Forum Index : Microcontroller and PC projects : asciimation
| javavi Guru Joined: 01/10/2023 Location: UkrainePosts: 603 |
Hi All! Added a function to the player [pause/play] adding the code to the beginning of the main player loop If Inkey$=" " Then Do FRAMEBUFFER write n Pause 500 Text MM.HRes/2,MM.VRes-70,"[ PAUSE ]",cm,,2 Pause 500 Text MM.HRes/2,MM.VRes-70," ",cm,,2 FRAMEBUFFER write f Loop While Inkey$="" EndIf Are there other films? |
| Volhout Guru Joined: 05/03/2018 Location: NetherlandsPosts: 6101 |
If you want a universal player, we have to adapt the compression format. Look at MPEG compression, they have I frames(initial),P frames(partial) and B frames( we don’t need those). The I frames are I.e. one every 30 frames, and contain the whole screen. All 13 lines of 68 characters. The P frames are the difference from previous frame. The current SW1-c.txt has only one I frame, the first. And from there only P frames. This means you can’t go fast forward without processing all the P frames in between. For this to work well, we need the compressor to leave a full I frame every 30 frames. Fast forward or backward would search for the next I frame and start playing from there. Volhout The B frames are bi-directional, and help when showing video durin rewind without costing too much bandwidth, Edited 2024-02-09 04:46 by Volhout PicomiteVGA PETSCII ROBOTS |
