Local Time 23:43 23 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Problem with MM+ matematics
Posted: 09:31am 14 Dec 2015
It doesn't fit in a 64-bit integer, whose max is around
18,446,744,073,709,551,615 (2^64-1, using unsigned)
i.e. about 1E19
At a guess the value you posted is the bottom 64 or 63 bits of the correct number (i.e. mod 64-bits).
JohnEdited by JohnS 2015-12-15
Posted: 09:33am 14 Dec 2015
(7^7)^7 = 2.5692357752105887808861147722424e+41
7^(7^7) = 823543
7^7^7 without brackets causes as much discussion as the Paris Climate Change meeting without any consensus.
Most calculators work from left to right so will give the first answer.
A lot of programming languages will resolve power from right to left resulting in the second answer.
Posted: 09:35am 14 Dec 2015
Jim,
Something wrong with your calculation of that 2nd one!!
7^7 = 823543
I can post the correct value if anyone wants a BIG post (695975 digits)...
E.g. it's the output from
echo '7^(7^7)' | bc
its length is
echo '7^(7^7)' | bc | tr -c -d '[0-9]' | wc -c
(which grabs just the digits and counts them)
Posted: 09:53am 14 Dec 2015
You are right.
Excel correctly gives an error for 7^(7^7) but MS calculator gave 823543.
Excel and VB also differ in the order they treat Power operators.
Negative numbers also suffer from the lack of a clear order.
-2^2 can be treated as (-2)^2 = 4 or -(2^2) = -4
Posted: 09:56am 14 Dec 2015
BTW, what is a "matematic"? (see title of thread)
Posted: 09:58am 14 Dec 2015
Each programming language should (as far as I know: always does) define the order.
But it's wise to use parentheses :)
kiiid
Posted: 10:15am 14 Dec 2015
  Grogster said   BTW, what is a "matematic"? (see title of thread)
Hey, that was uncalled for
A small typo on top of my secondary English... But still goes well as "science for mates"
http://rittle.org
Posted: 10:21am 14 Dec 2015
'Floating' spelling!
Just out of interest; PRINT 7^(7^7) generates -3,568,518,334,133,427,593
Don't think we've seen that number mentioned here yet!
isochronic
Posted: 09:26pm 14 Dec 2015
I tried the equivalent in electride, eg
a = 7.0 ** ( 7.0 ** 7.0 )
or
a = 7 ** ( 7 ** 7 )
etc
floating point ( single and double ) return "+Inf" which
is microchips positive-infinite symbol.
integer (32 bit) returns a large integer which I guess is
the remainder 32 bits.
ed - that should be "mithimetecs" which is used for
counting sheep in NZ Edited by chronic 2015-12-16
Posted: 11:00pm 14 Dec 2015
No offence, kiiid. I was just poking fun at the typo is all.
