Local Time 14:38 26 Oct 2026 Privacy Policy
     Page 21 of 52
Posted: 02:55pm 04 Apr 2025
@Peter,
RC8 2040 VGA PS2 platform (OPTION RESET VGA DESIGN 2)
make sure there is a program in memory (LOAD "xxx.bas") , just for the demo.
RESTART (or cold boot)
FONT 7 .... the screen goes black, cursor gone. blindly type:
LIST
Several things happen
1/ top part of the screen is not part of the listing
2/ at the listing end, when typing LIST again, the screen goes white.
Other fonts seem okay, only font 7 is affected (although font 6 is a unusable for LIST, it seems to function okay).
Edited 2025-04-05 00:58 by Volhout
Posted: 03:12pm 04 Apr 2025
Here you go
PicoMite.zip
Posted: 05:33pm 04 Apr 2025
@Peter,
Yes, that fixed it completely...
JanVolk
Posted: 06:16pm 04 Apr 2025
Program stopped. Possibly a problem in I2C ????
I can't find anything strange yet.
My program worked fine for a few hours until the output to LCD 2004 with I2C stopped.
Now a test with heartbeat on was first off to discover more of the problem.
After a reset I got the following. RTC is not used.
List system i2c does not work anymore.
PicoMite MMBasic RP2350A Edition V6.00.02RC9
Copyright 2011-2025 Geoff Graham
Copyright 2016-2025 Peter Mather
RTC not found, OPTION RTC AUTO disabled
> option list
OPTION SYSTEM I2C GP4,GP5
OPTION FLASH SIZE 16777216
OPTION COLOURCODE ON
OPTION PICO OFF
OPTION CPUSPEED (KHz) 150000
OPTION DISPLAY 44, 96
OPTION SDCARD GP15, GP10, GP11, GP12
> option system i2c
Error : Syntax
> list pins
GP0      1      OFF
GP1      2      OFF
GP2      4      OFF
GP3      5      OFF
GP4      6      Boot Reserved : SYSTEM I2C SDA
GP5      7      Boot Reserved : SYSTEM I2C SCL
GP6      9      OFF
GP7      10     OFF
GP8      11     OFF
GP9      12     OFF
GP10     14     Boot Reserved : SD CLK
GP11     15     Boot Reserved : SD MOSI
GP12     16     Boot Reserved : SD MISO
GP13     17     OFF
GP14     19     OFF
GP15     20     Boot Reserved : SD CS
GP16     21     OFF
GP17     22     OFF
GP18     24     OFF
GP19     25     OFF
GP20     26     OFF
GP21     27     OFF
GP22     29     OFF
GP23     41     OFF
GP24     42     OFF
GP25     43     HEARTBEAT
GP26     31     OFF
GP27     32     OFF
GP28     34     OFF
GP29     44     OFF
> ? mm.info$(system i2c)
I2C
> ? mm.info(boot count)
35
> ? mm.info$(lcdpanel)
> ? mm.info(heap)
294400
> ? mm.info(stack)
537401288
> ? mm.info(system heap)
53328
> ? mm.info(varcnt)
1
> ? mm.watchdog
0
> list system i2c
HEX  0  1  2  3  4  5  6  7  8  9  A  B  C  D  E  F
00:
Greetings,
Jan.
Edited 2025-04-05 04:23 by JanVolk
Posted: 06:24pm 04 Apr 2025
Jan,
When the LCD blocks the I2C bus for some reason, the bus (shared with RTC) cannot find RTC, and will disable the RTC AUTO function.
What are your I2C pullups ? 2k2 ? What is your RTC ? 3.3V device I assume. I assume the LCD is driven from a 3.3V PCA7584 (not a PCF7584, that is 5V).
If you use 5V devices on a 3.3V I2C bus, technically it is possible Vhigh is not met. use a level shifter to be sure (*)
Pullups are needed becuase the 2350 GPIO issue.
I fought a DS1307 RTC for times and times, it was connected to the 3.3V bus, and worked (at least that is what I thought). In the end, I added a level shifter, and never had a problem since.
Edited 2025-04-05 04:26 by Volhout
Posted: 06:28pm 04 Apr 2025
list system i2c locks up if one of sda/sck is permanently low. Something is locking up the I2C bus
ville56
Posted: 06:58pm 04 Apr 2025
@Peter,
is it intentinally that e.g.
   line aa 0,100,100,100,5,rgb(red)
only draws a line 1 pixel wide, whereas
   line 0,100,100,100,5,rgb(red)
draws a line 5 px wide?
