Local Time 22:43 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMBasic for Windows - betas
     Page 20 of 30
panky
Posted: 05:13am 24 Apr 2023
I think disco4now is right on the money. You can not sensibly use the PRINT statement when OPTION Y_AXIS UP is set. If you need to place text, then use TEXT. The manual says for use with drawing commands and I have amended the manual accordingly.
Doug.
JanVolk
Posted: 06:55pm 25 Apr 2023
Good day
I am exploring the latest version of MMB4W, now that I have a manual in my hands.
I run into a problem with a standard keyboard where a certain key does not respond and tested with UK and US keyboard in option keyboard.
It is the \ key or the | -key (shift + \) which works with all my other programs, but not with MMB4W. Before I dig further, I wanted to know if anyone else has this problem?
Jan
toml_12953
Posted: 07:18pm 25 Apr 2023
  JanVolk said  Good day
Jan
Both of those keys work for me. The \ gives me integer division.
I use b16 running on Windows 11 with a US keyboard.
Tom L
Edited 2023-04-26 05:19 by toml_12953
LucV
Posted: 07:31pm 25 Apr 2023
No problem on my side either.
MMBasic V5.07.03
| / \ all work.
Option keyboard US
Luc's tech Blog
JanVolk
Posted: 08:08pm 25 Apr 2023
Gentlemen,
Thank you for responding. The problem has become a bit clearer. I have been using a separate Logitech keyboard and mouse for a while and now I see that this key appears twice on my keyboard.
You guessed it one works and the other doesn't. The one that doesn't work is to the left of the Z key and to the right of the Shift key and the one that works is to the left of the Enter key and to the right of the ' key.
The key on my laptop also works, but I never use this keyboard and with a separate screen and separate keyboard and mouse, the laptop is always closed. Now that I know all this I can move forward.
Nice day.
Jan
panky
Posted: 11:38pm 26 Apr 2023
Update to the Windows for MMBasic User Manual - tidied up a bit and corrected some errors. I have not had a lot of feedback on errors so I can only assume it is relatively correct
MMB4W User Manual v0.86
For info, there are two versions of the User Manual:-
MMBasic for Windows v0.86odt-cond.pdf
 - this is a smaller sized version that only has page thumbnails to navigate by
and
MMB4W_User_Manual_v0.86.pdf
 - large version with bookmarks to all options/command/functions etc.
Content of both is identical - its just the navigation option that is different.
Enjoy, Doug.
Edited 2023-04-27 09:39 by panky
disco4now
Posted: 11:45pm 26 Apr 2023
hi Doug,
I think the link is not correct. For me it goes to my dropbox.
<a href="https://www.dropbox.com/home/MMB4W" target="_blank">MMB4W User Manual v0.86</a>
gerry
F4 H7FotSF4xGT
panky
Posted: 12:06am 27 Apr 2023
Try
Manual without bookmarks
and
Manual with bookmarks (big)
D.
Posted: 12:15am 27 Apr 2023
Thanks very much for your good work here.
Turbo46
Thanks Doug,
Sorry but one little point but it would be nice to have different footers for odd and even pages so that double sided and bound manuals could have the page number on the outer edge of the page.
Bill
Turbo46
Posted: 02:40am 27 Apr 2023
There is one funny thing: the version with the bookmarks has an extra blank page at page 106 which makes the index incorrect.
Bill
Turbo46
Posted: 04:31am 27 Apr 2023
Hi Doug,
I've started printing the manual a few pages at a time waiting for my printer to run out of ink and have found a few more 'funny' things:
Page 10. Under the heading :Differences to the Micromite version of MMBasic. The first line begins:
"Off all the different versions of MMBasic..."
Off should be Of
Also on page 10, in the table of Valid Default modes: the first three entries are shifted to the right. By an extra tab stop I assume.
Page 11, the last line on that page reads:
"red and blue are reversed compared to the CMM2 if a direct numerical value is used in this way i.e ABRG8888"
Should that read ARGB8888?
Page 14, the part:
Then type in this short program:
DO
r = RND * 255
 g = RND * 255
b = RND * 255
CIRCLE RND * 800, RND * 600, RND * 100,,, 0, RGB(r,g,b)
PAUSE 10
LOOP
The line "g = RND * 255" is not bold like the rest of the listing and is in a different font.
Also, I'd like to suggest that, for program listings, you do the same as Geoff: indent them and use a Courier font. It looks more like a computer printout (to me).
Also on page 14, near the bottom, the line:
"see the bubbles. To see how fast MMBasic for Windows can really go ,you could go back into the editor and"
The comma is in the wrong place.
Bill
panky
Posted: 04:38am 27 Apr 2023
Cheers Bill, Second one fixed, first suggestion being worked on,
Doug.
Turbo46
Posted: 04:46am 27 Apr 2023
Thanks Doug, Great job by the way.
One thing about line numbers: While you CAN use them in MMBasic, they are not respected in the way the early BASICs did.
Try:
15 print "LINE 15"
10 print "LINE 10"
20 print "LINE 20"
15 print "LINE 15 too"
end
The LINEs will be processed in the order that they are typed, LINE 15 is not inserted between LINEs 10 and 20 and two LINE 15s are OK.
Bill
panky
Posted: 05:41am 27 Apr 2023
Hi Bill,
Thanks for the great feedback - responses below
  Turbo46 said  Hi Doug,
Off should be Of
** fixed
** fixed
No, see the write up - when using numerical values, blue and red are swapped in position.
