Local Time 05:41 11 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Reset/empty string ARRAY$ ?
Posted: 12:23pm 11 Mar 2025
  matherp said
  Quote  On reflection I suspect it is one byte containing the current length and *7* characters.
Doesn't work like that. The vartbl entry still contains a pointer so nothing else needs changing. For short strings it points to the second element of the dimension array which is repurposed to contain the string
Ah right, thanks Peter, that would work too. Isn't the dimension array (minus one element) on the RP2040 large enough to hold 10 bytes then ? ... but the code is copied from the CMM2 which had a lower value of MAXDIM, that explains it.
