Local Time 07:49 04 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite - integrated compact C-compiler / C-runtime
MikeV73
Posted: 10:54am 03 Nov 2026
  Frank N. Furter said
  MikeV73 said
  Frank N. Furter said  The site isn't working for me...
Build for what hardware you prefer?
Current list:
PICO
PICOUSB
PICOMIN
VGA
M2P1VGA
VGAUSB
WEB
PICORP2350
PICOUSBRP2350
VGARP2350
VGAUSBRP2350
WEBRP2350
HDMI
M2P2HDMI
HDMIUSB
PICOBTRP2350
PICOBTHRP2350
HDMIBTH
HDMIWEB
PC3
But actually tested by me for now: M2P1VGA (2040) and M2P2HDMI (2350)
Hi Mike,
a simple version for the RP2350 would be great!
Frank
May be you missed, it was RC1: https://github.com/DnCraptor/pico-mm/releases/tag/PicoMite-V7.0.00b8-tcc-elf-RC1
Frank N. Furter
Posted: 11:46am 03 Nov 2026
VERY COOL! I'm really impressed! Thank you so much!!!
Frank
MikeV73
Posted: 11:50am 03 Nov 2026
  Frank N. Furter said  VERY COOL! I'm really impressed! Thank you so much!!!
Frank
Thnx you too,
BTW: https://github.com/UKTailwind/PicoMite/pull/146  - PR to your repo (I guess, it is your))
Edited 2026-11-03 21:51 by MikeV73
Frank N. Furter
Posted: 11:55am 03 Nov 2026
  MikeV73 said  BTW: https://github.com/UKTailwind/PicoMite/pull/146 - PR to your repo (I guess, it is your))
??? No, there's nothing from me there...
Frank
MikeV73
Posted: 12:00pm 03 Nov 2026
Frank
ups. sorry, may be I mixed you with other person.
Frank N. Furter
Posted: 12:06pm 03 Nov 2026
Shouldn't it run on an PicoCalc, too? That would be great!
Frank
MikeV73
Posted: 12:33pm 03 Nov 2026
  Frank N. Furter said  Shouldn't it run on an PicoCalc, too? That would be great!
Frank
PicoCalc needs no separate build: the standard PicoMitePICO, PicoMitePICORP2350, PicoMiteWEB and PicoMiteWEBRP2350 firmwares detect it, so TCC should be there on an RP2350, but I have not tested it on one. Note that the compiler really needs PSRAM on the QMI bus (CS on GP0, GP8, GP19 or GP47). As far as I know the PSRAM on the PicoCalc board itself is on GP20, so it can’t be used (to ensure...). On a plain Pico 2 expect only very small programs; a Pimoroni Pico Plus 2 W may work. On an RP2040 only prebuilt ELF files run. If anyone tries it, please report back.
Frank N. Furter
Posted: 12:52pm 03 Nov 2026
Thanks for your explanation. I have a Pico 2 in my PicoCalc without additional PSRAM.
Frank
bfwolf
Posted: 06:07pm 03 Nov 2026
  MikeV73 said  UPD:
N.B. tested on Murmulator 2.0 board only (for now).
Pls. notify, in case you have some issues, or not )) And on what build.
Couldn't resist to burn a 'PicoMitePICORP2350.uf2' on my Pimoroni-Pico +2' - nice..
Created with MMBasic's Editor:
list "a:/hello.c"
#include <stdio.h>
int main(void)
 puts("Hallo!");
 return 0;
Compile and run:
> tcc "-o hello.elf hello.c"
> files
A:/
  <DIR>  .
  <DIR>  ..
00:00 01-01-2024          4  bootcount
00:01 01-01-2024         80  hello.c
00:37 01-01-2024        704  hello.elf
00:04 01-01-2024        704  hello.o
2 directories, 4 files, 12566528 bytes free
> run "hello.elf"
Hallo!
The file "hello.o" is a result of earlier 'tcc "-c hello.c"'
Regards, bfwolf
MikeV73
Posted: 07:42pm 03 Nov 2026
  bfwolf said   'PicoMitePICORP2350.uf2' on my Pimoroni-Pico +2' - nice..
Thnx. PICORP2350 marked as tested )
PhenixRising
Posted: 09:18pm 03 Nov 2026
Same here, RP2350B-DIL with no PSRAM
bfwolf
Posted: 09:43pm 03 Nov 2026
  PhenixRising said  Same here, RP2350B-DIL with no PSRAM
I can confirm: compiling my mini "Hello" application worked even before I enabled PSRAM.
