Local Time 15:30 11 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite V6.00.01 release candidates - please test thoroughly
     Page 20 of 23
Posted: 10:45am 22 Dec 2024
Harm
Please check this
PicoMite.zip
twofingers
Posted: 11:19am 22 Dec 2024
Hi Peter,
I think there is a problem with "Autosave append" and the heap memory.
If I cancel "autosave append" with CTRL-C, I only have 3328k heap memory instead of 183kB. Only after a "NEW" do I have 183KB again
> memory
Program:
  3K ( 1%) Program (162 lines)
177K (99%) Free
Saved Variables:
 16K (100%) Free
RAM:
  0K ( 0%) 0 Variables
  0K ( 0%) General
228K (100%) Free
> ? mm.info(heap)
183808
> autosave append
> ? mm.info(heap)
3328
> memory
Program:
177K (99%) Free
Saved Variables:
 16K (100%) Free
RAM:
176K (77%) General
 52K (23%) Free
> new
> ? mm.info(heap)
183808
> autosave append
> ? mm.info(heap)
3328
> autosave append
Error : Not enough Heap memory
I think this is a low priority issue. I just wanted you to know about it.
If you don't know the reason and the problem suddenly occurs, it's confusing.
Michael
Edited 2024-12-22 21:25 by twofingers
The lone and ...
Posted: 12:21pm 22 Dec 2024
Michael: thanks for the report - easily fixed
Note to Harm
BAD
If MM.Device$ = "PicoMiteVGA" Then
GOOD
if instr(MM.Device$, "PicoMiteVGA") Then
Edited 2024-12-22 22:23 by matherp
homa
Posted: 02:21pm 22 Dec 2024
> option list
PicoMiteHDMI MMBasic USB RP2350A Edition V6.00.01RC9
OPTION SYSTEM I2C GP20,GP21
OPTION FLASH SIZE 4194304
OPTION COLOURCODE ON
OPTION KEYBOARD GR
OPTION CPUSPEED (KHz) 315000
OPTION DISPLAY 30, 53
OPTION SDCARD GP22, GP26, GP27, GP28
OPTION AUDIO GP10,GP11', ON PWM CHANNEL 5
OPTION RTC AUTO ENABLE
OPTION MODBUFF ENABLE  192
OPTION PLATFORM HDMIUSB
> files
A:/
  <DIR>  .
  <DIR>  ..
15:12 22-12-2024      19340  book.txt
14:44 22-12-2024          4  bootcount
14:57 22-12-2024      22542  fm.bas
15:12 22-12-2024      38216  picochess4.bas
15:12 22-12-2024      28854  small.bmp
2 directories, 5 files, 2260992 bytes free
> Sprite Loadbmp 1, "small.bmp",x,y,18,18
Error : Could not find the file
Is this possibly a bug?
I have added .bmp, I have copied it to "a:" and I have also tried 'a:small.bmp' and 'a:/small.bmp'...
I came across this in ‘picochess4.bas’.
Matthias
Posted: 03:30pm 22 Dec 2024
bug - will fix
Posted: 04:33pm 22 Dec 2024
V6.00.01RC10
PicoMiteRP2040V6.00.01RC10.zip
PicoMiteRP2350V6.00.01RC10.zip
Please, please if reporting any issues specify the exact version used and list all options set
Bug fixes
Bug in SPRITE LOADBMP not finding the file
Memory leak when AUTOSAVE APPEND is exited with Ctrl-C
Crashes in WebMite2040 caused by system heap being exceeded (in since 5.09)
Bug in VGA RP2040 caused by system/firmware memory overrun
Modifications
Tweaks the PSRAM timings to allow 372MHz operation of Pimoroni boards with RP2350B and 8Mb PSRAM. This enables 1280P resolution with a RP2350B running HDMI firmware
New functionality
LONGSTRING AES128 ENCRYPT/DECRYPT CBC/ECB/CTR key$/key[!/%](), in%(), out%() [,iv$/iv[!/%]()]
Encrypts or decrypts the longstring in in%() putting the answer in out%()
For CBC and CTR modes the encryption will generate a random initialisation vector and prepend out%() with the IV. If an explicit IV is specified this will be used instead of the random vector and this will be prepended to out%()
For CBC and CTR decryption the firmware assumes that the first 16 bytes of in%() are the initialisation vector.
In the case where you want to transmit a message without IV you can use LONGSTRING RIGHT to remove the IV before sending the message. In this case the recipient must know the IV as well as the key and create a complete longstring before using DECRYPT. This can be done by using LONGSTRING CONCAT to add the incoming message to a longstring containing the IV.
