Local Time 01:12 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CFunctions - learning by example (4)
Geoffg
Posted: 05:18pm 08 Jul 2017
  twofingers said  Can I call a MMBasic function from within a Cfunction?
Yes, use the RunBasicSub(string) function defined in CFunctions.h
The argument to RunBasicSub is a string specifying the name of the user defined BASIC subroutine to be executed. It MUST be terminated with TWO null chars.
Typical C code:
char s[5];
s[0] ='F'; s[1] ='o'; s[2] ='o'; s[3] = 0; s[4] = 0;
RunBasicSub(s);
Corresponding BASIC function:
SUB Foo
PRINT "Hello World from a CFunction"
END SUB
GeoffEdited by Geoffg 2017-07-10
twofingers
Posted: 03:10am 09 Jul 2017
Hi Geoff,
Thanks a lot for your quick response!
Unfortunately the CFunctions.h is poor documented. (Not a criticism!)
Peters useful documentation "Brief overview of all of the facilities in Cfunctions.h" (released 27. February 2016) is unfortunately somehow outdated.
Undocumented in Cfunctions.h:
#define GetTouchAxisVector (*(unsigned int *)Vector_GetTouchAxis)
#define GetTouchAxis ((int (*)(int)) (*(unsigned int *)GetTouchAxisVector)) (a)
// NOTE: The argument to RunBasicSub is a string specifying the name of the BASIC subroutine to be executed.
// It MUST be terminated with TWO null chars.
#define RunBasicSub(a) ((void (*)(char *)) Vector_ExecuteProgram) (a)
#define SaveProgramToFlash(a,b) ((void (*)(char *, int)) Vector_SaveProgramToFlash) (a,b)
#define error(a) ((void (*)(char *)) Vector_error) (a)
#define ProgFlash ((int *) Vector_ProgFlash)
#define ClearProgram() ((void (*)(void)) Vector_ClearProgram) ()
#define llist(a,b) ((char * (*)(char *, char *)) Vector_llist) (a,b)
#define CFuncInt2 (*(unsigned int *) Vector_CFuncInt2)
Maybe it would be useful to include the (updated) documentation in your MMBasic distribution?
  Geoffg said  The argument to RunBasicSub is a string specifying the name of the user defined BASIC subroutine to be executed. It MUST be terminated with TWO null chars.
Typical C code:
char s[5];
RunBasicSub(s);
SUB Foo
END SUB
Geoff
Just out of curiosity: Is there also a way to pass arguments?
MichaelEdited by twofingers 2017-07-10
The lone and ...
Posted: 05:14am 09 Jul 2017
  Quote  Just out of curiosity: Is there also a way to pass arguments?
You don't need to:
Set up a normal Basic variable with Global scope
Pass it to the Cfunction
manipulate it in the CFunction as required
Call the MMBasic function which has by definition got access to the Basic variable
twofingers
Posted: 05:21am 09 Jul 2017
Thanks Peter!
Sometimes the things can be so simple!
Michael
The lone and ...
crez
Posted: 07:55pm 26 Oct 2017
Further back in this thread someone sorted out a problem by switching to xc32 compiler version 1.33. I can not find this for download from microchip, only 1.44. I am getting the same sort of error. Where do I go from here? My entry into C functions has not been smooth so far!
DavidEdited by crez 2017-10-28
Posted: 08:56pm 26 Oct 2017
Maybe here
crez
Posted: 01:47am 27 Oct 2017
Thanks John, I'm back on track (for the moment )
