Local Time 18:54 04 Nov 2026 Privacy Policy
Forum Index : Windmills : Intro from newbie and controller question
     Page 2 of 3
BobMann
Posted: 12:49pm 18 Jan 2012
  Gizmo said   Bob keep on topic please. Yes the smartdrive can make over 1000 watts in the right circumstances with a Neo stator, but here we are talking about a 48 volt battery system, and a turbine that could only supply 500 so watts into the alternator, so figures from a smart grid connected system are not relevant.
Also making posts that are promoting something ($) that wont work in this situation is not on.
Glenn My brother from down under made the statment of the 200 Watts and that the 60 stators were junk. I have shown it is not that, it has just not been used in the right way. I guss some Yanky had to work on it!!
If you wish after my Boston MA Home show Jan 21-22 I will rerun the test with a stock 60 stator and hub to show how much more power can be pulled from it using a controller of this kind.
By the way the Smart controller is made to do just that Made to charge batterys too at a low cost with out cuting up stators and throughing a way power.
I am all about keeping the cost down for the DIY.
I think Steves VID will do a better way of showing the Smart Controller and how it works.
Steves VID
Bob Mann
Posted: 01:11pm 18 Jan 2012
Bob, have you achieved 1000 watts from a 60 series stator on a windmill?
Yes, Moose could add a $400 smart controller, build a Neo magnet hub for another $200, and this will probably double his power output, but he is still limited by the turbine. That turbine is designed for axial flux alternators, which have a different power curve to the F&P smartdrives. Our trials over the last couple of years have shown the GEO222 profile is a good match for the F&P's. It would be cheaper for him to find a couple of 80/100 series stators, add some caps, and a set of bigger blades and get more power.
Even just using a 80 or 100 series wired to suit would give over 300 watts with Mooses turbine, and thats a cheaper option again.
What we want to do is give Moose some advise that has a proven record, so he can buuild a better windmill.
I have no doubt the work you are doing Bob will give better power figures from a F&P based windmill, but its not ready yet, and no help to Moose. Once you have a working windmill that has been tested and sorted, then that would help Moose.
I'm loosing my cool with this.
yahoo2
Posted: 01:45pm 18 Jan 2012
  moose4621 said
It sounds like a "diversion" controller is the go. I didn't know there was such a thing.
  Gizmo said
What we want to do is give Moose some advise that has a proven record, so he can build a better windmill.
I can tell you that having a solar (in series) controller with an inbuilt diversion control system like your plasmatronic has, is a real winner!.
Having one controller making all the charging decisions will save you a lot of headaches, separate controllers tend to fight against each other. There used to be a reference manual that explained how to set up the diversion load resistor and the software,it would be worth having a read of this, if you can find one.
It doesn't need to be restricted to the wind turbine,once it is set up and operating any power supply that pumps out 60 volts and less than 30 amps will be controlled by the diversion, just connect the power across the battery bank and stand back!. much cheaper than a fancy 48 volt battery charger.
cheers YahooEdited by yahoo2 2012-01-19
BobMann
Posted: 02:32pm 18 Jan 2012
  moose4621 said   Hi all,
Newbie here. 1. I remember seeing data somewhere that showed the 80 series to be more productive in an 48volt configurations. Has anyone got real results along these lines? And any idea where I can get one?
2. While a dump load seems to be the commonly accepted method of controlling the wind gennie after charge is reached, it seems to make sense to me to be able to brake the gennie by shorting it and thereby preventing overcharge and saving on wear and tear at the same time but I can't seem to find a controller that does this. Is there a reason why this is a bad idea?
3. has anyone tried a pm motor speed controller to momentarily engage after a minimum wind speed is reached to force a start on one of these f&p things to overcome the cogging?
Maybe an arduino controller could achieve this?
Regards Moose.
He asked these things and I gave what I have tested to work. I am sorry if you do not get what we have build and tested to work.
Sorry if a stepped on you toe,s
Bob Mann
Rastus
Posted: 02:44pm 18 Jan 2012
Hi to all,
Is there a link that can inform me of the number of coil windings per pole,needed to rewind a 60's into an 80's unit.Is the only option to doing this manual,considering 80's seem to be harder to stumble onto.I'm intending to use 60's star 80's delta duals,but I'm getting the sense that dual 80's are the way to go!Cheers Rastus
herbnz
Posted: 04:31pm 18 Jan 2012
Hi Rastus
I always rewind its easy to remove old windings just cut start tie of and walk down driveway (do have to start right phase and end but not hard to work out )
rewind Use 1mm wire need to convert connections used here to turns per pole but nowdays I have a base and use my own knowledge.
a previous post of mine below.
Avatar
Online Status: Online
Posted: 23 October 2009 at 9:05am | IP Logged Quote herbnz
Hi
To throw aspanner in the works, I never reconnect its much quicker easier to rewire.
