Local Time 00:16 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite V6.02.01 release candidates
     Page 2 of 9
terekgabor
Posted: 04:53pm 05 Mar 2026
Thanks! I’ll try.
Posted: 05:01pm 05 Mar 2026
Mozzie
Please try this. Now supports G4 and you can peek the position and activity - see manual
Stepper_Reference.pdf
PicoMite.zip
Martin H.
Posted: 05:04pm 05 Mar 2026
  terekgabor said  Thanks! I’ll try.
As my little Raycaster draws on Framebuffer and Blits it to Screen N so generally,
it also works on LCD Picos.
But I am not sure if Picocalc does run with the official Picomite firmware out of the Box. So you might have to wait until its developers (clockworkpi) make an update to the firmware.
Edited 2026-03-06 03:13 by Martin H.
'no comment
terekgabor
Posted: 05:06pm 05 Mar 2026
It is running now on Picocalc, I just upgraded to RC1.
Briano
Posted: 12:38am 06 Mar 2026
I'm having trouble running a program I wrote which uses the FRAMEBUFFER command in RC1. It  worked in v6.01, but fails with 6.02.01b6 and 6.02.01RC1.
I narrowed the problem down to these two statements.
FRAMEBUFFER Create
FRAMEBUFFER Copy N, F
On my PicoCalc with BIOS 1.6 and Pico 2W, this causes WebMite to crash and reboot.
I tested but the WebMite and PicoMite versions for Pico 2 and both crash.
I suspect this could be a bug. Could someone test this on a non-picocalc device with a 2W?
Thank you.....Brian
Update: The last version of WebMite where this worked was 6.02.01b5 which came from Ernst.
The problem appeared in WebMite 6.02.01b6 which was the first supported version.
...Brian
Edited 2026-03-06 10:50 by Briano
Posted: 01:14am 06 Mar 2026
I don't have a 2W but loaded RC1 on a RP2350A VGA and
FRAMEBUFFER Create
don't cause any problem.
mozzie
Posted: 04:24am 06 Mar 2026
G'day Peter,
Thanks for the update, I will give it a test and report back.
Lyle.
toml_12953
Posted: 05:08am 06 Mar 2026
  Briano said  I'm having trouble running a program I wrote which uses the FRAMEBUFFER command in RC1. It  worked in v6.01, but fails with 6.02.01b6 and 6.02.01RC1.
FRAMEBUFFER Create
Thank you.....Brian
...Brian
I have a PicoCalc with Pimoroni Pico2 (no web) and the copy reboots my system.
terekgabor
Posted: 06:11am 06 Mar 2026
I have “standard” Pico 2 W with Picocalc and same problem with framebuffer copy.
I think b6 was the first version from original Picomite version fits for Picocalc also.
Maybe there remained a bug somewhere.
Edited 2026-03-06 16:37 by terekgabor
ville56
Posted: 06:47am 06 Mar 2026
just tested on a Pico 2 W, framebuffer create and framebuffer copy n,f do no harm here. BUT this may be code position dependent, at least from my past experiance. I've somtimes got strange behaviour (hangs or crashes) but no messages about low memory or heap. Moving the framebuffer create as far as possible to the beginning of the code did help most of the time.
73 de OE1HGA, Gerald
Posted: 08:25am 06 Mar 2026
toml_12953
Please provide a test program demonstrating the issue.
Please do as follows:
OPTION LIST
make a note of the configuration of the LCD
OPTION LCD DISABLE
OPTION LCD as per the original but substitute ST7796SP as the type of display
test again
if still the same repeat with ILI9488P
You can also try ST7365PBUFF
Let me know what happens
Edited 2026-03-06 18:30 by matherp
Posted: 10:37am 06 Mar 2026
@Peter,
In case you offer the option for a retriggerable ONESHOT, you could use the oneshot as an AM demodulator.
Posted: 10:51am 06 Mar 2026
Don't understand what you are asking for compared to what is there now
Posted: 12:04pm 06 Mar 2026
V6.02.01RC2
PicoMiteV6.02.01RC2.zip
Fixes bug in reading from a ST7365P LCD controller as used in the PicoCalc
Improves validation of FRAMEBUFFER COPY when using LCD displays
STEPPER command now supports G4
Use PEEK(STEPPER X/Y/Z/ACTIVE) to get current position
ONESHOT command now support a retriggerable mode
  Quote  ONESHOT triggerPin, sense, outputPin, prePulseDelay, pulseWidth [, quiescentPeriod]
or
ONESHOT R, triggerPin, sense, outputPin, prePulseDelay, pulseWidth [, quiescentPeriod]
or
ONESHOT DISABLE
Will configure a background one-shot pulse generator.
When the selected trigger edge is detected on 'triggerPin', MMBasic starts a delay of 'prePulseDelay' microseconds, then toggles 'outputPin'.  After 'pulseWidth' microseconds it toggles 'outputPin' again.  This creates a pulse in the opposite sense to the output pin's idle state.
An optional 'quiescentPeriod' (microseconds) can be supplied.  If present, ONESHOT will ignore retriggers for that period after the pulse completes.
'sense' selects the trigger edge transition and can be POSITIVE (also RISING) or NEGATIVE (also FALLING).  Triggering is edge based (transition), not level-state based.
