Local Time 07:33 24 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MM+ End Sub
Posted: 09:22pm 22 Aug 2015
Paul,
In your code your interrupt is branching to a label instead of a subroutine.
It is difficult to give the 'best' solution because is depends a lot on what else you are doing.
Here I simple switch between 2 screens One with a button and one blank.
I don't bother testing to see which button was pressed and pressing the blank screen still triggers the interrupt.
GUI INTERRUPT CHOOSE
START:
ScreenOn
DO
IF chosen = 1 THEN ' we have triggered the touch
SELECT CASE activeScreen
CASE 1 ' main screen
ScreenOff
CASE 0 ' blank screen
ScreenOn
END SELECT
chosen = 0 ' we only want to respond to the touch once
ENDIF
LOOP
SUB ScreenOn
activeScreen = 1 ' record which screen is active
GUI BUTTON #1, "SELECT",50,100,185,40,RGB(Black),RGB(Green)
END SUB
SUB ScreenOff
activeScreen = 0
GUI DELETE #1
CLS
END SUB
SUB CHOOSE
chosen = 1 ' all we do in the subroutine is set a flag
END SUB
palcal
Posted: 09:48pm 22 Aug 2015
Thanks Jim that works but I have to touch the blank screen (with no button)
to return to the main screen. I want to return after after a pause of so many seconds.
But leave it with me to fiddle with I will learn more working it out myself. If I fail I will post back.
Thanks Paul.
Posted: 10:11pm 22 Aug 2015
A hint:
After calling screenOff in the main loop
do your pause 2000 then call ScreenOn
That way you return to the main screen after the delay or sooner if you tap the blank screen.
palcal
Posted: 12:02am 23 Aug 2015
Thanks Jim I already have it working as I want, I have edited the code in my project and it all works great.
Thanks for your help.
Paul.
palcal
Posted: 05:38pm 23 Aug 2015
re GUI BUTTON
Well I thought all was OK but on doing some more tests this morning things went rather awry. Everything worked OK for a few touches then funny things started happening.
Sometimes the TIME would not be displayed the location instead of reading MYSTIC SANDS would read ELLOW, when I touched the buttons the text in the button would disappear and be replaced with random text. When I checked the value of the variables eg. The location MYSTIC SANDS which is set at the start of the program and never changes I found the value had somehow changed to ELLOW.
So all I did was get rid of the GUI BUTTONS and replace them with RBOX with text inside it. NOW ALL IS PERFECT.
That is the way it is staying, I will have a look at GUI BUTTON again someday but for now I have had enough.
Paul.
Edit. It occurred to me that since the problem did not occur until the Buttons had been touched a couple of times, has it got something to do with the chip running out of memory. Whatever happened it was rather catastrophic.Edited by palcal 2015-08-25
