Local Time 22:24 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Bug with Maximimite 6.00.00.b2?
Gadgetguy
Posted: 08:32am 24 Jun 2025
I have also checked. No impact of noLED. I totally lose keyboard when using v6 - while v5 works 100% without any problem.
I guess I should stay with v5 for now while hoping that v6 may be fixed one day.
Edited 2025-06-24 22:23 by Gadgetguy
Posted: 04:53pm 28 Jun 2025
Give this a go and let me know if any better
CMM2V1.5.zip
ManiB
Posted: 09:58pm 28 Jun 2025
  matherp said  Give this a go and let me know if any better
CMM2V1.5.zip
Hi Peter,
whatever you did - now it works again without any problems. My keyboard is recognized immediately and the mouse does what it should.
Many thanks from Germany,
Manfred
PS: just assembled and shipped ten of the CMM2 G2 V2:
Edited 2025-06-29 08:57 by ManiB
PeteCotton
Posted: 08:43pm 29 Jun 2025
Sorry Peter, but although the keyboard is working again, I'm getting weird artifacts when I try to access the graphics memory.
PeteCotton
Posted: 08:51pm 29 Jun 2025
This is the minimal code needed to check for artifacts
'MODE 1,16 ' 800x600
PAGE WRITE 1
LOAD JPG "img\crt3.jpg"
PAGE DISPLAY 1
DO:LOOP
Where crt.jpg is this file:
crt3.zip
Posted: 09:13am 30 Jun 2025
Do you see any issues other than with LOAD JPG?
PeteCotton
Posted: 03:58pm 30 Jun 2025
  matherp said  Do you see any issues other than with LOAD JPG?
I can't see any other issues apart from JPG loading. I ran through a few programs and they all seem to run fine (although I don't have speakers attached to test sound).
From my perspective, I can probably work around not using LOAD JPEG. The only reason I was using it (if memory serves) is that it loads much quicker than a BMP (but I might be wrong on that).
Posted: 04:04pm 30 Jun 2025
Try this. I've replaced the entire jpg module with the one from the Pico. S/W rather than H/W but more flexible - can load jpg bigger than the screen
CMM2V1.5.zip
Edited 2025-07-01 02:05 by matherp
PeteCotton
Posted: 06:25pm 30 Jun 2025
  matherp said  Try this. I've replaced the entire jpg module with the one from the Pico. S/W rather than H/W but more flexible - can load jpg bigger than the screen
Initial testing seems to confirm that yes - it is fixed. I will try and do more extensive testing tomorrow. I did quite a few reboots, and can confirm that the keyboard also always works every time.
Thank you once again Peter   As always - outstanding work!
