Local Time 08:36 05 Nov 2026 Privacy Policy
Forum Index : Windmills : Voltages from F&P
Downwind
Posted: 03:00pm 10 Jun 2010
Pictures please, its the 2nd button above from the right hand side with the little green arrow.
You might need to shrink the photos first if they are in a large file size before you can upload them to the forum
Heres how to shrink them if you dont know.
[quote]
Photos would be nice and to post a photo use the button second from the right with the green arrow on top of the reply window.
If you have large size photo files you might want to shrink them first.
I do this in "Paint" open the image in paint then click "Image" .... "Resize"... I use about 50% to both horizontal and vertical ...Then OK....Save AS.. the image... I just add "small" to the previous file name...Click OK.
Now post the photo.
I find it much quicker to upload this way.
The forum will often resize most photos but it is slow at doing it.[/quote]
Once the photo is uploaded it will appear as a string of text code in the reply box here, but if you use the Preview Post button at the bottom next to the Post reply you can have a look at your message/ photos before you post it public.
Once you are happy with it click Post Reply.
We wait to see your creation.
Pete.
Sometimes it just works
MacGyver
Posted: 03:49pm 10 Jun 2010
[Quote=aussepom]My mag motor . . .
Would this mean "magnetic motor" as in a motor that uses magnets as its power source?
If so, will it start by itself? Just curious.
. . . . . Mac
Copeville, Texas
aussepom
Posted: 01:18pm 16 Jun 2010
Hi MacGyver
it does use magnets, and it also uses a pulse, only one coil at any given time is pulsed, it could be a controled star and stop, the unit that I have is a 'test rig', and has been used to prove a number of diferent ways that wingenerators, use, and pulsed magnetic motors.
it has been re cofiguered several time to do thise different tests.
I do not use a N S N S format as I have found there is a numer of problems with this method, I also poved that with the wind generators trying to as I call it 'mimic' a normal motor or alternator is not a very good way for this type of generator.
electro magnetic or wound coils to me do not act the same way that the permenat magnet does, there is also a number of different ways of using would coils, and toriodal's can be very lethal, and can have there magnetic fields so strong if used corectly to cause a plasma field in the centre, or even force all the winding apart so much that they will snap.
I am still modifing the 'test rig' motor, it is also a generator or altenator whatever name that you wish to call it, and I collect all the BEMF.
aussepom
aussepom
Posted: 01:28pm 16 Jun 2010
Hi teryb45
where in oz, I am in melbourne, there is a way round putting up a wind turbine here but it would need to be a Vertical axis one, and if you are trying to cash in on the power pay back , from the grid, well you will need an expencive unit call a grid connet box, what this is it take you power and puts it in synchonisation with the line into your house, this looks at the rotation and also the phase that is connected to your house.
if you can generate more than a certain number of kW depending on you state ruling, some is 3kW some 5kW, and this is not enough for your own use anyway, all you are doing is helping the power companies and Kevin Rudd,.
let me know the state that you live in.
aussepom
MacGyver
Posted: 04:17pm 16 Jun 2010
aussepom
Where are the pictures?
The flavor of your posts suggests to me that you are working in the "over-unity" arena. While this research has produced much in the way of Internet entertainment, there's still no working model and everyone is "testing" stuff, but has nothing to show but a fortune of neomagnets bouncing back and forth.
The over-unity question seems to hinge a lot on theory and has to date produced no authenticated "working models". It's sort of like the Sasquatch thing. We'd all love to embrace "monsters" in the woods, but to date nobody and I mean nobody has produced a living or dead body of one of these things. There's never even been a report of any road kill!
Now, don't get me wrong, "experimenting" is loads of fun; I do it all the time. The difference between experimenting and fact is obvious and if you'll note, many (most!) of the things I concoct have flaws or downright just don't work. The catch here is I "post" all the results; working or not working. I'll admit I'm not the sharpest tool in the shed and it took me longer than it likely should have to learn how to post pictures, but at last I've figured it out and have even learned how to post videos on youtube. You can too, figure it out, I mean!
If you have something, working or not, please post some pictures or crank up a video for the crew here. Who knows? Maybe you're onto something and posting a picture might lead to someone pointing out the flaw that when fixed will make your dream a success. Happens all the time. On the other hand, there's no sense leading someone on and having them follow your lead if you're marching into hell, right?
As an example of someone pointing out a flaw, I currently have flying a set of "test" windmill blades (results with pictures posted in "Windmills" by the way). Perry, an engineer, pointed out that by my mounting a blade spar off center, the torque moment (lever) produced by spinning it, creates a line of force, which by physical law will "crack" my spar, which it did. Go to "Windmills" and look a the pictures in the post entitled "Blade Shank Failure" and read Perry's reply. Fortunately, the "test" hub I'm using was done merely out of convenience. I don't intend on using it permanently; it was only used to test a blade design, which is supposed to quiet the tip rotation.
