Local Time 12:46 14 Nov 2026 Privacy Policy
Forum Index : Other Stuff : cutting circlip groove in hardened steel
yahoo2
Posted: 03:02pm 27 Nov 2011
Hi bob
No, they wont be cheap and probably will snap the blades off like carrots.
The best tool I ever had was a large piece of tungsten shaped like a half moon or a woodruff key. I brazed it to a large hex boring bar, used it for removing bulk material inside and out. just sweat it off with the oxy to sharpen it then stick it back on with a piece of sandwich braze sheet. Like rastus says for general machining you cant beat the higher grade of HSS and a quality shaping wheel. Some homemade angle templates for the grinding wheel are handy, a tool with good clean angles will do a lot of work before it needs resharpening.
yahoo
Rastus
Posted: 10:46am 28 Nov 2011
Hi Bob,
The toolpost grinder sounds ideal for the job and yes,you read my mind with the cross slide.I'm getting to the stage I don't say what I mean,and don't mean what I say Fortunately I have a younger brother who is a fitter & turner,the only snag is he lives 240 miles away.It seems Yahoo can easily justify the cost of tooling.Youch!$1000 for the shaft assembly.I don't have a lathe ect.because of the outlay and consumables.You've probably become more resourcefull out of neccessity and experience.Cheers Rastus
Posted: 02:31am 02 Dec 2011
I have a lathe and now have a tool post grinder for it as well.
Any sort of sharp edged tool is not going to work on a hardened shaft, grinding is the only way.
You can get very narrow cutting wheels (made for angle grinders), some of those are only 1mm thick.
A small diameter abrasive cutting wheel worn down to minimum diameter mounted in a tool post grinder would cut a very clean groove with a pit of patience so the shaft is not overheated.
This is a 5" cutting wheel 3/32" thick (2.38mm) I just happen to have here, but they are available much thinner.
curiosity
Posted: 10:08am 08 Jan 2012
you can turn bearings with carbide lathe tips I've done it many times. you do need a decent brand tip (sandvik or similar)and spin very SLOW
VK4AYQ
Posted: 12:12am 09 Jan 2012
Hi Curiosity
You must have a very rigid lathe as well not the normal hobby lathe.
Bob
Foolin Around
curiosity
Posted: 11:42am 10 Jan 2012
  VK4AYQ said   Hi Curiosity
Bob
Chinese brand 3 phase. I have the luxury of using an industrial lathe at work but it's not very rigid really. I turn mostly stainless steel on it but on occasion we need to modify bearings slightly to get us out of trouble quickly.
VK4AYQ
Posted: 01:46pm 10 Jan 2012
Hi Curiosity
Must be a good machinist then, a dying breed these days as most are machine watchers and are called machinists.
When I had my workshop going commercially I to did a lot of stainless work in the farm and wine growing industry and also rebuilding paper mill machinery, it is a pleasure to work with the right tooling but I must admit I was never to keen on machining bearing cases, I would set them up and grind them mainly.
Still have most of the machinery but retired now so it gets hobby use only.
All the best
Bob
Foolin Around
curiosity
Posted: 09:53am 11 Jan 2012
thanks for the kind words Bob. I wouldn't say i'm a good machinist but i do prefer a challenge. With the introduction of CNC, which I've done very little of, I guess machine watchers are the best you can expect these days
Oscar4u
Posted: 08:28am 12 Jan 2012
Am enjoying your grinding thread.
I made a bracket that clamps in my toolpost which holds a 115mm grinder. Not as good as a proper toolpost grinder, but I am dutch and have a reputation to uphold! Cheers
Oscar
Oscar4u - for all your rotary cowshed repairs
Posted: 08:47am 12 Jan 2012
I have had my lathe for about forty years, but would still class myself as a beginner.
I just don't use it often enough to be a serious lathe addict.
But by golly it really comes in handy sometimes.
It seems to me, a very big part of lathe work is coming up with really cunning and devious ways to do rather unusual things with very limited resources.Edited by Warpspeed 2012-01-13
VK4AYQ
Posted: 10:01am 12 Jan 2012
It is all good fun and really satisfying when you make something that works.
Bob
Foolin Around
