Local Time 12:48 26 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : HELP needed: PIC32MX170 & MPLab IDE 8.90
vasi
Posted: 09:18am 10 Aug 2014
Peter, is not there an extra 0 in the device ID? Just asking, as there the number is bigger than the others.
Elvish name: Mablung Miriel
Beyound Arduino Lang
G8JCF
Posted: 09:57am 10 Aug 2014
@VASI
afaik, the device ID is a 32 bit number, and that number is what PICPROG.EXE reported back to me for the "MX170F256B-501/SP". I used that number, and PIC32PROG.EXE works so I didn't argue or think about it any more, I was more interested in getting my MX170F256B-501/SP working ! I did try and find the Dev Id for a "MX170F256B-501/SP" but couldn't.
AS I said previously, that Device ID worked for me, so I didn't bother investing any further more time and effort , and I now have a working '170F.
If you (@Vasi) could find/know/research/investigate the Device ID's for '170 chips that would be most helpful to us all.
Perhaps someone who understands Microchip Device IDs can explain/verify what the Device ID is for the "MX170F256B-501/SP", and. hopefully more generally where/how Microchip Device IDs are managed/made visible to us punters.
73
Peter
Edited by G8JCF 2014-08-12
The only Konstant is Change
Posted: 09:32am 11 Aug 2014
@G8JCF, will be getting the 170's hopefully in the next 3-4 days so will have a play and be in touch when I get 'stuck'
WW
Posted: 10:18am 11 Aug 2014
The ID I have for the 170F256B is 0x06610053
Looks to be a stray 2 in the earlier post (which will be ignored as it's a 32-bit item).
I got the values from the Flash Programming Spec. It has a lot of PIC32MZ ones, too.
G8JCF
Posted: 12:44pm 11 Aug 2014
@JohnS
Thanks for that info, I'll update target.c and try it out.
0x26610053 definitely works, but maybe PICProg masks out the top 4 bits because those are the silicon revision bits (I think).
BTW, I've managed to find 61145L.PDF from Microchip which includes MZ series as well as MX, but not unfortunately MX170's. So there must be a newer 61145X.PDF out there somewhere ?
Thanks, once again
Peter
G8JCF
Posted: 01:08pm 11 Aug 2014
Hi JohnS
Very many thanks for your info, it gave me the spur/clue to go digging around on Microchip's site and find the requisite document !
So here is PIC32PROG.EXE for PICKit2 with
{0x6610053, "MX170F256B", 256, &family_mx1},
{0x661A053, "MX170F256D", 256, &family_mx1},
added into target.c
When I run the new compiled PIC32PROG.EXE against my '170F, PIC32Prog reports
>pic32prog.exe
Programmer for Microchip PIC32 microcontrollers, Version 1.96M
Copyright: (C) 2011-2014 Serge Vakulenko
Adapter: PICkit2 Version 2.32.0
Processor: MX170F256B (id 26610053)
Flash memory: 256 kbytes
Boot memory: 3 kbytes
Configuration:
DEVCFG0 = 7ffffffb
3 Debugger disabled
0 JTAG disabled
18 Use PGC1/PGD1
DEVCFG1 = fc67cf59
1 Fast RC oscillator with divide-by-N and PLL
3 Primary oscillator: disabled
4 CLKO output disabled
0 Peripheral bus clock: SYSCLK / 1
8 Fail-safe clock monitor enabled
4 Clock switching enabled
DEVCFG2 = fff9ffd9
1 PLL divider: 1/2
5 PLL multiplier: 20x
7 USB PLL divider: 1/12
8 Disable USB PLL
1 PLL postscaler: 1/2
DEVCFG3 = cfffffff
USBID pin: controlled by port
4 USBID pin: controlled by USB
8 VBuson pin: controlled by USB
I've attached the new PIC32Prog.exe in case it's useful to someone.
Once again, very many thanks to @JohnS
73
Peter
2014-08-11_230509_pic32prog.zip
Posted: 10:52pm 11 Aug 2014
I'm not sure if you found it but the most recent doc looks to be:
here
If that C code uses a 32-bit value (maybe a type called u32) then using the old constant with that stray 2 ought to generate a compiler warning (at least) if you turn enough warning on. gcc is quite good (sometimes painfully so) at warning about apparent loss of bits.
JohnEdited by JohnS 2014-08-13
Posted: 12:15am 12 Aug 2014
@G8JCF. I am having no luck running either of your posted pic32prog attached files.
I am unzipping on a windows 7 (64-bit) laptop and when I run the file I get a quick dos window flash up and then disappear.
If I run as administrator it just sits on an hourglass (I then have to quit via Task Manager).
Please, what am I doing wrong??
Thanks for including the file as a downloadable with both 170's and 150's - and thanks too to for JohnS help
G8JCF
Posted: 01:58am 12 Aug 2014
@WW
You have to open up CMD.exe, then from the command line type PIC32PROG.exe. PIC32Prog.exe is a command line only utility.
OK ?
Peter
G8JCF
Posted: 02:02am 12 Aug 2014
PIC32PROG.EXE - Update
I got an email from Serge (pic32prog's author) this morning who said
I've added the needed ids for mx170/270 in revision r97 - it was easy fix.
Usually the build for Windows is the most complicated part.
I've found that Linux mingw32 cross-compiler is the most straightforward way to build Windows binaries.
Peter
vasi
Posted: 02:03am 12 Aug 2014
WW, probably libusb for windows has to be installed. Pickit2 has to be connected on USB and at your board. Pic32prog is a console application. For you to be able to read the application;s messages, you need to open a permanent console, inside where you navigate to the folder you have the hex file. Pic32prog has to be in a folder included in the PATH system variable.
Again, TotalCommander file manager can be very useful (you can launch cmd.exe from his command line in any folder you want). As an old programmer, you should be proficient with this stuff...
Posted: 02:12am 12 Aug 2014
  vasi said   WW, As an old programmer, you should be proficient with this stuff...
Appreciate your help vasi (but I'm not that old!!)
G8JCF
Posted: 11:52pm 12 Aug 2014
@WW
If you have installed a PICKit2 then PIC32Prog should work without further ado. All the driver(s) required should have been installed as part of installing the PICKit2.
73
Peter
