Local Time 04:11 11 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2: 3D Printed case for CMM2
Martin H.
Posted: 10:27am 07 Apr 2025
  PeteCotton said
You are very welcome. I'm very interested in how you get on with it and any suggestions you have for improvements.
First part is about to finish now
now i have to find out how to align the back of the housing to minimize the need for supports
'no comment
PeteCotton
Posted: 04:42pm 07 Apr 2025
Excellent. Thanks for the update.
For what it's worth, I aligned the back of the housing this way for printing.
There are groves on the left/right edges of the bezel that you are printing. If you have supports on while printing, you may have to scrape them out of the groves. The large part of the monitor case has corresponding rails on the left/right edges that the groves should slot into. Mine were too tight, so I expanded the gap a little bit on the new model (the one you are printing). Hopefully I haven't made it too loose fitting.
My LCD panel has two screw holes at the top, so I made corresponding holes in the monitor case. I hung the panel with just a couple of bolts. They don't actually need to have nuts on the back, as the bezel should hold the panel firmly in place.
I would recommend adding the 90 degree HDMI connector to the LCD before putting the panel in the case, as it's a bit tight.
I'm very interested in your experience with this and what you would change/fix.
PeteCotton
Posted: 04:45pm 07 Apr 2025
  Plasmamac said  Can someone please add a bay/support for a real 3,5 Floppy Disk ?
I can definitely do that, but not until the end of the week probably. (I'll be away from my computer for the next few days). The case might have to be expanded a little bit but not by much. What computer are you putting in there, and I'll make sure it fits with the floppy bay.
EDIT: I just read the next story on the forum - which was you talking about floppy drive with CMM2 - so I guess it's a CMM2  . No problem.
Edited 2025-04-08 02:47 by PeteCotton
Plasmamac
Posted: 06:22pm 07 Apr 2025
Thx Pete , don’t hurry
Plasma
Martin H.
Posted: 02:08pm 08 Apr 2025
Hi Plasma
the thing is that a standard 3.5 inch drive would already take up half the space:
So you would either have to make the housing higher so that the floppy can be mounted above the board,
or you place a floppy case  between the computer and the screen
Martin
'no comment
Plasmamac
Posted: 02:38am 09 Apr 2025
Hahaha, I have not realized how small it is 🫣
Plasma
PeteCotton
Posted: 08:50pm 09 Apr 2025
Hi Plasma
Martin
I was intending on making it taller (that way the top of the case and monitor would not need to be remodeled). However, to take a mash-up of your ideas - I quite like the idea of a separate floppy "layer" between the case and monitor. Sort of like the later HP9000 Unix stations did - where you just stacked boxes until you had a giant tower of power.
Martin H.
Posted: 07:02am 10 Apr 2025
Hey Pete,
taller is not the problem (except for longer printing times). The housing is already larger in length and width than a “normal” 3D printer (22x22cm) could produce.
I'm currently having problems with the back of the monitor because of the curvature. Printing time 7.5 hours each time. After 3 failed attempts (at the moment i am also struggling with printer problems from time to time, I'm considering whether I should split it into back and side parts or simply make it more square.
cheers
Martin
'no comment
PeteCotton
Posted: 02:05pm 10 Apr 2025
  Martin H. said  ....I'm currently having problems with the back of the monitor because of the curvature. Printing time 7.5 hours each time. After 3 failed attempts (at the moment i am also struggling with printer problems from time to time, I'm considering whether I should split it into back and side parts or simply make it more square.
I vote for more square. Even with support struts, I wasn't particularly happy with the banding on the curve. It looked quite rough. Are you comfortable making the edit yourself - if not, I can do it this weekend?
