Local Time 19:24 24 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMEdit V5.4.0
Posted: 11:10am 18 May 2026
Sorry about that Fred, I will add USER_FUNCTIONS to the list.
Turbo46
Posted: 05:35am 20 May 2026
Thanks Jim, The "Next after replace" works well, very much appreciated.
I think I must have somehow assigned the Action button to "Run in DOS" because that is what it does for me without using the CTRL key. Could it possibly be made to "Run MMB4W" by using the ALT key? Or if I did assign it to run in DOS can I reassign it to run MMB4W normally and MMBasic for DOS using the CTRL key?
Bill
Posted: 06:42am 20 May 2026
Hi Bill,
In FILE/PREFERENCES/EXTERNAL PROGRAMS you can enter the desired incantation to start MMB4W (or MMB4L in Linux systems).
This is activated by clicking the following icon:
Posted: 07:01am 20 May 2026
Bill,
Volhout is correct.
Whatever is configured as External program "0" will be run with <ctrl>-Click
Whatever you have set as "set as default" will be run by click without any modifier key.
So, leave external program 0 as is pointing to DOS and
switch to where-ever you have MMB4W and click on "Set as default"