Just some food for thought. By the way, an angry reply will tell more than shows on its surface, but I expect I'll get one none the less. My intention here is not to anger you. My intention is to show you how to salvage and perhaps improve your project and move forward.
Edit: comma after 'it' & changed 'angular momentum' to 'torque moment'; please forgive me, I'm just a plumber!
. . . . . MacEdited by MacGyver 2010-06-18
Copeville, Texas
terryb45
Posted: 11:01am 17 Jun 2010
thank's AUSSIEPOM
i'am in perth
i do have a inverter already as its got the solar pannels hooked up to it its a 2.5 kw latronic's pav edge the pannels are 8x170 watt so i have 1300 watt room left in it that's why iam trying to find a way to top it up &use it 24/7 & i hope make some spare change by selling the excess power back to senergy that's why i'am trying to find out how to wire the f/p motors tothe inverter and not to the battery's
you got any idear's it would be a help !!!!!!
thank's terry
Perry
Posted: 01:29pm 17 Jun 2010
  aussepom said   Hi MacGyver
aussepom
Those are some pretty big claims. Do you have any data or information that can back it up? Maybe a picture of these destructive plasma fields forming in your coils? You said that you proved many groundbreaking theories. Just looking for some info. Why is it that the guys that discover something new or prove well known theories wrong are the same guys that can't figure out how to use the 'post picture' button. Must be a left brain, right brain thing.
Perry
Edited by Perry 2010-06-18
Downwind
Posted: 01:47pm 17 Jun 2010
I think he is all smoke and mirrors and likes to rattle on about something we will never get to see.
It wouldnt be the first one.
I posted a help above on how to post photos but perhaps i should have spoke ....slower.
Pete.
GWatPE
Posted: 02:29pm 17 Jun 2010
I believe the device talked about by aussiepom is similar to an Adams pulsed electric motor. This used same polarity magnets arranged radially from a rotating axis, with solenoid type pulsed electromagets.
This was from across the Tasman. The unit appeared in Nexus magazine in an article. I happened to get access to a copy of the design notes, and made a test unit similar to the notes. The motor worked, but testing revealed a flaw in the calculations of power and hence efficiency as a motor generator, that was supposed to be over unity. Ended up being 60% efficient instead of the 120% as was originally claimed.
If you get some pictures posted, there will be many whom could offer critical comment.
Gordon.
become more energy aware
MacGyver
Posted: 03:18pm 17 Jun 2010
[Quote=Downwind]I think he is all smoke and mirrors and likes to rattle on about something we will never get to see.
If you go back 500 or so posts to where I started my journey on this platform, you'll see I faced many of these same hurdles. I too made some fairly outlandish claims. At one point I was accused of "blowing smoke" so to say and even got a little offended; bad on me.
Fortunately for me, I was regurgitating stuff I had already actually built. I had no pictures then simply because all the stuff I'd built was 40 years ago and back then I didn't have a digital camera let alone a computer. The Internet wasn't even thought of yet.
Anyway, I thought I'd interject this merely as a little "buffer". This guy as well as others with similar "outlandish" claims might be on the up and up, so I say we give him a chance.
By "give him a chance" I mean lets all hide in the wings and see if any pictures pop up. Unless he's sneaking in time on someone else's computer and is actually destitute, purchasing an inexpensive digital camera or even borrowing one from a friend (perhaps the same friend lending him the computer he uses to post messages here) shouldn't be beyond his expertise, especially if he's got as much on the ball as he has claimed to date!
Just my perspective.
Edit: typos
. . . . . Mac
. Edited by MacGyver 2010-06-19
Copeville, Texas
aussepom
Posted: 02:49pm 19 Jun 2010
Hi
Terry, not sure what the maximum is there for a grid connect system, but you would not be able to use the F/P, there are a few who have modified it to generate power, but mainly they turn it into dc first, due to the frequency that the F/P would generate. I have not had any dealing first hand on them.
First check to see what you maximum amount is that you can generate before spending money. How every what you are trying to do wire direct will not work, to long to explain here, but if you did have a full system with back up battery bank, just turn it into DC and supply you battery pack.
Now as for ‘a picture of these destructive plasma fields forming in your coils’
The explanation was that, this effect could happen in a Toroid coils under certain conditions. I was not referring to any of my coils.
If you are interested in plasma then look at my ‘aussepom channel’ on utube.
And there are 62 pages in google.
Now I came to this forum as I thought that it was mainly made up of Australians, and wanted to help were I could, but I have be met with verbal abuse.
