Local Time 03:45 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite Firmware Release Version 6.02.00
     Page 2 of 5
bfwolf
Posted: 01:41pm 26 Jan 2026
Perhaps Geoff updated the manual today and changed the download again?
Posted: 01:53pm 26 Jan 2026
Geoff updated the manual and created the download today (Aus time) with files I supplied to him yesterday (my time). Remember, we have a massive timezone difference to confuse everything as well.
bfwolf
Posted: 02:07pm 26 Jan 2026
  matherp said  Remember, we have a massive timezone difference to confuse everything as well.
Yes, indeed !!!
Just checked for the new "clipboard" after update to V6.02.00b: Works!
Regards ant thx!
Edit:
Ah: Perhaps you could consider incrementing the last digit of the version number when you release an update for a new version? That would be great and would avoid confusion.
So, in this case, V6.02.01
Edited 2026-01-27 00:11 by bfwolf
DigitalDreams
Posted: 03:21pm 26 Jan 2026
Editor issues with 6.02 here (LCD)....
F4 no longer highlights all lines making it difficult to know what you've selected, yet still works. In some .bas files the highlighted section flashes on and off each time you move down a line. Repeatedly pressing up results in the same flashing yet alternate lines are then left highlighted !?.
If F10 is pressed followed immediately by 'esc' the screen goes white !.
Posted: 03:25pm 26 Jan 2026
What LCD, what version? Tested on SSD1963 and works fine.
Edited 2026-01-27 01:38 by matherp
DigitalDreams
Posted: 03:40pm 26 Jan 2026
  matherp said  What LCD, what version?
Best I can do right now is from the option list...
Picomite MMBasic RP2350A V6.02.00
Option lcdpanel console ,, FF00
Option display 26, 40
Option lcdpanel st7796sp, portrait,gp14,gp15, gp13,,invert
Edited 2026-01-27 01:41 by DigitalDreams
Posted: 03:49pm 26 Jan 2026
In other words a PicoCalc? No idea what they have done. Just tested a RP2040 and a RP2350A with a waveshare 320x240 ST7789 and that also works perfectly. Do you get any issues if you only use F4 on the same screen without it scrolling?
UPDATE:
Also tested ST7796SP and ST7796BUFF with no issues
Edited 2026-01-27 02:50 by matherp
Posted: 06:10pm 26 Jan 2026
Peter,
Above mentioned 2 bugs did not exist in 6.02.00_a release (the one originally posted). They only exist in the current download. Tested on bare pico (not geek) with RP2040.
homa
Posted: 06:28pm 26 Jan 2026
Sorry Peter!
I tried the latest FW and thought I had to specify the drive when saving the marker. As a result, I cannot delete the file. Except, of course, by formatting drive A:.
But loading works ;-)
Matthias
Addendum: Renaming/moving with FM helped.
> files
A:/
  <DIR>  .
  <DIR>  ..
19:20 26-01-2026         93  a:clipboard.bas
19:18 26-01-2026          4  bootcount
19:16 25-01-2026      13312  demo4.bas
19:16 25-01-2026      24704  dtn-super_mario_brothers.mod
19:16 25-01-2026      50432  fm175.bas
19:16 25-01-2026     622720  help.txt
19:16 25-01-2026      22362  hitme.bas
19:16 25-01-2026     264704  jtel_hitme.mod
20:06 25-01-2026       6182  sprite25.bas
19:16 25-01-2026       6182  spritedemo.bas
2 directories, 10 files, 1298432 bytes free
> option list
PicoMiteHDMI MMBasic USB RP2350A Edition V6.02.00
OPTION SYSTEM I2C GP20,GP21
OPTION FLASH SIZE 4194304
OPTION COLOURCODE ON
OPTION KEYBOARD GR
OPTION RESOLUTION 640x480 @ 315000KHz
OPTION SDCARD GP22, GP26, GP27, GP28
OPTION AUDIO GP10,GP11', ON PWM CHANNEL 5
OPTION RTC AUTO ENABLE
OPTION MODBUFF ENABLE  192
OPTION PLATFORM HDMIUSB
> kill "a:clipboard.bas"
Error : Could not find the file
Edited 2026-01-27 04:31 by homa
Posted: 06:33pm 26 Jan 2026
The only change in the newer release is in the editor relating to F4. I've tested everything on windows and it just works. I've checked it has masses of stack available and the program size is still within the same 848Kbyte envelope. Try clear_flash and re-load.