LONGSTRING BASE64 ENCODE/DECODE in%(), out%()
This BASE64 encodes or decodes the longstring in in%() placing the answer in out%(). The array used as the output must be big enough relative to the input and the direction. Encoding increases length by 4/3 and decoding decreases it by 3/4
Function
MATH(BASE64 ENCODE/DECODE in$/in(), out$/out())
Returns the length of out$/out(). This base64 encodes or decodes the data in 'in' and puts the result in 'out'. Where arrays are used as the output they must be big enough relative to the input and the direction. Encryption increases length by 4/3 and decryption decreases it by 3/4
Command
MATH AES128 ENCRYPT/DECRYPT CBC/ECB/CTR key$/key(), in$/in(), out$/out() [,iv$/iv()
This command encrypts or decrypts the data in 'in' and puts the answer in 'out' using the AES128 encryption method specified
The parameters can each be either a string, integer array, or float array with any mix possible
The key must be 16 elements long (16*8=128bits)
in and out must be a multiple of 16 elements long.
In the case of out being specified as a string (e.g. out$), the string variable must exist and should be set to empty (DIM out$="")
The maximum number of elements in 'in' and 'out' is limited by memory when defined as arrays. Strings for encrypting are limited to 240bytes (EBR) and 224bytes (CTR and CBC).
For CBC and CTR encryption you can optionally specify an initialisation vector 'iv'. 'iv' must be 16 elements long (16*8=128bits). If an initialisation vector is not specified encryption will generate a random initialisation vector.
In both cases the output is prepended with the IV.
For CBC and CTR, decryption requires that the first 16 elements of the input are the initialisation vector.
In the case where you want to transmit a message without IV you should remove the IV before sending the message using standard MMBasic manipulations. In this case the recipient must know the IV as well as the key and create a complete message before using DECRYPT by prepending the IV to the incoming message.
Edited 2024-12-23 03:00 by matherp
javavi
Posted: 05:25pm 22 Dec 2024
PicoMiteHDMI MMBasic RP2350A Edition V6.00.01RC10
OK! PSRAM (ESP-PSRAM64H 133MHz) works in 640 & 1024 HDMI resolutions
640 @315MHz | 1024 @324MHz |
When changing the HDMI resolution to 1280, the following message appears at startup:
Invalid clock speed - reset to default
the resolution is reset to 640 but the default font settings remain FONT 3
All these innovations are already reaching the minor version PicoMite V6.01
Edited 2024-12-23 03:35 by javavi
Posted: 05:36pm 22 Dec 2024
Just do Option RESET to clear up. The test for working just attempts to get the firmware to run and doesn't try to tidy up.
javavi
Posted: 06:01pm 22 Dec 2024
  matherp said  Just do Option RESET to clear up. The test for working just attempts to get the firmware to run and doesn't try to tidy up.
In my case, this reset leads to the need to configure all the options again.
This is especially difficult on PicoMite USB editions, since my board does not have USB-UART on the pins by default. Although there is the ability to connect an external USB Hub.
Edited 2024-12-23 04:03 by javavi
twofingers
Posted: 09:01pm 22 Dec 2024
About: V6.00.01RC10
Hi Peter,
AFAIK is there an issue with
Math aes128 decrypt ctr key$,out$,comp$,iv$
I suspect that only the IV$ part (initialisation vector) is affected. If "IV$" is commented out it works (iv_enabled=0).
The longstring DEcrypt version also works!
LongString AES128 DECRYPT CTR key$, lout%(), lcomp%() ,iv$
Demo code.
' Peters aes demo program for Picomites
' modified for ascii input by twofingers@TBS
Option explicit
CLS
Const iv_enabled = 0 ' IV on/OFF <<<<<<<<<<<<<-------------------
Dim string in$="",out$="",comp$=""
Dim integer i
Dim key$ ="0123456789ABCDEF" 'Your "Password"
Dim IV$  ="0123456789012345" 'initialisation vector
'convert the message to a string version of the message
Print
Input "Your message (max 224): ", in$
Inc in$,String$((16-Len(in$) Mod 16)Mod 16,0)
' encrypt the message
If iv_enabled Then
  Math aes128 encrypt ctr key$,in$,out$,iv$
Else
  Math aes128 encrypt ctr key$,in$,out$',iv$
EndIf
IV$=Left$(out$,16)
Print "1> "out$,Len(IV$),Len(out$)
If iv_enabled Then out$=Mid$(out$,17)
Print "2> "out$,Len(IV$),Len(out$)
'decrypt the message
If iv_enabled Then
Else
 Math aes128 decrypt ctr key$,out$,comp$',iv$
EndIf
Print out$
Print comp$
'check for errors
If in$<>comp$ Then Print "WTF" Else Print "Okay"
End
Michael
This is a working example using "Longstring AES ..." for decrypting:
Option explicit
CLS
Dim integer i
Dim lout%(2048),lcomp%(2048)
Print
LongString append lout%(),out$
comp$ = LGetStr$(lcomp%(), 1, Len(in$))
'Math aes128 decrypt ctr key$,out$,comp$,iv$
Print out$
Print comp$
'check for errors
End
Edited 2024-12-23 07:30 by twofingers
The lone and ...
