Local Time 21:09 24 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : ESP8266/Micromite/sending a log
centrex
Posted: 07:37pm 16 Jan 2015
Hi Jim
I just loaded the little terminal program into the uMite 170 and expected to be able to talk to the esp8266 via the chat window but no joy.
cliff
Cliff
Posted: 08:04pm 16 Jan 2015
OK. I found the program you were referring to.
Try this slightly modified version.
I have added the LF to each CR and put in a delay.
It is always good to have a delay in a loop until you are sure it's debugged.
OPEN "com1:115200" AS #1
DO
PRINT INPUT$(1,#1);
k$ = INKEY$
IF k$=CHR$(13) THEN k$=CHR$(13)+CHR$(10)
PRINT #1, k$;
PAUSE 50
LOOP
You might have to change the baud rate.
centrex
Posted: 08:12pm 16 Jan 2015
Fantastic works like charm.
Now to see what else I can do with it then find a use.
cliff
Cliff
