Local Time 16:45 22 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Pir sensor not working
Posted: 04:34am 18 Feb 2017
Code for flashing LED when motion detected (non interrupt driven).
OPTION EXPLICIT
CONST PIRLED=1:SETPIN PIRLED,DOUT
PIN(PIRLED)=0 'ensure LED off to start with
CONST PIRPIN=2: SETPIN PIRPIN,DIN,PULLDOWN
'PROGRAM START
DO
DO WHILE PIRPIN=0:LOOP ' endless loop while no motion (i.e. PIR input LOW)
DO WHILE PIRPIN=1 ' if here then see if motion is still detected
PIN(PIRLED)=1 ' LED on
PAUSE 200 ' but only briefly
PIN(PIRLED)=0 ' before turning LED OFF again
PAUSE 200 ' bit more of a delay (so LED can Flash if movement still occurring)
LOOP ' see if still moving i.e. PIRPIN=1
LOOP ' if no movement (i.e. PIRPIN=0) - then go back to wait for next movement
END
Edited by WhiteWizzard 2017-02-19
rallyman
Posted: 05:19am 18 Feb 2017
here is the new setup:
on the left is the arduino panel, power via usb2 from a usb hub. (hub has its own 220V feed)
I get the 5V and GRND from the arduino panel.
I use the PIC only to get the PIR out and handle it and switch the led if needed.
Now it works fine.
My code is
OPTION EXPLICIT
CONST PIRLED=4:SETPIN PIRLED,DOUT
CONST PIRPIN=5
SETPIN PIRPIN,INTH,ALERT,PULLDOWN
DIM SIGN=0
'PROGRAM START
DO
PIN(PIRLED)=0
DO WHILE SIGN=0
LOOP
MOTIONACTION
SIGN=0
LOOP
SUB ALERT
SIGN=1
END SUB
SUB MOTIONACTION
PRINT "MOTION DETECTED!"
PIN(PIRLED)=1
PAUSE 1000
PIN(PIRLED)=0
END SUB
END
I will try your code WhiteWizard after a fast lunch
rallyman
Posted: 05:39am 18 Feb 2017
WhiteWizzard, your code working also fine, many thanks!
meantime I changed the arduino panel to a 9V battery as the power source for the led and the pir and still working fine.
CaptainBoing
Posted: 11:47am 18 Feb 2017
  rallyman said
1) my sensor is default H
That link does nothing to the output (it is always active HI)
The link is connected to pin 1 of the BISS001 and that states whether the PIR is re-triggerable or not.
With it dragged HI, the device is re-trigerable. This means that if it sees more movement while triggered, the timer is reset to zero - i.e. keep moving and it will always be active and the output HI pulse is "stretched".
With it LO, the device will only ever be triggered for the set time and the output will go LO after it expires - if you are still moving, it will immediately trigger HI gain, but you will see a brief LO pulse on the output (between the two triggers).
hth
h
Edited by CaptainBoing 2017-02-19