Posted: 10:39pm 22 Dec 2024
Please read my post. Decrypt no longer has a iv option
twofingers
Posted: 10:56pm 22 Dec 2024
@Peter
Thanks. Works!
I'm just wondering how MATH AES DECRYPT detects if the message was sent with or without IV, hence my confusion.
Michael
I'm guessing it sets a flag in the output file?
Option explicit
CLS
Const iv_enabled = 1 ' IV on/OFF <<<<<<<<<<<<<-------------------
Dim integer i
Print
If iv_enabled Then
Else
  Math aes128 encrypt ctr key$,in$,out$  'without initialisation vector
EndIf
Math aes128 decrypt ctr key$,out$,comp$  '
Print ">"comp$"<"
'check for errors
End
Edited 2024-12-23 09:09 by twofingers
The lone and ...
Posted: 11:30pm 22 Dec 2024
  matherp said  For CBC and CTR decryption the firmware assumes that the first 16 bytes of in%() are the initialisation vector.
My understanding is an IV is always prepended to the message. If you don't specify one a random one is used.
If you supply an IV at the decryption end the prepended one is ignored.
Edit.
Perhaps I haven't understood the question.
  Quote  For CBC and CTR modes the encryption will generate a random initialisation vector and prepend out%() with the IV. If an explicit IV is specified this will be used instead of the random vector and this will be prepended to out%()
If the IV has been removed before sending it is up to the receiving end program to add the IV before decrypting. There is no automatic mechanism to determine if the IV has been removed before sending.
Edited 2024-12-23 09:44 by phil99
twofingers
Posted: 11:47pm 22 Dec 2024
  phil99 said  ... My understanding is an IV is always prepended to the message. If you don't specify one a random one is used. ...
Very true. That's exactly how it is! "Out$" is always the same length.
Michael
  phil99 said  ... If the IV has been removed before sending it is up to the receiving end program to add the IV before decrypting.
And the program on the receiving end must know that it is required to add the IV.
Edited 2024-12-23 09:56 by twofingers
The lone and ...
Michal
Posted: 09:25am 23 Dec 2024
> option list
PicoMite MMBasic RP2350A Edition V6.00.01RC10
OPTION CPUSPEED  150000 'KHz
> run
MMBASIC benchmark (C) KnivD 2016
Calculating...
[8] randomize Timer
Error : Unknown command
twofingers
Posted: 09:39am 23 Dec 2024
Hi Michal,
I think "RANDOMIZE nbr" is no longer available on the Pico 2.
  Quote  RANDOMIZE nbr
(RP2040 only)
Maybe
  Quote  MATH RANDOMIZE [n]
and
  Quote  MATH(RAND)
can help?
Michael
Edited 2024-12-23 19:43 by twofingers
The lone and ...
Posted: 09:41am 23 Dec 2024
Peter,
Thanks, PLAY WAV works now on 2040 VGA.
Edited 2024-12-23 19:42 by Volhout
Michal
Posted: 10:34am 23 Dec 2024
Yes, MATH RANDOMIZE TIMER in place of RANDOMIZE TIMER works on both.
Posted: 11:04am 23 Dec 2024
Randomize is not needed on the rp2350 because the chip uses a H/W mechanism to generate entropy. The RP2040 uses the standard C rand() software function.
MATH RANDOMIZE uses a completely different and better software function than the standard C version. If you use MATH RANDOMIZE you must also use MATH(RAND) and not RND or you are achieving nothing
Geoffg
Posted: 02:03pm 23 Dec 2024
It would be handy if the RP2350 version simply ignored the RANDOMIZE command rather than generate an error.  That would allow many programs to run unchanged on either platform.
Geoff
     Page 20 of 23
