Local Time 08:43 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Graphic commands in XOR...
hhtg1968
Posted: 11:14am 22 Dec 2025
The screen errors "occur" exclusively on page 1 when I resize a preliminary box or disc etc. with live and continously drawing. Occasionally, they are then transferred to page 0 or even page 2, at least partially.
hhtg1968
Posted: 01:09pm 22 Dec 2025
While watching my own videos, I noticed that the mouse cursor occasionally flashes, which I hadn't intended or meant to happen. It might be related to the unplanned temporary saving of the portion of the screen in the mouse cursor's area where the errors occur.
But especially when watching the films, one gets the impression that the faulty areas are too large to have been caused by the mouse pointer.
I can also upload the source code, but I don't want to bother people too much here.
hhtg1968
Posted: 01:21pm 22 Dec 2025
  Volhout said  On PicoMite (VGA/HDMI) in mode 2
Attached will allow you to test your mouse in a program.
Assuming you have used OPTION MOUSE to enable the mouse. It reads the coordinates from the mouse, and creates the cursor (rectangle) in MMBasic.
Use the mouse to navigate to a lemming, then click left mouse to change the walking direction of that lemming. It is not flawless (yet) but helps you to test the mouse.
lem_core2.zip
In the next year i will order picomites at jlcp. so i can not test it this time...
I have a picomite on breadboard but the cables make problems.
hhtg1968
Posted: 01:49pm 22 Dec 2025
When you document a program error for others, you often discover the cause yourself. I'm uploading another video here. You can see, or rather, I can see, that the errors occur where I move the mouse to modify the disk. With large objects that have filled areas, drawing the object takes so long that a mouse action interferes (as i suppose). I don't yet understand why this only happens in the lower third of the screen. Also, I've actually turned off or hidden the mouse, or at least tried to...
when i drag an resize the disc it is ugly flashing because at page1 I draw the not finally disc and clear it with cls continuously with moving the mouse. this will be solved in a better way in future...
I'm on the trail of the error, but so far I can't figure out why it's only in the lower third of the screen. Perhaps someone here has an idea...
m4.mp4.zip
the movie...
disco4now
Posted: 11:19pm 22 Dec 2025
If you load it here I can try on the latest firmware I am working on.
Gerry
F4 H7FotSF4xGT
hhtg1968
Posted: 08:28am 23 Dec 2025
ok. i will be home at the 26.12. at home is my cmm2...
hhtg1968
Posted: 09:01am 23 Dec 2025
@disco4now:
my son mailed me the file...
here it is:
hp.bas.zip
hhtg1968
Posted: 09:04am 23 Dec 2025
@disco4now:
to see the error on screen:
run the progam
choose "box filled"
press tab or right mouse button for paint screen
click once for the first point
release mouse button
drag the box bigger and move the mouse into the area down on the screen an you see the errors...
Edited 2025-12-23 19:05 by hhtg1968
hhtg1968
Posted: 10:52am 23 Dec 2025
perhaps a link to movies is better (than uploading as zip):
https://www.youtube.com/@heinrichhubbert8474
movies of errors
Edited 2025-12-23 22:20 by hhtg1968