Conclusion: if a line has either 0, 90,180, 270 degrees orientation, the line width is not correct in LINE AA
Env.: PicoMiteHDMI MMBasic RP2350B Edition V6.00.02RC9
note: seems to apply also other configs in RC9
Gerald
Edited 2025-04-05 05:01 by ville56
73 de OE1HGA, Gerald
electricat
Posted: 07:01pm 04 Apr 2025
HDMI/USB/2350 RC8
Not a big deal, however "user manual pg. 37
"Either forward or back slashes can be used in paths"
Accidently found :
SPRITE LOAD "b:/pathto/sprite.spr",51
will load
SPRITE LOAD "b:\pathto/sprite.spr",51
will load
SPRITE LOAD "b:/pathto\sprite.spr",51
will load
SPRITE LOAD "b:\pathto\sprite.spr",51
Will throw error: The logical drive number is invalid
My MMBasic 'sand box'
JanVolk
Posted: 07:22pm 04 Apr 2025
Hello Harm,
I have a 3231 RTC module on the bottom of my MAKER PI PICO board and a 2004 LCD with an I2C to parallel print on the back and placed on the side with nylon spacers as a sturdy whole.
It is true that the 4x20 works on 5V but I removed the SDA and SCL pullup resistors of 4K7 from the LCD I2C print (5V) and moved them to a 3V3 connection, so that the I2C bus works on 3V3. This has been working like this for a few years without any problems.
Then no problem with the 5V on the pins of the display.
I had problems with the output of the display with self-made characters before. I think this has been fixed.
As you may know, it is possible to use Chr$(0) to Chr$(7) for this.
But with Chr$(0-255) you can also place the AscII characters on the screen with LCDI2C lineno, charno, "test" or LCDI2C lineno, charno, Chr$(nr) or LCDI2C lineno, charno, Str$( ).
I called the character on the screen with Chr$(2) which resulted in a distorted Chr$(0). It turned out that I had not defined Chr$(2) which caused Chr$(0) to give nonsense. After making Chr$(2) the empty character (data byte 8 x 0) I had no more problems.
I use this Chr$(nr) to show the status on the display with a letter R=Rain etc.
It may happen again if I choose Chr$(1) and Chr$(3) to Chr$(7) in the program that I have not tested yet. One problem at a time. (I made this program 10 years ago with BascomAVR and it still works and now converted to MMBasic).
Greetings,
Jan.
JanVolk
Posted: 07:39pm 04 Apr 2025
Peter,
Reset on MAKER PI PICO does not help. List system i2c does not work yet.
USB plug out and in and then it worked again. Possibly the LCD screen is stuck. I do use an RP2350A ???
But there is no proof yet that this is the problem? I will apply some check points to clarify the problem.
Greetings,
Jan.
JanVolk
Posted: 09:32pm 04 Apr 2025
Harm and Peter,
The I2C chips I have are HLF8574T and on the MAKER PI PICO a PCF8574T and a 2004 LCD 4x20 and a blue DS3231 module with 24C32N EEProm and CR2032 button cell from China.
The I2C bus is loaded with 2x4K7 parallel, so 2K35 on the SDA and on the SCL.
The LCDI2C subroutine I use is the same as the pdf I recently posted with I2C examples.
If there are any questions, please let me know.
Greetings,
Jan.
Posted: 08:26am 05 Apr 2025
V6.00.02RC10 is available on
Fixes bug in SPRITE LOAD filename parsing
Stops LIST SYSTEM I2C locking up
Fixes bug in switching to Font 7 in mode 1 VGA
Fixes reported characters in line when font 8 used in 1280x720 and 1024x768 resolution
Supports variable frequency for BACKLIGHT command
BACKLIGHT n [,FreqInHz]
Adds:
MM.HEIGHT 'the number of character across the physical display with the current font
MM.WIDTH ' the number of characters down the display with the current font
MM.DISPLAY 'returns 1 if a physical display is configured, otherwise 0
Edited 2025-04-06 17:35 by matherp
JanVolk
Posted: 06:57pm 06 Apr 2025
Peter,
I tested the firmware version PicoMite MMBasic RP2350A Edition V6.00.02RC10 and it worked all day without any problems without any error messages and everything continues to work.
Now the option autorun on is enabled.
Unfortunately, it now goes wrong with regard to the DS18B20 OneWire temperature sensors.
I see that the DS18B20 sensor on GP13 still works correctly but the DS18B20 sensor on GP14 returns 10 degrees too high, which was not the case with OPTION AUTORUN disabled and both indicated the correct value.
This problem occurred on my MAKER PI PICO and on my OLIMEX board. On the Olimex there is a RaspBerry Pi Pico W with PicoMite MMBasic RP2350A Edition V6.00.02RC10 firmware with the same problem.