Page 14, the part:
DO
r = RND * 255
 g = RND * 255
b = RND * 255
PAUSE 10
LOOP
** fixed
** changed to Courier New and set in but I like the pale background differentiating code from other text (unless I get objection from Geoff/Peter)
** fixed
Bill
Regards, your other request for odd/even gutters - work in progress.
Will try and upload revised version later tonight/tomorrow.
Doug.
Geoffg
Posted: 06:03am 27 Apr 2023
  Quote  I like the pale background differentiating code from other text (unless I get objection from Geoff/Peter)
No objection from me.  In fact I like it so much that I am looking at adopting it for the future.
Geoff
Turbo46
Posted: 07:45am 27 Apr 2023
Reading more:
P17, near top, the paragraph:
"The filename is now mandatory as on MMBasic for Windows. You can now paste into AUTOSAVE using CTRL-V. When you exit AUTOSAVE with F1 or CTRL-Z. the file is saved and the program is loaded ready to..." My bolding.
Should that be: "for the CMM2"?
P17, down further, the paragraph:
"The running program is normally held in memory. This means that it will not be lost if the MMBasic for Windows is closed or the computer powered off."
This doesn't see correct. do you mean "The running program is normally held on the hard drive"? or "This means that it will be lost"?
p18,
Watchdog Timer
It is possible to use MMBasic for Windows set up so that...
Replace 'use' with 'have'?
P19, near the bottom:
"Note: you can also enter selection mode when using a USB keyboard by holding the
shift key and pressing right-arrow or down-arrow."
Is this statement valid for a windows computer? My laptop claims to have a "PC/AT Enhanced PS/2 Keyboard" and this method of selection works.
P21, "This setting is saved in non-volatile memory and automatically applied on startup."
Actually the setting is saved in an 'options.' file. Mine is saved in my Documents folder and I don't know if that can be changed.
P26, Passing Arguments by value
This has never been properly explained in any manual that I can recall so thanks for trying to clear it up.
While I understand the concept I feel the example doesn't really make it clear. The use of a LOCAL is clear and should be easily understood. The earlier swap sub clearly shows passing by reference and is probably all that is needed for that. Personally I have never used the passing by value method and after reading the manual I am not much more clear on the subject. Does:
testsub(a, b)
pass both a and b by value or reference?
What about:
testsub((a), (b))
I guess that does
but what about passing a single variable by value
testsub(a)
or does it have to be
testsub((a))
Easy enough to try and I will tomorrow
I'm done for the night, off to buy a blue ink cartridge,
Bill
Turbo46
Posted: 09:25pm 27 Apr 2023
Hi Doug,
Still worried about passing by reference or value so I wrote a little test program:
' VRtest.bas
' An MMBasic to test and demonstrate passing
' arguments to a subroutine by reference
' or value
print " Test 1."
a=4
b=4
testsub((a),b) ' Passes a by value, b by reference
print a,b
print
print " Test 2."
a=4
b=4
testsub((a),(b)) ' Passes a and b by value
print a,b
print
print " Test 3."
a=4
b=4
testsub(a),(b) ' Passes a by reference, b NOT passed
print a,b
print
print " Test 4."
a=4
b=4
testsub(a),b ' Passes a by reference, b NOT passed
print a,b
print
print " Test 5."
a=4
b=4
testsub a,(b) ' Passes a by reference, b by value
print a,b
print
print " Test 6."
a=4
b=4
testsub a,b ' Passes a and b by reference
print a,b
print
print " Test 7."
a=4
b=4
testsub(a,b) ' Passes a and b by reference
print a,b
print
print " Test 8."
a=4
b=4
testsub(a+b,b) ' Passes a+b by value and b by reference
print a,b
print
print " Test 9."
a=4
b=4
testsub a+b,b ' Passes a+b by value and b by reference
print a,b
print
sub testsub(arg1,arg2)
arg1=arg1+1
arg2=arg2+1
print arg1, arg2
end sub
It seems to me that, if passing arguments by reference, you can enclose the whole list of arguments in brackets or not (tests 6 and 7).
If you want to pass any arguments by value then each argument that you want to pass by value must be enclosed in brackets and the the whole argument list MUST be enclosed in brackets. An expression (like a+b) will be passed by value and does not need to be enclosed in brackets (test 8 and 9)
MMBasic seems to take an ending bracket ')' as the end of the list of arguments so if the argument enclosed in brackets is the last one then all the arguments will be passed to the subroutine but if it is not the last argument in the list, the rest of the list will not be passed (tests 3, 4 and 5). I think it best to have a blanket rule that - when passing any argument by value then the whole list should be enclosed in brackets.
Maybe good programming practice to always enclose the whole argument list in brackets.
Programmers may like to comment?
Bill
Posted: 10:02pm 27 Apr 2023
MY preference is and will remain, assume passing by reference and don't change the parameter withing the sub unless that is what you really want.
The other way to 'trick' the interpreter is to use things like
testsub a*1, b*1
or testsub a+0, b+0
etc
instead of brackets.
There is more than one way to skin a cat but in this case, I think the cat would prefer to keep it's skin on.
Posted: 10:26pm 27 Apr 2023
I agree with Jim. If you are using any of those tricks to force pass by value semantics then I suggest renewing your prescription for dried frog pills.
     Page 20 of 30
