Local Time 18:47 12 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMiteHDMI: Color Cycle Animation
stanleyella
Posted: 01:50am 18 Oct 2024
cool phil. hdmi mode 5 shows 4 blue, 8 green, 8 red.. but only shows 6 colours but nice demo
another different problem you could help me with maybe please.
SPRITE LOADARRAY [#]n, w,h, array%()
Creates the sprite 'n' with width 'w' and height 'h' by reading w*h RGB888
values from 'array%()'. The RGB888 values must be stored in order of
columns across and then rows down starting at the top left.
This allows the programmer to create simple sprites in a program without
needing to load them from disk or read them from the display. The
firmware will generate an error if 'array%()' is not big enough to hold the
number of values required
how do I get data to array? ie make array instead of data and this crude way?
ie create array with shortcut colour values
'copy data to screen
 for spht=0 to 15
   for spw=0 to 15
     read sp1
     pixel spw+10,spht+10,sp1
   next spw
 next spht
'read screen to sprite
sprite READ 1,10,10,16,16
sprite1:
data wh,bl,bl,bl,bl,bk,bk,bk,bk,bk,bk,bl,bl,bl,bl,wh
data bk,bl,re,re,re,bl,bl,bk,bk,bl,bl,re,re,re,bl,bk
data bk,bk,bk,bl,re,wh,bl,bk,bk,bl,wh,re,bl,bk,bk,bk
data bk,bk,bk,bk,bl,wh,bl,bk,bk,bl,wh,bl,bk,bk,bk,bk
data bk,bk,bk,bk,bk,bl,bl,bk,bk,bl,bl,bk,bk,bk,bk,bk
data bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk
data bk,bk,bk,bk,ye,ye,ye,bk,bk,ye,ye,ye,bk,bk,bk,bk
data bk,bk,bk,ye,bk,bk,bk,bk,bk,bk,bk,bk,ye,bk,bk,bk
data bk,ye,ye,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,ye,ye,bk
data bk,ye,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,ye,bk
data ye,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bl,ye
data ye,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,ye
data bk,bk,ye,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,ye,bk,bk
should have added
'colour shortcuts
const WH =RGB(255,  255,  255) 'WHITE
const YE =RGB(255,  255,    0) 'YELLOW
const LI =RGB(255,  128,  255) 'LILAC
const BR =RGB(255,  128,    0) 'BROWN
const FU =RGB(255,  64,   255) 'FUCHSIA
const RU =RGB(255,  64,     0) 'RUST
const MA =RGB(255,  0,    255) 'MAGENTA
const RE =RGB(255,  0,      0) 'RED
const CY =RGB(0,    255,  255) 'CYAN
const GR =RGB(0,    255,    0) 'GREEN
const CE =RGB(0,    128,  255) 'CERULEAN
const MI =RGB(0,    128,    0) 'MIDGREEN
const CO =RGB(0,    64,   255) 'COBALT
const MY =RGB(0,    64,     0) 'MYRTLE
const BL =RGB(0,    0,    255) 'BLUE
const Bk =RGB(0,    0,      0) 'BLACK
const Gy =RGB(128,  128,  128) 'GREY
const Lg =RGB(210,  210,  210) 'LITEGREY
const Og =RGB(255,  165,    0) 'ORANGE
const PK =RGB(255,  160,  171) 'PINK
const Gd =RGB(255,  215,    0) 'GOLD
const SA =RGB(250,  128,  114) 'SALMON
const BE =RGB(245,  245,  220) 'BEIGE
Edited 2024-10-18 12:27 by stanleyella
Posted: 02:26am 18 Oct 2024
  Quote  hdmi mode 5 shows 4 blue, 8 green, 8 red.. but only shows 6 colours
Mode 5 is 8 bits - RGB332, 3 bits = 8 shades. Black counts as a colour and the two brightest shades may be hard to tell apart.
