Local Time 20:54 13 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite/VGA/Web V5.08.00: Release candidates
JanVolk
Posted: 12:03am 18 Jan 2024
Thank you. From now on, use files with wildcards, which is much easier, and use that example in a program.
Jan
Posted: 02:47am 18 Jan 2024
Webmite
WEB TCP CLIENT REQUEST is not always saving the last packet.
The following code
WEB OPEN TCP CLIENT "api.openweathermap.org",80
WEB TCP CLIENT REQUEST b$,m%(),10000
PAUSE 200
WEB CLOSE TCP CLIENT
PRINT "Length is ";LLEN(m%())
LONGSTRING PRINT  m%()
will return a short string if the "pause 200" delay is not used before closing the stream.
It doesn't seem to matter if the reply is 2 or 20 packets long. It doesn't matter if I am retrieving from my local network or across the WWW. The same 200mS delay is needed.
Replies that fit into one packet don't need the delay before closing.
Posted: 11:11am 18 Jan 2024
Please could you try the attached - untested
PicoMiteWeb.zip
Posted: 01:02pm 18 Jan 2024
Forgot to mention some time ago. The VGA version can now optionally use different pins
OPTION VGA PINS HSYNCpin, BLUEpin
The command changes the pins used for VGA display output allowing more flexibility in PCB design or wiring. “HSYNCpin” defines the start of a pair of contiguous GP numbered pins that are connected to HSYNC and VSYNC
“BLUEpin” defines the start of four contiguous GP numbered pins that are connected to BLUE, GREEN_LSB, GREEN_MSB, and RED.
Posted: 02:41pm 18 Jan 2024
Oh brilliant!!!!! Thanks. :)
I'll have to try that on a RP2040-Zero.
Posted: 07:42pm 18 Jan 2024
  matherp said  Jim
PicoMiteWeb.zip
Yes!
That seems to have fixed it. 2k and 20k replies are returned in full without any need for a delay.
Thanks.
