Local Time 01:04 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : FRANK OS - Win95
Posted: 11:04pm 10 Mar 2026
FRANK OS already has loadable executables, doesn't it?
Maybe just one as yet?  (I haven't looked enough.)
Posted: 01:09am 11 Mar 2026
Very clever.
V1.0, so very effectively still in Alpha, so I would expect lots of bugs, but every project has to start in Alpha, and then the bug squishing begins to make the project more stable.
Perhaps given some time, this could turn into something more interesting and usable.
Posted: 07:39am 11 Mar 2026
Lots of MMBasic features are stubbed out as yet.
So, think of it as a bit like MMBasic for DOS, maybe.
Posted: 08:07am 11 Mar 2026
I'm not going to bother messing about with a board. The M2 design has a lot of other stuff on it that may or may not be needed eventually so I don't think it's worth bothering with a board that will only do the bare minimum.
bfwolf
Posted: 09:43am 11 Mar 2026
  JohnS said  FRANK OS already has loadable executables, doesn't it?
Yes, as the developer says.
Of course, this is also possible without an MMU. MS-DOS could do it, after all. The executables then need to include a relocation table to correct absolute addresses, or the C compiler needs to generate position-independent code.
  JohnS said  Lots of MMBasic features are stubbed out as yet.
It will certainly require some effort to handle all hardware-related functions (graphics, sound) via the operating system. It simply won't work without it. We'll have to wait and see how this develops.
  Mixtel90 said  I'm not going to bother messing about with a board. The M2 design has a lot of other stuff on it that may or may not be needed eventually so I don't think it's worth bothering with a board that will only do the bare minimum.
The entire system can certainly be compiled for other hardware configurations and boards. Perhaps someone could help with that? The repository is open, and maybe the author will add some configuration options there?
bfwolf
PilotPirx
Posted: 11:11am 11 Mar 2026
I got a mail from Mikhail Matveev which has the following details:
Glad you like FOS — it’s is still on a very early stage, but I will work on it.
Honestly saying, I did not test MMBasic that much — not even sure it is stable. But it runs, so it is a good sign.
Regarding of boards I need to explain a few things first.
The M1 and M2 is not a board ID, it is a way of wiring. Because M2 is HSTX compatible, the FRANK OS does require it.
Next, I have designed lots of boards— all of them are called FRANK. In fact, there are two kind of boards which will suit your need: FRANK M2 and MiniFRANK M2. The difference is that FRANK M2 requires Pico 2 and RP-Zero boards (there are sockets for them). And regarding Pico 2: there is no PSRAM soldered on the original one, so you will need a clone (preferably Pimoroni Pico 2)
You can send him a mail:
Mikhail Matveev <xtreme@rh1.ru>
Homepage https://rh1.tech/
Google says:
The domain rh1.ru is primarily associated with Russian software developer and literary scholar Michael A. Matveev (often appearing under the pseudonym xtreme or xtremespb).
He is a russian guy who lives actually in Greece/Thessaloniki