Just because I could not find your pic post button.
GWatPE, No it is not exactly the same as the Adams motor, and you are correct that too can not produce any useful output, well not that I have found.
I will post a pic
But do not expect any more if the abuse continues,
I only as late only follow two forums, and they have pics.
aussepom
MacGyver
Posted: 04:07am 20 Jun 2010
aussepom
This is not meant to be an attack, but could you have made the picture any smaller?
What exactly is that? It looks like someone holding a flashlight (torch for Brits) in a dark closet. What about some still shots of your "machines"?
I'll go for a look see at your youtube location. There again, a "link" would have been a nice touch. You do that by copying and pasting the link code from that little, blue "Forum Codes" link at the bottom of the "Post Reply" box. Just copy the code and replace the URL with your youtube URL and make the "My Link" say anything you want.
If I can figure it out, it's pretty easy. Now it's your turn.
. . . . . Mac
Copeville, Texas
MacGyver
Posted: 04:24am 20 Jun 2010
Okay, I looked at THIS and I'm only assuming it's "your" site.
See there, I made a link for you. Now you don't have to make one, but you really owe it to yourself to give it a try anyway.
From what I saw, I have three comments:
First off, your handle, "SirHOAX" pretty much sets the stage! Look son, if you're wishing to be taken even a little bit serious, you can't pull crap like that; it just won't fly.
Second: The first half or so of the presentation, though well produced, appears to be cheap fireworks going off inside someone's shop. An explanation might be in order so the viewer isn't left trying to make up his own story line!
Third: If you're going to try to pass off ignition of Brown's Gas (HHO) and call that "plasma" then you might as well try to convince me burning a candle is akin to an atomic engine. I liked the fireworks part better. At least it shot some sparks into the air; fun to watch.
In my opinion, if "you" actually created these presentations, your time might be better spent as a cinematographer. I'll give you this much, the production looked very professional. Then again, if the movie was merely a cut and paste job, you're in violation of youtube's terms of use.
You're gonna have to do better than that to convince me and I'm just a silly plumber. Heck, there are actual mechanical and electrical engineers on this 4m. They're likely to tear you to shreds if you try to pass off anything that looks like Merlin just stopped by for a visit!
Again . . . just my humble opinion . . .
. . . . . Mac
Copeville, Texas
aussepom
Posted: 05:44am 20 Jun 2010
Hi MacGyver
I am not "SirHOAX"
Try this
http://www.youtube.com/results?search_query=aussepom&aq=f
this not HHO this is water air and power. and that 'small pic' wel look at the vid, its real and as it was done, and you are alowed to edit a long running vid.
and yes sorry but to me it is an a sarcastic attack, I have not time for sites that do this, I will wacth and see, maybe after you have visited this site, and photobucket.
aussepom
Downwind
Posted: 05:48am 20 Jun 2010
Removed due to comments on the wrong utube site.Edited by Downwind 2010-06-21
MacGyver
Posted: 06:12am 20 Jun 2010
[Quote=aussepom] . . . and yes sorry but to me it is an a sarcastic attack, I have not time for sites that do this, I will wacth and see, maybe after you have visited this site, and photobucket.
"This site"? And "photobucket"? Just where on photobucket would you like me to visit?
I had you figured for a kid, but according to the video you're at least my age. Get a grip!
As for the sarcasm accusation, I tried to defend you! Just back up a few posts and see for yourself.
Personally, I don't care if you learn how to post a picture, set a link or quote anything at all. In the journalism field, "-----30-----" means "end of story".
I'll not respond further (unless really provoked)!
-----30-----
. . . . . Mac
Copeville, Texas
MacGyver
Posted: 06:22am 20 Jun 2010
Okay, call me a liar.
This: http://www.youtube.com/results?search_query=aussepom&aq=f is the exact same link I posted when I manufactured the active link in my reply to you. The video it points to is on YOUR playlist.
It's you and it's your site and it's your video and you're playing games and I'm not!
----------30---------
Honest, Glen; I'm done. It ends here.
. . . . . Mac
Copeville, Texas
aussepom
Posted: 01:58pm 20 Jun 2010
sirHOAX
http://www.youtube.com/watch?v=G9NvboKL43Q&feature=PlayList& p=BFA5BD08573922C7&playnext_from=PL&index=0&playnext=1
aussepom
do these look the same
no more coments
aussepom
Downwind
Posted: 02:34pm 20 Jun 2010
Ausseporn,
This is a perfect example of what happens when you take short cuts and dont bother to post the link correctly in the first place.
Secondly it would be polite of you to start your own threads and not hijack someone elses as you are here.
Pete.
MacGyver
Posted: 07:06pm 20 Jun 2010
-----------30-----------
Copeville, Texas
