Local Time 20:18 24 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MM2: Fun with fonts
Zonker
Posted: 01:06am 03 Feb 2015
Thanks Matherp...
I will give it a try when I get home from work this afternoon...
twofingers
Posted: 02:54am 03 Feb 2015
Hi WW,
  Quote  1> What software from matherp are you running?
2015-01-16_152147_ILI9341SPI.zip
ILI9341touchdemo.bas
ILI9341calibratetouch.bas
  Quote  Is it definitely the correct touch controller?
I don't know! I even doubt if it is equipped with an controller.
Maybe is is the missing U1 (right of "240X320", yellow arrow)?
  Quote  2> Exactly what module are you running? (Sorry if previously mentioned)
see picture!
  Quote  Finally, do you have a second module to try? This is mentioned just in case you have a faulty one (not that cheap Chinese modules are ever faulty
I have only one module to try.
I think it may be the missing touch controller (U1).
Thank you for pushing me to take a second look at the module!
Upps:
I looked again at the auction: Type: without touch panel
My fault! *grmpf*
Michael Edited by twofingers 2015-02-04
The lone and ...
Posted: 03:38am 03 Feb 2015
I can confirm that is your issue!! Oh well, at least we know why
twofingers
Posted: 04:33am 03 Feb 2015
@WW
  Quote  Oh well, at least we know why
YES! That's most important. Makes a good feeling. I ordered already new modules with touch controller!
The lone and ...
Zonker
Posted: 12:58pm 03 Feb 2015
@Matherp
Looks like putting a 4.7k on the display reset line solved the problem of display de-init... I have the 1.8" connected to the DIP-600-28 board happily updating the RTC time on a tick Int.. (sweet)... Testing (playing) continues... Also, will be hooking up the monochrome (blue) 3.2" display you had shown in another thread. As much as I tried to get the exact one you did, now that I'm looking at it, there are slight differences on the PCB... The "12864B" number is the same but, this one sports a "V2.0" on the hard etch... I didn't find any 0 ohm resistors... There is a solder blob jumper that has "S" and "P" next to it, I assume that stands for Serial and Parallel... We will see how it works next...