This, to me means I am not interested in codes that show connection methods, rather I convert to turns / phase or in fact when lazy turns / pole. ie a common unit 100sp is 7 pairs in series or to me 44 turns *2 = 88 turns /phase
or 6 turns /pole.
A code that showed turns /phase would suit me better but then I am a loner on this I suspect
Herb
There are other times I have commented on this but most consider not on.
The most turns I use per pole is 12
I dont worry about scrambling the windings just get as tight as possible.
Herb
moose4621
Posted: 09:15pm 18 Jan 2012
I really appreciate all the input and advice here and thank you all for joining in. I am learning heaps and with most replies here, there is a faint sound of a penny dropping.
  fillm said   You have pretty well hit the nail on the head there. I started out much with the same thought pattern you have and stuffed around trying to make blades out of ABS pipe which closely resembled a clark y , flat one side and a curve the other , I thought they were pretty good at the time and was proud as punch of how well they went. When I was sent a set of GOE222 blades and after seeng the benifit a proper air foil at work the howling banchee blades went into the Bin promptly, I vowed never to stuff arround trying to make blades again, and put more time into other areas, if the blades do not convert the wind energy you are behind the 8 ball from the start.
But I spent so much time on them. By far the most time consuming task. And,......and,........and,.........BUGGER!
In their defense though, they are dead quiet blades, except when grossly oversped.
So the GEO222 blades with constant cord and progressive angle of attack, (no twist), is the way to go on a F&P? Who would have thunk it? Thanks Fillm.
  fillm said   depends on how much you want to make.
Well, to be honest, I started this project as an experiment to see how effective a wind turbine would be in this location. I decided on the F&P because it was cheap and easy and I had hoped that on completion it would make a worthwhile contribution to the batteries. Once proven, I would embark on a 1.5Kw+ mill that would make up a shortfall I have in the solar panels since buying larger capacity batteries.
I wish I had read words to this effect five years ago. Thanks Gizmo, well worded. And your dead right, I will not contemplate spending $600 on a washing machine mill.
Here's another of those penny dropping moments. Thanks Yahoo, and appreciate your advice.
I was confusing Dump load controller and diversion controller as two different things but if I have finally got it right, they both divert the excess current into a dump load. In which case I am familiar with this and was originally asking about a controller that would short the three phase from the mill to stop it from overcharging. I have since reasoned that I can use the Load terminal on my PL60 to activate a relay/contactor to do the job. I would not be able to use PWM mode though. The PL60 is a great little charge controller and has served me well for six or seven years so far. Does a great job of generator control too!
  herbnz said
I always rewind
That's interesting Herb. I guess thats an option. Where do you guys source the enamelled copper from? I can only assume it's bloody expensive.
Many thanks to all.
He who dies with the most toys, wins!
yahoo2
Posted: 10:54pm 18 Jan 2012
there is a difference between a series dump load and diversion control but a lot of people don't make the distinction. With a traditional dump load the turbine is switched out of the battery circuit and the energy is transferred to a large resistor, a diversion control just manages the battery voltage by progressively switching on the resistor load, the turbine is still connected to the battery and running.
That is why the pl-60 can run PWM on both solar and diversion at the same time.... and why you could throw the stop switch on the turbine and supply power from any other source you choose. even some extra solar panels!
It is to long since I have worked on a pl-60, my memory is a bit hazy on what additional outputs you have, if any. shorting the phases is pretty brutal, I wince when I do it once by hand on a gusty day, I would have nightmares about it switching continuously all day.
yahooEdited by yahoo2 2012-01-20
moose4621
Posted: 11:06pm 18 Jan 2012
  yahoo2 said   there is a difference between a series dump load and diversion control but a lot of people don't make the distinction. With a traditional dump load the turbine is switched out of the battery circuit and the energy is transferred to a large resistor, a diversion control just manages the battery voltage by progressively switching on the resistor load, the turbine is still connected to the battery and running.
yahoo
Thanks for the clarification Yahoo. I get the impression that you believe I should stick with convention and divert to a resistor.?
yahoo2
Posted: 11:33pm 18 Jan 2012
No moose I don't have any bias one way or the other. I have used a contactor switching out at 14.7 volts and back in at 12.1 volts but the solenoid used a lot of power itself, a latching relay would have been better but this was before internet and I didn't have the skills to build it. I am just saying you have most of the bits needed for a working mill on your main system already, you can have a go and learn while it is running, most first timers haven't got this luxury.
Sorry, I slipped an extra bit in my last post about solar panels while you weren't looking.
yahoo
yahoo2
Posted: 12:08am 19 Jan 2012
  moose4621 said   there is a faint sound of a penny dropping.
My biggest moment like this was when I compared my power use with a friends, He had 2.2 Kw a day to run his water pump, I had 35 watts (I use a large overhead tank for water pressure and fill it every two months) We fitted a huge pressure accumulator to his pump and his pumps power use dropped to 100 watts a day. I was gobsmacked It was raining pennys that day!
moose4621
Posted: 04:57am 19 Jan 2012
yahoo
In standard form, without the expansion board, I have the "G" terminal which in my case is configured to remote start the genset, and the "Load" terminal which I have now configured for load dumping as per these instructions. Without the expansion board, you only have two external controls available.