Timing is interrupt driven and non-blocking.  Delay and pulse width are specified in microseconds.
`ONESHOT R` enables retriggerable mode.  In this mode, a new trigger while active will restart timing instead of being ignored.
In retriggerable mode:
If a trigger arrives during pre-pulse delay, the pre-pulse delay is restarted from that trigger.
Triggers are not queued.  During pre-pulse delay, each new valid trigger replaces the previous pending delay and restarts timing.
This means the pulse starts only after a quiet gap at least as long as `prePulseDelay` following the most recent valid trigger.
If triggers continue to arrive more frequently than `prePulseDelay`, the output transition can be deferred indefinitely until triggers stop.
If a trigger arrives during the pulse, the pulse width timer is restarted from that trigger (the output stays in its active pulse state).
If a trigger arrives during quiescent period, a new cycle is started (pre-pulse delay then pulse).
'prePulseDelay' may be set to 0, in which case the pulse starts immediately on the selected trigger edge.
'pulseWidth' must be a positive value (>0).
Notes:
'outputPin' must be OFF or DOUT when ONESHOT is configured.
If 'outputPin' is OFF it will be configured as DOUT and driven low before ONESHOT is armed.
If 'outputPin' is already DOUT, its current state (high or low) is preserved and the generated pulse is the opposite polarity.
Only one ONESHOT configuration can be active at any one time.
In standard (non-retriggerable) mode, additional triggers received while ONESHOT is in the pre-pulse delay period, while the pulse is active, or during any configured quiescent period are ignored.
ONESHOT DISABLE stops background operation, cancels pending timing events and restores the output pin to its idle state if a pulse was in progress.
ClearExternalIO() also disables and clears ONESHOT background activity.
The trigger and output pins must be different pins.
Example:
SETPIN GP2, DIN
SETPIN GP3, DOUT
ONESHOT GP2, POSITIVE, GP3, 50, 200
This waits for a rising edge on GP2, delays 50µs, toggles GP3, then toggles GP3 again 200µs later.
Retriggerable example:
SETPIN GP2, DIN
SETPIN GP3, DOUT
ONESHOT R, GP2, POSITIVE, GP3, 50, 200, 500
In this mode, each valid rising edge on GP2 retriggers ONESHOT while active.
If a trigger arrives during pre-pulse delay, the 50µs delay restarts.
If a trigger arrives during pulse, the 200µs pulse timer restarts.
If a trigger arrives during the 500µs quiescent period, a new cycle starts.
toml_12953
Posted: 12:38pm 06 Mar 2026
  matherp said  toml_12953
OPTION LIST
OPTION LCD DISABLE
test again
The test program just does those two things:
FRAMEBUFFER Create
Since I have a PicoCalc, all the LCD options are fixed in the firmware. If you want me to change the LCD and recompile the source, let me know. Here are the options:
PicoMite MMBasic RP2350B V6.02.01RC1
OPTION SERIAL CONSOLE COM1,GP0,GP1,BOTH
OPTION LCD SPI GP10,GP11,GP12
OPTION SYSTEM I2C GP6,GP7, SLOW
OPTION FLASH SIZE 16777216
OPTION LIBRARY_FLASH_SIZE  52000
OPTION COLOURCODE ON
OPTION CONTINUATION LINES ON
OPTION CASE UPPER
OPTION TAB 8
OPTION DEFAULT COLOURS GREEN, BLACK
OPTION KEYBOARD PICOCALC
OPTION PICO OFF
OPTION CPUSPEED (KHz) 384000
OPTION LCDPANEL CONSOLE ,, FF00
OPTION DISPLAY 26, 40
OPTION LCDPANEL ST7365P, PORTRAIT,GP14,GP15,GP13
OPTION BACKLIGHT LCD 96
OPTION SDCARD GP17, GP18, GP19, GP16
OPTION RTC AUTO ENABLE
OPTION MODBUFF ENABLE  192
OPTION PLATFORM PicoCalc
OPTION PSRAM PIN GP47
Edited 2026-03-06 22:39 by toml_12953
Posted: 12:43pm 06 Mar 2026
You don't need to recompile the source with my build you can change options using the standard MMBasic commands
HOWEVER, please try RC2. The problem should be fixed
Briano
Posted: 02:58pm 06 Mar 2026
  matherp said  You don't need to recompile the source with my build you can change options using the standard MMBasic commands
RC2 fixed the FrameBuffer Copy issue for me. (Picocalc/2w).
Thank you!.....Brian
mozzie
Posted: 03:38pm 06 Mar 2026
G'day Peter,
Some brief testing of the Stepper commands and all appears to be working well
The PEEK commands are a great addition, as is G4.
Many thanks once again.
Lyle.
toml_12953
Posted: 04:28pm 06 Mar 2026
You are correct. The problem is fixed in RC2. Thanks!
Bleep
Posted: 06:29pm 06 Mar 2026
Hi Peter,
Have you by any chance tweaked some of the HDMI mode timings, I used to have problems with 640x480 it wouldn't reliably sync on several of my screens at 378MHz but now it is rock steady, but also some of the other resolutions seem to have changed their clock frequencies?
Kevin.
     Page 2 of 9
