Forum Index : Microcontroller and PC projects : The CGMMSTICK1 Maximite
Gizmo is right. Unregulated wall warts tend to change in voltage as their current changes. Micromites and Maximites! - Beginning Maximite |
| djuqa Guru Joined: 23/11/2011 Location: AustraliaPosts: 447 |
Yes some of them can be 10% or more RIPPLE factor with up to 10v output with little load current. Good 5v plug packs are CHEAP buy One. VK4MU MicroController Units |
pcaffalldavis![]() Senior Member Joined: 17/10/2011 Location: United StatesPosts: 187 |
Well I have a few 4.5 volt wall transformers for old sony discmans, remember those? I'll check their voltage, but do you think I can use 3 D cells for the battery back-up for when power goes out? I don't know of any 5 volt batteries. I wonder if 4.5 volts will be enough? What do folks suggest for battery back-up for CGMMSTICK1's when line power goes off? Pete in Hyder We're all here 'cause we're not all there. |
| rhamer Senior Member Joined: 06/06/2011 Location: AustraliaPosts: 174 |
Run the whole thing from a UPS, they are very cheap these days and solve all the change over and charging issues. Cheers Rohan Rohan Hamer HAMFIELD Software & Hardware Solutions Makers of the Maximite Expander. http://www.hamfield.com.au |
TassyJim![]() Guru Joined: 07/08/2011 Location: AustraliaPosts: 6619 |
The MCP1700 regulator on the CGMMSTICK1 is a very low dropout one so yes, you could run it off 4.5V with room to spare for an isolating diode. With a shottky diode (~0.35V volts drop) you could let the battery volts drop to 4.0 before thing went cranky. I have a need for 12V as well so I run everything of 12V with 8 and 5 volt regulators as required. The maximite monitors the battery volts and if the power has been off for too long the maximite turns off some of the higher current drawing devices such as cameras and the network switch. Jim VK7JH MMedit |
| 3buns Newbie Joined: 16/07/2012 Location: United KingdomPosts: 8 |
Hi all, new member here, great forum! I received my CGMMSTICK1 in the post here in the UK the other day. I am planning to build a scaleable retro games console with it. My question is regarding the 3.3v available on PIN 1. I have read that the device will draw 125mA'ish,does this include powering the SD card? The MCP1700 I read is rated at 250mA. I would like to draw up to 50mA from the 3.3v pin for joystick resistor pullups, is there enough headroom on the regulator for this, or should I really go for an off board regulator? Many thanks, Kurt |
Best to play it safe and use an off-board regulator. SD card access is sensitive to voltage dips on the 3.3V line. Micromites and Maximites! - Beginning Maximite |
