Local Time 23:40 24 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Help - Programming ASCII Terminal
Posted: 02:22pm 26 Dec 2014
Well done - glad it is now working.
Yes, that Vcap is mission-critical. It MUST be a good quality tantalum, or an X5R SMD ceramic, if you are designing for SMD. It would seem that the PIC32 core intensely dislikes bog-standard caps, which is probably a good thing anyway!
Posted: 04:02pm 26 Dec 2014
Hi Steve,
Glad it is all working for you..
I am fairly certain that firmware I sent is OK to use as I copied it out of a 250 that was flashed with v1.0 then updated via USB to 1.2.
I would use the one that has the bootloader as well when Geoff releases V1.2w B/Loader to be sure.
Geoffg
Posted: 12:29am 27 Dec 2014
I have finally got the latest firmware + bootloader out.
Check this post if you have not seen it already: http://www.thebackshed.com/forum/forum_posts.asp?TID=7290&PN =1
Geoff