  Peter said  HDMI mode 5 can show any 256 out of 32768 at the same time
256=8 bits
wh=RGB(white)
bl=RGB(blue)
re=RGB(red)
ye=RGB(yellow)
bk=RGB(black)
my=RGB(myrtle)
Option Base 0
Dim array%(255) '256 = 16 hor x 16 vert - 1 (-1 as array is Base 0)
For sp=0 To 255
 Read  array%(sp)
Next sp
Sprite LOADARRAY #1, 16,16, array%()
Sprite SHOW #1, 36,36,0
sprite1:
Data wh,bl,bl,bl,bl,bk,bk,bk,bk,bk,bk,bl,bl,bl,bl,wh
Data bk,bl,re,re,re,bl,bl,bk,bk,bl,bl,re,re,re,bl,bk
Data bk,bk,bk,bl,re,wh,bl,bk,bk,bl,wh,re,bl,bk,bk,bk
Data bk,bk,bk,bk,bl,wh,bl,bk,bk,bl,wh,bl,bk,bk,bk,bk
Data bk,bk,bk,bk,bk,bl,bl,bk,bk,bl,bl,bk,bk,bk,bk,bk
Data bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk
Data bk,bk,bk,bk,ye,ye,ye,bk,bk,ye,ye,ye,bk,bk,bk,bk
Data bk,bk,bk,ye,bk,bk,bk,bk,bk,bk,bk,bk,ye,bk,bk,bk
Data bk,ye,ye,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,ye,ye,bk
Data bk,ye,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,ye,bk
Data ye,bk,bk,bk,bk,my,bk,bk,bk,my,bk,bk,bk,bk,bl,ye
Data ye,bk,bk,bk,bk,bk,bk,my,bk,bk,bk,bk,bk,bk,bk,ye
Data bk,ye,bk,bk,bk,my,bk,bk,bk,my,bk,bk,bk,bk,ye,bk
Data bk,bk,ye,bk,bk,bk,my,my,my,bk,bk,bk,bk,ye,bk,bk
Edited 2024-10-18 15:01 by phil99
stanleyella
Posted: 04:47pm 18 Oct 2024
thanks phil, I was looking for
dim sprite1(wh,bl,bl,bl,bl,bk,bk,bk,bk,bk,bk,bl,bl,bl,bl,wh,
bk,bl,re,re,re,bl,bl,bk,bk,bl,bl,re,re,re,bl,bk,
bk,bk,bk,bl,re,wh,bl,bk,bk,bl,wh,re,bl,bk,bk,bk,
bk,bk,bk,bk,bl,wh,bl,bk,bk,bl,wh,bl,bk,bk,bk,bk,
bk,bk,bk,bk,bk,bl,bl,bk,bk,bl,bl,bk,bk,bk,bk,bk,
bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,
bk,bk,bk,bk,ye,ye,ye,bk,bk,ye,ye,ye,bk,bk,bk,bk,
bk,bk,bk,ye,bk,bk,bk,bk,bk,bk,bk,bk,ye,bk,bk,bk,
bk,ye,ye,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,ye,ye,bk,
bk,ye,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,ye,bk,
ye,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bl,ye,
ye,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,ye,
bk,bk,ye,bk,bk,bk,bk,bk,bk,bk,bk,bk,bk,ye,bk,bk)
but get Error : Expected closing bracket
using mmedit
regards, stan
stanleyella
Posted: 07:50pm 18 Oct 2024
I stuck with my first option
cls
restore sprite1:sht=15:swid=15
udg1 'draws sprite1 on screen at 10,10
sprite READ 1,10,10,16,16 'reads sprite1 from screen to blit buffer1
restore sprite2
udg1 'draws sprite2 on screen at 10,10
sprite read 2,10,10,16,16 'reads sprite2 from screen to blit buffer2
restore cannon:sht=9:swid=11
sprite READ 3,10,10,12,10 'reads sprite1 from screen to blit buffer1
restore missile:sht=15:swid=0
sprite READ 4,10,10,1,16 'reads sprite1 from screen to blit buffer1
sub udg1 'draws data for blit to copy
 for spht=0 to sht
   for spw=0 to swid
     read sp1
   next spw
 next spht
end sub
using
'restore sprite1
'For temp=0 To 255
'Read  array%(temp)
'Next temp
'Sprite LOADARRAY #1, 16,16, array%()
'restore sprite2
'For temp=0 To 255
'Read  array%(temp)
'Next temp
'Sprite LOADARRAY #2, 16,16, array%()
'restore cannon
'For temp=0 To 119
'Read  array%(temp)
'Next temp
'Sprite LOADARRAY #3, 12,10, array%()
'restore missile
'For temp=0 To 15
'Read  array%(temp)
'Next temp
'Sprite LOADARRAY #4, 1,16, array%()
can't use the array%() for other size sprites , each needs it's own array.
