Local Time 02:39 24 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Low power audio Amp required for MM
Posted: 10:52pm 28 Oct 2015
  Grogster said   75mA is not much current to play with, Mr. Wizzard. .. I do like the adafruit unit though, and if you did not drive it's output very hard, you could probably do it all within 75mA or so - you'd have to try it and see.
I have a stereo module to try and play with (can't remember where I put it though). Will see how 'quiet' it is when restricting it to 75mA's.
I am trying to make a kids 'toy' that asks questions (thinking of each question being a MP3 file). So need it clear enough to be heard when held in hands (i.e. a short distance only). I am not building a nightclub (which is where your amp comes in )!!
Chris Roper
Posted: 10:59pm 28 Oct 2015
  WhiteWizzard said  I am trying to make a kids 'toy' that asks questions (thinking of each question being a MP3 file).
Then why not design it to drive a pair of earbuds, that can be quite loud on low power, and the kids parents my appreciate it too...
You could then plug in a pair of powered PC speakers if you needed the whole room to listen in.
Chris
http://caroper.blogspot.com/
Posted: 11:08pm 28 Oct 2015
  Chris Roper said   . . . why not design it to drive a pair of earbuds, that can be quite loud on low power, and the kids parents my appreciate it too...
That was my initial plan; but there will be groups of two/three/four kids at a single 'toy' so they all need to hear it.
Mobile phone 'amp/speakers' can't draw too much power surely???
WW
Posted: 12:05am 29 Oct 2015
Some tiny speakers are here.
Cheap too.
This mono SOIC amp with DC volume control might be useful for your purposes.
This amp is cheap and simple, but does need a DC control voltage for the volume control. This could possibly be via a PWM output and RC filter?
Chris Roper
Posted: 01:50am 29 Oct 2015
  WhiteWizzard said  Mobile phone 'amp/speakers' can't draw too much power surely???
I have never worked with the audio component of a phone but have used Cellular Modules in a couple of projects and the Battery/PSU had to be expected to supply a minimum of 2A at 3V to support the Cellular Components. So a Cell phone has the capacity to supply a lot more power than 75ma to its audio subsystem.
Not sure if they do but the capacity is certainly there.
Chris
Posted: 02:56am 29 Oct 2015
  Chris Roper said   . . . the Battery/PSU had to be expected to supply a minimum of 2A at 3V to support the Cellular Components. So a Cell phone has the capacity to supply a lot more power than 75ma to its audio subsystem.
A GSM modem can draw up to 2A when first powered up and it is seeking a network - hence why they need that capacity. However, in standby (and once locked onto a network) they draw considerably less (typically under 100mA in standby).
The screen/backlight draws the most power inside a phone. All other components (apart from amp) typically draw microamps (things such as compass, proximity sense, capacitive touch-screen sense).
Low-cost greetings cards that incorporate sound/speech play it through a thin piezo element. Only thing is that they are 'samples' sounds and this is not a practical approach for what I need.
Will spend the evening on Google to see what is being used in tablets & phones.
WW
CircuitGizmos
Posted: 05:36am 29 Oct 2015
  HankR said
  viscomjim said   It uses the MP3TF16P unit. Serial comms.
Thank you Jim.
Just doing a quick search on this item (not the entire CG board), I'm getting a clear impression that the audio amp has no uC control, only the wave player IC on the MP3TF16.
That page shows a little MMbasic library with volume control commands.
HankR
Posted: 04:21pm 29 Oct 2015
  CircuitGizmos said
Thank you Jim.
CG,
Are you speaking about your CG page? That's not the page I was looking at. I was looking at a Chinese page which indicates that the IC on the MP3TF16P module which is under uC control is the DA/Codec IC, not the audio amp IC.
Therefore even hacking into the MP3TF16 module would not produce access to a uC controlled audio IC that would accept analog audio in.
Hank
