All, This is sounding more and more exciting, ‘possibly’ having access to storage devices as well is icing on the cake. I am glad to read that ‘no0ne’ expected that the function keys etc would not work, it eliminates anything that I have introduced. I have noticed, albeit when the setup wasn’t working, that if I unplug then replug the HID2CDC device I would see the picoVGA either lockup or see the report on the screen Invalid Address - Restarting but even after said restart it would not work with the HID2CDC. Now that I know how to get the setup to work on power up every time, I will try unplugging the HID2CDC and see what happens. Regards, Mick . Edited 2024-01-02 09:08 by bigmik Mick's uMite Stuff can be found >>> HERE (Kindly hosted by Dontronics) <<< |
hi Mick, that is pretty much as i would expect. think of it in the context of a picomite plugged into the USB port of a regular PC - the picomite is just a peripheral and is seeing the host PC connection disappear. but with a PC that would only happen when the picomite is unplugged from the PC, at which point the pico powers down. i doubt very much if tinyUSB has ever been tested under the conditions of the USB connection being lost but power remaining on. normally a pico is either tethered to a PC with USB connection and deriving power from said PC, or there is no USB connection and the pico is powered continuously from a battery or plugpack. note: i have on the odd occasion seen USB printers lose their USB connection without power being interrupted, at which the printer sometimes locks up completely and requires power cycling to recover. simply put, many USB devices are not specifically designed to keep working through a lost USB connection situation. if you feed 5-volts directly into VBUS (pin 40, ground return to pin 38) of the HID2CDC pico, and only into there, then the above problem should not happen. the power will flow directly into your USB hub and from there power the picomite VGA (and keyboard). if the HID2CDC is unplugged, everything else loses power. cheers, rob :-) Edited 2024-01-02 11:25 by robert.rozee |
Please be careful about putting supplies onto the VBUS terminal. It's so easy to think "I just need to change..." and connect the USB port to your PC - possibly damaging the USB chip in it. All you gain over powering from VSYS is the little drop across a Schottky diode, which is completely irrelevant if you are using the switching supply. VBUS is great for powering 5V devices *from* though (if you are getting a supply from USB). Mick Zilog Inside! nascom.info for Nascom & Gemini |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 11834 |
Has the issue with function keys, arrow keys, control keys, and anything else that generate escape sequences been solved? It seems to me that until the basics are working this is of limited use and extra functionality (usb drives) should be deferred. Bluntly, what is there at the moment is just basic TinyUSB functionality. The hard bit is getting things like multiple languages and all the edge cases working. Check the source of any of the MMBasic variants for how much of keyboard handling is dealing with these (nearly all of it). Aus and NZ may choose to us a US keyboard but much of the rest of the world and many of out biggest contributors don't so this stuff is important. |
new version of HID2CDC, with arrow keys now working: https://github.com/No0ne/hid2cdc/raw/main/hid2cdc.uf2 mick - with the new version are you seeing anything else working, ie, control keys, home/end, pgup/pgdn, insert/delete? cheers, rob :-) |
further update, looks like ALL required keys are now working: https://github.com/No0ne/hid2cdc/raw/main/hid2cdc.uf2 only key repeat not yet working. yes, it seems so. peter: are you able to test this with a UK keyboard? cheers, rob :-) Edited 2024-01-05 09:59 by robert.rozee |
