Forum Index : Microcontroller and PC projects : Front panel designer
| toml_12953 Guru Joined: 13/02/2015 Location: United StatesPosts: 720 |
I use the software to design a panel, then I print it and use that as a guide for drilling holes in my own sheet aluminum (aluminium?) After I drill, I paint the panel and apply dry letter transfers. It looks very professional. The software makes it easy to align and correctly space rows of holes. Front Panel.pdf Edited 2024-10-27 20:40 by toml_12953 |
| Mixtel90 Guru Joined: 05/10/2019 Location: United KingdomPosts: 9118 |
Ah, I use SL6 for PCB panels or nanoCAD 5.0 (the free version) for other mechanical stuff. That's because it's similar to an early AutoCAD version that I used for many years. Mick Zilog Inside! nascom.info for Nascom & Gemini |
| Volhout Guru Joined: 05/03/2018 Location: NetherlandsPosts: 6101 |
All, Used this software to design a new front panel and rear panel for a 40 year old power supply. Works very nice. I laser printed the test printout, and made it more robust using a plastic foil. Glued on the power supply. Nice...(*) Volhout (8) I even thought for a moment to simply order them online from Schaffner, at a price of 40 eur per (for 3mm thick milled anodized alu, with countersunk screw holes), that was the most professional solution. I still may, but for now I am fine. Edited 2024-12-16 18:21 by Volhout PicomiteVGA PETSCII ROBOTS |
