Local Time 15:53 13 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : csub and array - help please
Posted: 04:30pm 07 Mar 2024
  matherp said
  Quote  OK, so the whitespace around the * is I'm pretty sure always irrelevant, for a pointer I usually put it with the type so I would have written:
I'm never sure on this one so I always put it with the variable
int64_t* a,b;
int64_t *a,b;
Yes, if you insist on declaring multiple variables like that then to reduce (you cannot eliminate) confusion you do want to put the * with the identifier and not with the type. Also you should be shot .
Peter's way may be more sensible, but I largely work with higher-level languages where the type is one atomic keyword/identifier, not a mess of them.
Edited 2024-03-08 02:49 by thwill
homa
Posted: 05:39pm 07 Mar 2024
I'd like to say: yes, C is special!
Very confusing for a beginner like me.
Especially because wrong spelling doesn't necessarily lead to an error, just a different result.
And you can get the same result with different expressions.
Anyway, I'm working my way through it now. My ambition has been kindled.
Matthias
twofingers
Posted: 06:04pm 07 Mar 2024
I think it doesn't get any easier because the information about CSub is so spread out here in the forum and some of it is several years old. The - excellent! - MMBasic manual is of very little help regarding CSubs.
The lone and ...
disco4now
Posted: 10:24pm 07 Mar 2024
I have started a page on FotS (Fruit of the Shed) to link to posts around CSubs. Eventually I hope it can be expanded as a complete reference for CSubs and Cfunctions(still maintaining links to the original posts).
I have added a link to this page.
Despite having cut and pasted Geoff and Peter's C code for a couple of years now I am still not fluent in pointer syntax and sometimes have a bit of trial and error. The explanations here are the clearest I have seen.
Fruit of the Shed - CSubs
Gerry
F4 H7FotSF4xGT
twofingers
Posted: 10:56am 08 Mar 2024
  disco4now said  I have started a page on FotS (Fruit of the Shed) to link to posts around CSubs. ...
Very good idea! Thank you! Impressive!
Maybe a reference to it could be in the manual?
Best regards
Michael
The lone and ...
homa
Posted: 06:06pm 10 Mar 2024
Hello dear gurus,
what is the fundamental problem with this error?
Matthias
C:\homa\csub\ray>arm-none-eabi-ld -nostartfiles -T arm-gcc-link.ld -o main.elf main.o
arm-none-eabi-ld: main.o: in function `degToRad.4898':
main.c:(.text.degToRad.4898+0xe): undefined reference to `__aeabi_i2d'
arm-none-eabi-ld: main.c:(.text.degToRad.4898+0x16): undefined reference to `__aeabi_dmul'
arm-none-eabi-ld: main.c:(.text.degToRad.4898+0x26): undefined reference to `__aeabi_ddiv'
arm-none-eabi-ld: main.c:(.text.degToRad.4898+0x32): undefined reference to `__aeabi_d2f'
arm-none-eabi-ld: main.o: in function `ray':
main.c:(.text.ray+0x36): undefined reference to `__aeabi_l2f'
arm-none-eabi-ld: main.c:(.text.ray+0x48): undefined reference to `__aeabi_l2f'
arm-none-eabi-ld: main.c:(.text.ray+0x5a): undefined reference to `__aeabi_l2f'
arm-none-eabi-ld: main.c:(.text.ray+0x6c): undefined reference to `__aeabi_f2iz'
arm-none-eabi-ld: main.c:(.text.ray+0x86): undefined reference to `__aeabi_f2d'
arm-none-eabi-ld: main.c:(.text.ray+0x92): undefined reference to `tan'
arm-none-eabi-ld: main.c:(.text.ray+0x9e): undefined reference to `__aeabi_d2f'
arm-none-eabi-ld: main.c:(.text.ray+0xa8): undefined reference to `__aeabi_f2iz'
arm-none-eabi-ld: main.c:(.text.ray+0xc0): undefined reference to `__aeabi_f2d'
arm-none-eabi-ld: main.c:(.text.ray+0xcc): undefined reference to `cos'
arm-none-eabi-ld: main.c:(.text.ray+0xd4): undefined reference to `__aeabi_dcmpgt'
arm-none-eabi-ld: main.c:(.text.ray+0xde): undefined reference to `__aeabi_f2iz'