It's a pity the input from the wind generator won't be monitored by the PL and used in it's SOC estimation as well as total in/out, etc. But, as you say, it's a lot better than starting from scratch.
No wind today.
Took advantage of the down time and wired the F&P to the main system today. Although not getting much out of it, was being wasted on spare batteries.
yahoo2
Posted: 05:33am 19 Jan 2012
PL Reference
moose4621
Posted: 06:10am 19 Jan 2012
  yahoo2 said   PL Reference
Got that one. Doesn't cover wind/dump load very well.
moose4621
Posted: 06:40am 19 Jan 2012
Another penny drops! If I connect the + DC from the mill to the shunt connected to the PL via the PLS2 remote adapter, it will record ext charge.
I just saw that the genset powered charger is connected here too. Does this sound right?
Doing this would give the pl60 the ability to log external charging from the wind generator, (and genset) and even display ext amps as well.
fillm
Posted: 09:30am 19 Jan 2012
Hi Moose ,
You are correct , but when you connect the wind with a PLS2 & Shunt it adds to the total input so you can not see wind or other charging seperate . For the wind you could add a seperate amp meter or better still a logging system like the piclog or similar .
I have a PL60/PLS2 in my system but it is hardly utilized more than a dump load controll now as I also have a MPPT solar charger.
Plasmatronics have two downloads for setting up wind / solar , LINK Wind Sheet 1 and LINK Wind Sheet 2 , there is also the G-set or L-Set terminals that can be used to activate a solid state relay from memory but its been a while since I have played around with all the options , but none the less they are a top class voltage reg and fully programable on #4 as a battery management system rather than at 1 voltage the dump/diversion turns on.
The PL20 is a good one as well as it can switch 20A which is basicly 1kW in 48V and it comes at a better price , basicly 2 PL20s for the price of a 60 . Be warned about the PL40 as it can only switch 5A and is more a solar charger only . Edited by fillm 2012-01-20
moose4621
Posted: 11:06pm 19 Jan 2012
  fillm said   Hi Moose ,
Thanks fillm. If you go to the CHRG---CINT-CEXT menu it displays external charge current greater than the load current. In other words, the shunt doesn't display a charge from an external source until the input exceeds the output. The input from the solar is CINT and therefore not displayed. Makes sense but is of little use for monitoring the wind turbine.
  fillm said   there is also the G-set or L-Set terminals that can be used to activate a solid state relay from memory but its been a while since I have played around with all the options
Can do great things with these terminals including switching water pumps, etc. As I said in another post, without the expansion board you can only do two things. In my case it's G-set generator control, and L-set Load control for wind. With the expansion board, you can do six functions.
I had all this down pat a few years ago but I haven't fiddled with the PL60 for ages and now I have to forget something, (like how I rewired the stator) to make room for a new memory.
moose4621
Posted: 09:13pm 20 Jan 2012
Has anyone tried geo222 blades with taper and helix?
Jarbar
Posted: 02:47am 21 Jan 2012
Hi moose4621,
in the original development of the extruded geo222 PVC blades a couple of customers bought sections of blades which as Glenn and I suggested may be theoretically set to different pitch angles along the length of the blade.As for tapering this was not possible using the extrusion process.
I have taken a a length of blade and cut it into 32mm slices that were then orientated at incremental angle/pitch changes from end to end.The advantage of the PVC was they could be glued into position but needed a spar through the full blade length for support.
Another potential added advantage was the turbucle effect that would cause a more laminar airflow across the blades surface.Which theoretically would enhance their power.Unfortunately another unfinished experiment.
Anthony.
moose4621
Posted: 05:00am 21 Jan 2012
  Jarbar said   Hi moose4621,
Anthony.
Hi Jarbar.
I was hoping someone has carved a set.
I am well aware that extruded blades cannot be twisted or tapered and as a result, can not set the length of the blade to a specific pitch or optimize it's lift according to it's radius. Therefore the blade has a different pitch at each station along the length of the blade.
As I am sure you are aware, the pitch of a blade is relevant to it's radius from centre of rotation and therefore the angle of incidence must change along the blade to maintain the same pitch.
I was interested to know if anyone had carved a set of blades to the GEO222 airfoil with taper and helix, or correct pitch along it's length and what the results were. While I can understand why the extruded blades start easily with such a course pitch at the tip and therefore lower angle of attack, I can also understand why these blades don't spin up as well as a others because of the relatively fine pitch and possible negative angle of attack near the root.
I'm certainly not knocking the extruded blades as I haven't even seen any in the flesh and certainly never tried them but they are obviously a compromise between performance and manufacturing process.
Just fishing for more info.
     Page 2 of 3
