Forum Index : Microcontroller and PC projects : Picomite USBHDMI
What is the power source. Can you try another USB-C cable. Bad power supply can be an issue. F4 H7FotSF4xGT |
| Gadgetguy Senior Member Joined: 26/04/2025 Location: FrancePosts: 104 |
Thank you for suggesting - but I tried several power supplies and different cables. They make no difference unfortunately. (For example I tried powered by my laptop got same results as when powered by a brand new raspberry pi 5 USB power supply) |
| Bleep Guru Joined: 09/01/2022 Location: United KingdomPosts: 852 |
Try OPTION KEYBOARD US,0,0,200,150 The repeat rate you are setting is extreemly fast. |
| Mixtel90 Guru Joined: 05/10/2019 Location: United KingdomPosts: 9114 |
Keyboards that contain other devices like USB hubs or track pads may not work. The PicoMite USB system is not a full version like Windows. Also, there are some RGB keyboards that don't work (I have one that appears as multiple USB devices so that it can have n-key rollover, which you can't have on USB2, never mind USB1 like the Pico, as it's too slow). To confuse things even more, some powered hubs don't work if you use them with a Pico. Mick Zilog Inside! nascom.info for Nascom & Gemini |
Thank you. Tried it. Not really different unfortunately. |
To confuse things even more, some powered hubs don't work if you use them with a Pico. Thank you. Yes, I am aware. But it seems that some people are using the exact same keyboard (Logitech K400) and it works for them. Hence my confusion. Of course I can use the keyboard that works - I was just hoping to use the Logitech one. |
| dddns Guru Joined: 20/09/2024 Location: GermanyPosts: 910 |
Connects Keyboard and Mouse. Which version are you using as firmware? Edited 2025-05-17 02:38 by dddns |
Connects Keyboard and Mouse. Which version are you using as firmware? I am on RC23. Please note that I have the K400r model, which is very similar to the K400+ but not 100% the same. Thank you so much for any ideas! Edited 2025-05-17 05:07 by Gadgetguy |
Connects Keyboard and Mouse. Which version are you using as firmware? Logitech K400+ Works on RC23 HDMIUSB for me. Only setup is OPTION RESET HDMIUSB Note: This is the first version of the reference design, no PSRAM option and no I2S The VID/PID and recognised devices on the Logitech K400+ ----------------------------------- ? MM.INFO(USB VID 1) --> 1133 ? MM.INFO(USB VID 2) --> 1133 ? MM.INFO(USB PID 1) --> 50475 ? MM.INFO(USB PID 2) --> 50475 ? MM.INFO(USB 1) --> 1 (Keyboard) ? MM.INFO(USB 2) --> 2 (Mouse) Edited 2025-05-17 12:19 by disco4now F4 H7FotSF4xGT |
A K400R is not a K400 or a K400+. Some keys are programmable. There is obviously different firmware in the keyboard and it is definitely a possibility that the K400R won't work even though the others do. We don't know these things until someone tries them, unfortunately. When your sample of K400R users is one it's very difficult to figure out what's happening! Mick Zilog Inside! nascom.info for Nascom & Gemini |
Bear in mind most things you have connected that keyboard to have hardware USB and/or large USB stacks (software). The Pico has neither i.e. no USB hardware and a limited software emulation of USB fitted into the available space. John |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 11827 |
Gadgetguy: does your board have R54 and R55 fitted? If it does please remove them (completely benign) and see if it makes a difference |
Thank you all for the super helpful comments. I found another no name chinese wireless keyboard that works. So I have now 3 that don't and 2 that do. I will just live with this (not really comfortable desoldering parts) and acknowledge that my logitech is not compatible. We shall see if it works with the Maximite. I will update you here. Thank you again! |
Update : got the k400+ version. Well, that does not work either. I wonder how it works for others? |
Do you get the same results for VID/PID ? The VID/PID and recognised devices on the Logitech K400+ ----------------------------------- ? MM.INFO(USB VID 1) --> 1133 ? MM.INFO(USB VID 2) --> 1133 ? MM.INFO(USB PID 1) --> 50475 ? MM.INFO(USB PID 2) --> 50475 ? MM.INFO(USB 1) --> 1 (Keyboard) ? MM.INFO(USB 2) --> 2 (Mouse) F4 H7FotSF4xGT |
The VID/PID and recognised devices on the Logitech K400+ ----------------------------------- ? MM.INFO(USB VID 1) --> 1133 ? MM.INFO(USB VID 2) --> 1133 ? MM.INFO(USB PID 1) --> 50475 ? MM.INFO(USB PID 2) --> 50475 ? MM.INFO(USB 1) --> 1 (Keyboard) ? MM.INFO(USB 2) --> 2 (Mouse) I am getting zero for all. |
You might consider removing these. You should be able to remove mechanically if you dont want to put a soldering iron in there. See this link for the history on this. Post about R54 and R55 and here Edited 2025-05-25 17:04 by disco4now F4 H7FotSF4xGT |
I will try. What I wonder is why some wireless dongles work and only some others dont. If this is an issue with the resistors then no dongle would work - or is that logic not true? |
| phil99 Guru Joined: 11/02/2018 Location: AustraliaPosts: 3375 |
My understanding is there was a batch of USB hub chips that had an error in their output current protection circuit. Removing those resistors disables that. The board has other over current protection so the USB chip's current protection isn't required. |
That's correct. The USB chips that were supplied to JLCPCB's suppliers had the wrong internal configuration, apparently. Mick Zilog Inside! nascom.info for Nascom & Gemini |
