Local Time 04:24 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : get week day function memory issue?
GoodToGo!
Posted: 12:34am 04 Aug 2017
  MicroBlocks said   I posted this in Januari 2014 and i have been using it since the GWBasic days on the PC, so it should be time tested.
I use it often in programs as one of those handy to have functions.
It is a bit cryptic, but it is small and FAST. :)
[code]
function DayOfWeek(year, month, day)
  a = int((14-month)/12)
  m = month + 12*a - 2
  y = year - a
  DayOfWeek = (day + y + int(y/4)-int(y/100)+int(y/400)+int(31*m/12)) mod 7
end function
[/code]
Hey Microblocks, is it ok to modify your routine to eliminate the many "int's" and use "\" instead? Or in other words:-
[code]
  a = ((14-month)\12)
  y = year - a
  DayOfWeek = (day + y + (y\4)-(y\100)+(y\400)+(31*m\12)) mod 7
end function
[/code]
Although I guess now looking at it, it's a case of '6 of one, half a dozen of the other'......
GTG!
MicroBlocks
Posted: 12:54am 04 Aug 2017
It still swaps strings around though and that depending on the size of the strings can cost time. It uses a lot of overhead in that case.
The way to solve that is to create another array with integers, fill them with the numbers from 0-number of elements. Then each time you need to swap a string, you swap the integers instead. This is a lot faster but is only worthwhile when using larger arrays.
Depending on the data and on how the interpreter handles the data internally it can make a huge difference. Only a test will tell.
CaptainBoing
Posted: 12:55am 04 Aug 2017
I played with this but even with a 5MHz clock, the time difference was negligible so I left them to remain faithful to the original.
timer=0
x=dayofweek(2017,8,4)
? timer,x
timer=0
x=dow(2017,8,4)
? timer,x
Function DayOfWeek(year, month, day)
y = year - a
End Function
Function Dow(year As integer, month As integer, day As integer) As integer
local integer a,m,y
a = (14-month)\12
y = year - a
Dow = (day + y + (y\4)-(y\100)+(y\400)+Int(31*m/12)) Mod 7
End Function
Edited by CaptainBoing 2017-08-05
Posted: 12:59am 04 Aug 2017
  MicroBlocks said  I think Grogster uses it also (see his post) and maybe he can confirm it works good. I only tested it for current dates, and in that case it works perfectly.
Confirmed. No problems to report. Works correctly with any date I throw at it.
MicroBlocks
Posted: 01:25am 04 Aug 2017
Personal preference is to use int() instead of the \.
I just find it more readable.
In C# and Javascript which i use most it is optimized away by the compiler anyway.
In Basic the INT() is tokenised so also not much gain.
The brackets also neatly and clearly show which value is used. When having a expression within those brackets it is clear that the INT is done over the result of that expression. In the example you can see that clearly, the INT(31*m/12) is more difficult to replace as you will need to consider the precedence of the operators.
I also never use i++ but instead use i = i + 1;
Also a+=1 or a*=5 etc i write as it is done in Basic.
Much clearer and less chance for mistakes.
Also keeps he syntax mostly the same in Basic, C/C#, Javascript.
Again compilers/JIT optimize it.
Edited by MicroBlocks 2017-08-05
CaptainBoing
Posted: 01:46am 04 Aug 2017
heh. you noticed that
