Local Time 13:17 12 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : COUNT and max frequency for PicoMite?
Posted: 12:36pm 23 Nov 2024
If Jim's method is fast enough for your needs it will give you 10^12 counts. That is a lot!
While awaiting Peter's update I think this will give 62 or 63 bits starting from 0.
setpin gp0,pwm : pwm 0, 1000000,50
setpin gp6,cin
> pin(gp6)= -(2^31) :pause 10000 : C=pin(gp6)+(2^31) :? C
At 1MHz it will take a much longer than the 10 seconds in the above example (years I imagine) to reach 2^62.
Posted: 07:26pm 23 Nov 2024
53375996 days or 146236 years approximately
While Peter has now given us 64 bit (signed I assume) counts, there are plenty of external devices that are 16 or 32 bit or any strange number of bits that will need converting to MMBasic integers.
ElectroPI
Posted: 10:27am 24 Nov 2024
Having it the same as a (signed?) integer would be great and saves confusion. Thanks Peter for including this in your next update.
all the best
Posted: 10:40am 24 Nov 2024
NB:
The fast timer functionality is RP2350 only. This is because only the RP2350 has a second PWM interrupt and this is needed for the 16-bit PWM register rollover. The first interrupt is dedicated to audio.
RC17 has the 64-bit counter variables
PhenixRising
Posted: 02:34pm 25 Nov 2024
  matherp said  In the latest release you can use pin GP1 for very fast frequency measurement
SETPIN GP1,FFIN ' set GP1 for fast frequency input
'Connect gp1 to gp3
SETPIN GP3,PWM
PWM 1,val(mm.info(cpuspeed))/4,,50 'this is the fastest PWM can run
? pin(gp1)
Only just made it back to my desk to test this
Many thanks Pete, works beautifully
