Local Time 08:20 19 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : TSCP chess program updated
Bleep
Posted: 10:01am 24 Oct 2026
Hi Harm,
Yes I did notice that, but I just cut & pasted that section of code from the chess client version so assumed it was correct & didn't check any further, I'm now home & have realised that the banner which I couldn't see earlier, is not in a good position either so I'll move that as well.
Regards Kevin
Bleep
Posted: 11:59am 26 Oct 2026
Attached is the latest update to Chess, I've corrected the path '\\' moved the banner, a few other minor cosmetic changes.
I have tested it on a 2040 VGA now as well and it's surprisingly fast, only about 20% slower than the 2350, so still easily fast enough to give a game, maybe not if your are a chess prodigy. ;-) Obviously this will also work with a HDMI output using the VGA screen mode.
Regards Kevin.
chesscsubvga.zip
Posted: 02:59pm 17 Nov 2026
Hi Kevin,
There is one feature you added that is confusing. When using 640x480 on VGA, the colour is produced using tiles.
The feature you added is highlighting the recent move by a box around the related fields. But the colour of the box (fringe) also changes the color of the piece. A white bishop that took a red pawn turned red on the play field. Only by looking at the moves (in text) I noticed this is wrong.
It feels like the board is not updated completely every time. Sometimes a piece becomes invisible, and next move (board update) the piece is back again (just witnessed a white pawn disappearing , and next move re-appearing). Is it possible that a time-out results in an incomplete board when asked from TSCP core.
Edited 2026-11-18 01:29 by Volhout
Bleep
Posted: 03:37pm 17 Nov 2026
Yes it should only update the pieces that change I'll have a look.