Posted: 08:28pm 18 Oct 2024
  Quote  can't use the array%() for other size sprites , each needs it's own array.
The arrays don't need to be permanent, erase them after the sprite is created.
Dim array1%(xy1)
 'make sprite 1
Erase array1%()
Dim array2%(xy2)
 'make sprite 2
Erase array2%()
Dim array3%(xy3)
 'make sprite 3
Erase array3%()
Edited 2024-10-19 06:29 by phil99
stanleyella
Posted: 08:52pm 18 Oct 2024
I was wondering if release or un dim was possible.thanks. big manual,gets bigger.
Posted: 09:19pm 18 Oct 2024
Another option, make the array big enough for the biggest sprite so you can re-use it.
Only erase it after all have been made.
Tested ok.
wh=RGB(white)
bl=RGB(blue)
re=RGB(red)
ye=RGB(yellow)
bk=RGB(black)
my=RGB(myrtle)
MODE 2
Option base 0
Dim array%(999)
For sp=0 To (16*16-1) '16 hor x 16 vert - 1 (-1 as array is Base 0)
 Read  array%(sp)
Next sp
For sp=0 To (16*5-1) '16 hor x 5 vert - 1 (-1 as array is Base 0)
 Read  array%(sp)
Next sp
Sprite LOADARRAY #2, 16,5, array%()
Erase array%()
Sprite SHOW #1, 36,36,1
Sprite SHOW #2, 96,36,1
sprite1:
Sprite2:
Edited 2024-10-19 07:29 by phil99
stanleyella
Posted: 11:34pm 18 Oct 2024
this seems best and apart from data statements, leaves no waste, like using the screen but faster. live n learn
didn't know Dim array%(16*16+16*16+12*10+1*16) works
Dim array%(255) '16x16 sprite
restore sprite1
For temp=0 To 255:Read  array%(temp):Next temp
Sprite LOADARRAY 1, 16,16, array%()
restore sprite2 '16x16 sprite
Sprite LOADARRAY 2, 16,16, array%()
erase array%()
Dim array%(119) '12x10 sprite
restore cannon
For temp=0 To 119:Read  array%(temp):Next temp
erase array%()
Dim array%(15) '1x16 sprite
restore missile
For temp=0 To 15:Read  array%(temp):Next temp
erase array%()
Edited 2024-10-19 09:56 by stanleyella
Posted: 11:58pm 18 Oct 2024
As the biggest sprite is 16 x 16 you only need to erase array%() after the last one.
See my previous post, it doesn't matter if the array is bigger than the sprites.
Dim array%(16*16) is enough as for each sprite the For...Next starts from 0 again, overwriting the previous array elements.
  Quote  big manual,gets bigger
Erase has been in the manual from the beginning.
Edit
If you want to save some memory the data for symmetrical sprites can be cut in half and a mirror image of the first half put in the second half of the array.
For vertical symmetry this is done line by line.