I've just rebuilt it to test again so you can try this if you want but I can't see it behaving any different.
PicoMite.zip
  Quote  I tried the latest FW and thought I had to specify the drive when saving the marker.
You need a:/ to indicate the drive when saving. You could have deleted the file with
KILL "a:/a:clipboard.bas"
Edited 2026-01-27 04:37 by matherp
homa
Posted: 06:44pm 26 Jan 2026
  matherp said  The only change in the newer release is in the editor relating to F4. I've tested everything on windows and it just works. I've checked it has masses of stack available and the program size is still within the same 848Kbyte envelope. Try clear_flash and re-load.
PicoMite.zip
Who do you mean?
Thank you! It's a great feature in general!
Posted: 06:52pm 26 Jan 2026
Who do you mean?
Harm
Posted: 07:49pm 26 Jan 2026
Peter,
On a bare pico with only SD card attached, running 6.02.00_b (the one with the new edit clipboard save function) from Geoff's site (not your re-build).
- The F4 problem seen once, this time shifting the whole text 1 line down. And the highlighting then is shifted with respect to the text. But could not repeat. This was just the first time after installing the firmware (after a flash clear). Successive tries to replicate it was working fine.
- The file transfer problem with MMCC was not duplicated.
Tomorrow I'll try again the GEEK board. Find out if it is related to something in the GEEK (the GEEK is a RP2040 with 4Gbyte flash (not 2), configured with "pico off").
Maybe it is related to the GEEK.
B.t.w. The GEEK is a RP2040 microcontroller (defaulting to 200MHz) that is configured through OPTION CPUSPEED to 252 MHz. Maybe that is a bit too much for the tiny board with miniature voltage regulator. But that remark is unrelated to my observations, since I manually configure it down to 200MHz anyway.
EDIT: pulled out the second GEEK. With 60200_b the file transfer with MMCC works fine. The issue with the F4 in the editor, with the text shifted down 1 line can be duplicated. The first time after a CPU RESTART, when opening the editor, the text starts with a blank line on screen, followed by the text of the program listing. When pressing F4 to top line is highlighted (in this case the blank line) but in the highlight is the text of the second line. It is as of a "line feed" is in the buffer of the screen output when opening the editor. But this cannot be duplicated after the first time. Only after a CPU RESTART (or changing the OPTIONS) this happens once.
To me it is a no-brainer. Not nice, but not obstructing any progress.
Edited 2026-01-27 06:11 by Volhout
Posted: 08:28pm 26 Jan 2026
  Volhout said  @Peter,
- File Manager MMCC (linux) cannot transfer files anymore from GEEK to PC
Problem with MMCC Linux V5.4.0, not MMBasic.
I will investigate.
JIm
Posted: 08:53am 27 Jan 2026
  Quote  The issue with the F4 in the editor, with the text shifted down 1 line can be duplicated. The first time after a CPU RESTART, when opening the editor, the text starts with a blank line on screen, followed by the text of the program listing. When pressing F4 to top line is highlighted (in this case the blank line) but in the highlight is the text of the second line. It is as of a "line feed" is in the buffer of the screen output when opening the editor. But this cannot be duplicated after the first time. Only after a CPU RESTART (or changing the OPTIONS) this happens once.
Sounds like linux is putting a CR or LF in the output as you open the editor. I certainly can't replicate this in windows.
Posted: 11:22am 27 Jan 2026
@Peter,
Sounds like a Linux issue that upsets Putty. GFXterm on Linux does not show this.
Maybe it is even related to opening/closing of the USB port. Note that Linux closes the port when pico reboots. Manual restart of Putty re-opens it (and therefore also misses/does not show the bootmessage). But maybe (timing) the last CR or LF of the bootmessage is in the USB buffer still when Putty grabs it.
Anyway, not something you can worry about.
Posted: 11:26am 27 Jan 2026
Just to confirm then, With GFXterm on Linux you are seeing no issues and Jim has confirmed that the transfer issue is in MMCC so there is nothing for me?
Edited 2026-01-27 21:27 by matherp
Posted: 01:23pm 27 Jan 2026
Peter,
No issues at the moment, but I am currently not able to spend much time on verification. To busy at work. Hardly time to breathe.
Posted: 02:05pm 27 Jan 2026
  Quote  To busy at work. Hardly time to breathe.
Just wait until you are retired, then you will really have no time
Posted: 03:45pm 27 Jan 2026
Hehe....
Very, very true.  lol
     Page 2 of 5
