Local Time 11:26 14 Nov 2026 Privacy Policy
Forum Index : Other Stuff : recharging cellphone by dynamo
KarlJ
Posted: 01:58pm 12 Feb 2010
why not?
Downwind
Posted: 05:01pm 12 Feb 2010
To start with a logging of an anemometer shows peaks and troughs non suitable for a mill for efficient output.
2) Them...the other side of the boundry fence.
3) A council that has lots of red tape for the construction height required to get close to feesiable air.
Funny 10 years ago i always got coastal wind at night and now i get bursts of wind. (well not personally ) but not the good steady wind i use to get.
Pete.
Sometimes it just works
oztules
Posted: 09:33am 13 Feb 2010
Downwind,
you have jumbled some figures there somewhere, but the drift is clear.
Armature reactance does not seem to be terminal, solidity has not taken over.... better loading seems to be at lower speeds.... conclusion ???????... make a good cell phone charger
Well done.
...........oztules
KarlJ
Posted: 12:27am 14 Feb 2010
Pete
I found a windturbine suitable for your place on ebay.
windturbine BIG
Downwind
Posted: 03:52am 14 Feb 2010
Thanks Karl, I would rather the third one down on the left. It looked like more fun
Pete.
isaiah
Posted: 11:50pm 16 Feb 2010
'' I think The Indian Just needs a small c clamp two pieces of wire a 15 foot copper ground rod or copper tubeing and a couple feet of garden hose to go over the ground rod.
Connect one wire to the c clamp the other end to the cell phone - .
The other wire hook it to the ground rod the install the hose over the bottom end and connect the other end of this wire to the + side of the cell phone.
To use clamp the c clamp to the metal part of the train car then take the ground rod and told it up to the electric wires that runs along side the rail road and pick up the static corolla.
This should pick up enough to power the cell phone if he gets too much well it will be another good cell phone. ''Edited by isaiah 2010-02-18
matt down south
Posted: 11:58am 27 Feb 2010
buy a wind up dynamo led torch and tap in to the dynamo output and save the headf*ck
matt