Eg.
wh=RGB(white)
bl=RGB(blue)
re=RGB(red)
ye=RGB(yellow)
bk=RGB(black)
my=RGB(myrtle)
MODE 2
Option base 0
Dim array%(16*16-1) 'Size of largest Sprite
For sp=0 To (16*16-1) '-1 as array is Base 0
 Read  array%(sp) 'fill first half of each line
 n%=(15+sp)-(sp Mod 8)*2 'fill second half of each line in reverse order
 array%(n%)=array%(sp)
 If sp Mod 8 = 7 Then Inc sp,8
Next sp
For sp=0 To (15*5-1) 'Symmetrical sprite with an odd number of pixels
 n%=(14+sp)-(sp Mod 8)*2 'fill second half of each line in reverse order
  Inc sp,8
  array%(n%+8)=BK 'set the last pixel of each line to background colour
 EndIf
Next
Erase array%()
Sprite SHOW #2, 66,36,1
sprite1:
sp2:
Data bk,bk,ye,bk,bk,my,bk,bk
Data bk,ye,bk,bk,bk,bk,bk,my
Edited 2024-10-19 15:07 by phil99
stanleyella
Posted: 06:01pm 19 Oct 2024
yes,works. I got error before with smaller than 16x16 sprites.
Dim array%(16*16) '16x16 sprite
restore sprite1
restore sprite2
restore cannon
restore missile
erase array%()
SPRITE READ [#]b, x, y, w, h and SPRITE WRITE [#]b, x, y
[,mode] to draw half symmetrical sprite, reverse it and join on screen and read whole sprite. same for flipping any sprite, using screen can seem easier
stanleyella
Posted: 10:00pm 19 Oct 2024
half symmetrical sprite using screen
mode 2
OPTION BASE 0        ' 0 based arrays
option DEFAULT INTEGER
cls
restore sprite1:sht=15:swid=7
sprite READ 1,10,10,8,16 'reads sprite1 from screen to blit buffer1
SPRITE WRITE 1,18,10,&B001 'inverts sprite horizontal and draws next to first half
SPRITE CLOSE 1 'clears sprite 1 for reuse
sprite READ 1,10,10,16,16 'reads whole sprite1 from screen to blit buffer1
sprite WRITE 1,10,50 'draws whole sprite
end
 for spht=0 to sht
   for spw=0 to swid
     read sp1
   next spw
 next spht
end sub
'half symmetrical sprite data
sprite1:
data wh,bl,bl,bl,bl,bk,bk,bk ',bk,bk,bk,bl,bl,bl,bl,wh
data bk,bl,re,re,re,bl,bl,bk ',bk,bl,bl,re,re,re,bl,bk
data bk,bk,bk,bl,re,wh,bl,bk ',bk,bl,wh,re,bl,bk,bk,bk
data bk,bk,bk,bk,bl,wh,bl,bk ',bk,bl,wh,bl,bk,bk,bk,bk
data bk,bk,bk,bk,bk,bl,bl,bk ',bk,bl,bl,bk,bk,bk,bk,bk
data bk,bk,bk,bk,bk,bk,bk,bk ',bk,bk,bk,bk,bk,bk,bk,bk
data bk,bk,bk,bk,ye,ye,ye,bk ',bk,ye,ye,ye,bk,bk,bk,bk
data bk,bk,bk,ye,bk,bk,bk,bk ',bk,bk,bk,bk,ye,bk,bk,bk
data bk,ye,ye,bk,bk,bk,bk,bk ',bk,bk,bk,bk,bk,ye,ye,bk
data bk,ye,bk,bk,bk,bk,bk,bk ',bk,bk,bk,bk,bk,bk,ye,bk
data ye,bk,bk,bk,bk,bk,bk,bk ',bk,bk,bk,bk,bk,bk,bl,ye
data ye,bk,bk,bk,bk,bk,bk,bk ',bk,bk,bk,bk,bk,bk,bk,ye
data bk,bk,ye,bk,bk,bk,bk,bk ',bk,bk,bk,bk,bk,ye,bk,bk