arm-none-eabi-ld: main.c:(.text.ray+0xec): undefined reference to `__aeabi_i2f'
arm-none-eabi-ld: main.c:(.text.ray+0xf8): undefined reference to `__aeabi_fsub'
arm-none-eabi-ld: main.c:(.text.ray+0x102): undefined reference to `__aeabi_fmul'
arm-none-eabi-ld: main.c:(.text.ray+0x10c): undefined reference to `__aeabi_fadd'
arm-none-eabi-ld: main.c:(.text.ray+0x126): undefined reference to `__aeabi_fmul'
arm-none-eabi-ld: main.c:(.text.ray+0x132): undefined reference to `__aeabi_f2iz'
arm-none-eabi-ld: main.c:(.text.ray+0x14e): undefined reference to `__aeabi_f2d'
arm-none-eabi-ld: main.c:(.text.ray+0x15a): undefined reference to `cos'
arm-none-eabi-ld: main.c:(.text.ray+0x162): undefined reference to `__aeabi_dcmplt'
arm-none-eabi-ld: main.c:(.text.ray+0x16c): undefined reference to `__aeabi_f2iz'
arm-none-eabi-ld: main.c:(.text.ray+0x178): undefined reference to `__aeabi_i2d'
arm-none-eabi-ld: main.c:(.text.ray+0x180): undefined reference to `__aeabi_dsub'
arm-none-eabi-ld: main.c:(.text.ray+0x18c): undefined reference to `__aeabi_d2f'
arm-none-eabi-ld: main.c:(.text.ray+0x198): undefined reference to `__aeabi_fsub'
arm-none-eabi-ld: main.c:(.text.ray+0x1a2): undefined reference to `__aeabi_fmul'
arm-none-eabi-ld: main.c:(.text.ray+0x1ac): undefined reference to `__aeabi_fadd'
arm-none-eabi-ld: main.c:(.text.ray+0x1c4): undefined reference to `__aeabi_fmul'
arm-none-eabi-ld: main.c:(.text.ray+0x1de): undefined reference to `__aeabi_f2iz'
arm-none-eabi-ld: main.c:(.text.ray+0x1ea): undefined reference to `__aeabi_f2iz'
arm-none-eabi-ld: main.c:(.text.ray+0x230): undefined reference to `__aeabi_f2iz'
arm-none-eabi-ld: main.c:(.text.ray+0x24a): undefined reference to `__aeabi_f2d'
arm-none-eabi-ld: main.c:(.text.ray+0x256): undefined reference to `cos'
arm-none-eabi-ld: main.c:(.text.ray+0x262): undefined reference to `__aeabi_fsub'
arm-none-eabi-ld: main.c:(.text.ray+0x26a): undefined reference to `__aeabi_f2d'
arm-none-eabi-ld: main.c:(.text.ray+0x276): undefined reference to `__aeabi_dmul'
arm-none-eabi-ld: main.c:(.text.ray+0x284): undefined reference to `__aeabi_f2iz'
arm-none-eabi-ld: main.c:(.text.ray+0x29c): undefined reference to `__aeabi_f2d'
arm-none-eabi-ld: main.c:(.text.ray+0x2a8): undefined reference to `sin'
arm-none-eabi-ld: main.c:(.text.ray+0x2b4): undefined reference to `__aeabi_fsub'
arm-none-eabi-ld: main.c:(.text.ray+0x2bc): undefined reference to `__aeabi_f2d'
arm-none-eabi-ld: main.c:(.text.ray+0x2c8): undefined reference to `__aeabi_dmul'
arm-none-eabi-ld: main.c:(.text.ray+0x2d4): undefined reference to `__aeabi_dsub'
arm-none-eabi-ld: main.c:(.text.ray+0x2e0): undefined reference to `__aeabi_d2f'
arm-none-eabi-ld: main.c:(.text.ray+0x2ee): undefined reference to `__aeabi_fadd'
arm-none-eabi-ld: main.c:(.text.ray+0x2fa): undefined reference to `__aeabi_fadd'
arm-none-eabi-ld: main.c:(.text.ray+0x326): undefined reference to `__aeabi_fdiv'
arm-none-eabi-ld: main.c:(.text.ray+0x330): undefined reference to `__aeabi_f2iz'
arm-none-eabi-ld: main.c:(.text.ray+0x34c): undefined reference to `__aeabi_f2d'
arm-none-eabi-ld: main.c:(.text.ray+0x358): undefined reference to `sin'
arm-none-eabi-ld: main.c:(.text.ray+0x360): undefined reference to `__aeabi_dcmpgt'
arm-none-eabi-ld: main.c:(.text.ray+0x36a): undefined reference to `__aeabi_f2iz'
arm-none-eabi-ld: main.c:(.text.ray+0x376): undefined reference to `__aeabi_i2d'
arm-none-eabi-ld: main.c:(.text.ray+0x37e): undefined reference to `__aeabi_dsub'
arm-none-eabi-ld: main.c:(.text.ray+0x38a): undefined reference to `__aeabi_d2f'
arm-none-eabi-ld: main.c:(.text.ray+0x396): undefined reference to `__aeabi_fsub'
arm-none-eabi-ld: main.c:(.text.ray+0x3a0): undefined reference to `__aeabi_fmul'
arm-none-eabi-ld: main.c:(.text.ray+0x3aa): undefined reference to `__aeabi_fadd'
arm-none-eabi-ld: main.c:(.text.ray+0x3c2): undefined reference to `__aeabi_fmul'
arm-none-eabi-ld: main.c:(.text.ray+0x3ea): undefined reference to `__aeabi_f2iz'
arm-none-eabi-ld: main.c:(.text.ray+0x406): undefined reference to `__aeabi_f2d'
arm-none-eabi-ld: main.c:(.text.ray+0x412): undefined reference to `sin'
arm-none-eabi-ld: main.c:(.text.ray+0x41a): undefined reference to `__aeabi_dcmplt'
arm-none-eabi-ld: main.c:(.text.ray+0x424): undefined reference to `__aeabi_f2iz'
arm-none-eabi-ld: main.c:(.text.ray+0x432): undefined reference to `__aeabi_i2f'
arm-none-eabi-ld: main.c:(.text.ray+0x43e): undefined reference to `__aeabi_fsub'
arm-none-eabi-ld: main.c:(.text.ray+0x448): undefined reference to `__aeabi_fmul'
arm-none-eabi-ld: main.c:(.text.ray+0x452): undefined reference to `__aeabi_fadd'
arm-none-eabi-ld: main.c:(.text.ray+0x46c): undefined reference to `__aeabi_fmul'
arm-none-eabi-ld: main.c:(.text.ray+0x486): undefined reference to `__aeabi_f2iz'
arm-none-eabi-ld: main.c:(.text.ray+0x492): undefined reference to `__aeabi_f2iz'
arm-none-eabi-ld: main.c:(.text.ray+0x4d8): undefined reference to `__aeabi_f2iz'
arm-none-eabi-ld: main.c:(.text.ray+0x4f2): undefined reference to `__aeabi_f2d'
arm-none-eabi-ld: main.c:(.text.ray+0x4fe): undefined reference to `cos'
arm-none-eabi-ld: main.c:(.text.ray+0x50a): undefined reference to `__aeabi_fsub'
arm-none-eabi-ld: main.c:(.text.ray+0x512): undefined reference to `__aeabi_f2d'
arm-none-eabi-ld: main.c:(.text.ray+0x51e): undefined reference to `__aeabi_dmul'
arm-none-eabi-ld: main.c:(.text.ray+0x52c): undefined reference to `__aeabi_f2iz'
arm-none-eabi-ld: main.c:(.text.ray+0x544): undefined reference to `__aeabi_f2d'
arm-none-eabi-ld: main.c:(.text.ray+0x550): undefined reference to `sin'
arm-none-eabi-ld: main.c:(.text.ray+0x55c): undefined reference to `__aeabi_fsub'
arm-none-eabi-ld: main.c:(.text.ray+0x564): undefined reference to `__aeabi_f2d'
arm-none-eabi-ld: main.c:(.text.ray+0x570): undefined reference to `__aeabi_dmul'
arm-none-eabi-ld: main.c:(.text.ray+0x57c): undefined reference to `__aeabi_dsub'
arm-none-eabi-ld: main.c:(.text.ray+0x588): undefined reference to `__aeabi_d2f'
arm-none-eabi-ld: main.c:(.text.ray+0x596): undefined reference to `__aeabi_fadd'
arm-none-eabi-ld: main.c:(.text.ray+0x5a2): undefined reference to `__aeabi_fadd'
arm-none-eabi-ld: main.c:(.text.ray+0x5bc): undefined reference to `__aeabi_fcmplt'
arm-none-eabi-ld: main.c:(.text.ray+0x5d2): undefined reference to `__aeabi_f2lz'
arm-none-eabi-ld: main.c:(.text.ray+0x5e6): undefined reference to `__aeabi_f2lz'
Posted: 07:15pm 10 Mar 2024
Have you been through the original cfunction tutorials?
http://www.thebackshed.com/forum/forum_posts.asp?TID=7965&PN=1&TPN=1
http://www.thebackshed.com/forum/forum_posts.asp?TID=7973
http://www.thebackshed.com/forum/forum_posts.asp?TID=8038
http://www.thebackshed.com/forum/forum_posts.asp?TID=8389&KW=by+example
If not you should. Although there is some PIC specific stuff a lot of it is still relevant.
The answer to your question is that you are trying to do maths and this calls SDK routines which you can't link. You need to use the maths calls in the header file
e.g.
x=y*z;
becomes
x=FMul(y,z);
EDNEDN
Posted: 09:27pm 10 Mar 2024
  homa said  I'd like to say: yes, C is special!
Matthias
Most people starting to do complicated things in C benefit from understanding the parsing of complex C declarations.   If you read these articles, everything starts to be easy:
http://unixwiz.net/techtips/reading-cdecl.html
https://users.ece.utexas.edu/~ryerraballi/CPrimer/CDeclPrimer.html
http://www.ericgiguere.com/articles/reading-c-declarations.html
Once you can parse and understand the more complicated declarations most of the confusion disappears.
Edited 2024-03-11 07:43 by EDNEDN