With this list it went well.
> option list
OPTION PICO OFF
OPTION RTC AUTO ENABLE
This list is wrong.
> option autorun on
> option list
OPTION AUTORUN ON
OPTION COLOR CODE ON
OPTION PICO OFF
OPTION CPU SPEED (KHz) 150000
Greetings,
Jan.
JanVolk
Posted: 10:14pm 06 Apr 2025
Peter,
Original program option autorun on
Outside temp.       : 28.95
Inside temp.        : 18.625
Window position_adc : 2.583992674
Window position     : 0
Rain detector       : 2.606153846
Original program option autorun off
Outside temp.       : 18.7625
Inside temp.        : 18.8125
Window position_adc : 2.592857143
Window position     : 0
Rain detector       : 2.619450549
Here is a shortened program where it works fine with option autorun on.
Rest of the week I will do further research in the original program. Program is 1100 lines so some research and I'll come back to it or something will come to light sooner?
Dim Temperature(5)
Dim Inside_temp
Dim Outside_temp
Dim Windowposition
Windowposition = 10
LCDI2C_Init &H20, 1, 0, 2, 3        ' 4x20 LCD PCF8574A
LCDI2C_BackLightOn
LCDI2C_CLEAR()
 Read_ds1
 Read_ds2
 LCDI2C_CMD(64)
 LCDI2C_DATA(7) : LCDI2C_DATA(5) : LCDI2C_DATA(7) : LCDI2C_DATA(0)
 LCDI2C_DATA(0) : LCDI2C_DATA(0) : LCDI2C_DATA(0) : LCDI2C_DATA(0)
 LCDI2C 1,  1, "OutdoorTemp.:R C"
 LCDI2C 1, 15, Str$(Temperature(2), 2, 1)
 LCDI2C 1, 19, Chr$(0)
 LCDI2C 2,  1, "Indoor Temp.: C"
 LCDI2C 2, 15, Str$(Temperature(1), 2, 1)
 LCDI2C 2, 19, Chr$(0)
 LCDI2C 3,  1, "Window position :R %"
 LCDI2C 3, 15, Str$(Window position, 2, 1)
 LCDI2C 4, 1, " "
 LCDI2C 4, 1, "zo"
 LCDI2C 4, 4, Left$(Date$, 5)
 LCDI2C 4, 16, Left$(Time$, 5)
 Print
 Print
 Print " ******* Log climate ********"
 Print " Outside temperature :" ; Temperature(2)
 Print " Inside temperature  :" ; Temperature(1)
 Print " Window position     :" ; Window position
 Print " Date                : "; Date$
 Print " Time                : "; Time$
 Pause 10000
End
Sub Read_ds1                   ' Read DS18B20 out
 TEMPR START GP13, 3          ' 2=0.125C 400mS 3=0.0625 800mS 1=0.25C 200mS stand.
 ' Tempr(GP13)
 Temperature(1) = TEMPR(GP13) ' InsideTemperature(13)
 Pause 800
End Sub
Sub Read_ds2                   ' Read DS18B20 out
 TEMPR START GP14, 3          ' 2=0.125C 400mS 3=0.0625C 800mS 1=0.25C 200mS stand.
 ' Tempr(GP14)
 Temperature(2) = TEMPR(GP14)-0.3 ' Outside Temperature(14)
 Pause 800
End Sub
' ** All subroutines for LCD 16x2 and 20x4              **
' ** Line=1-4, Char=1-16, Text$=CHR$+ALL CHARACTERS     **
' LCDI2C Line, Char, Text$
Sub LCDI2C(LineNum, CharPos, Text$)
 Local I
 If LineNum = 1 Then I = (&H80 + CharPos - 1)
 If LineNum = 2 Then I = (&HC0 + CharPos - 1)
 If LineNum = 3 Then I = (&H94 + CharPos - 1)
 If LineNum = 4 Then I = (&HD4 + CharPos - 1)
 LCDI2C_CMD(I)
 For I = 1 To Len(Text$)
   LCDI2C_DATA(Asc(Mid$(Text$, I, 1)))
 Next I
End Sub
The remaining subroutines of LCDI2C are continued below.
Greetings,
Jan.
Posted: 11:36pm 06 Apr 2025
Unable to replicate the TEMPR issue
       AHT10         DS3231 Temp   distance       DS18B20      DS18B20        DHT11
67 %        12.3`C        12`C       232 mm       13.6`C       12.7`C     12.5`C  78 %
The difference between the DS18B20s is mainly due to their different locations plus 0.4°C calibration error in a non-genuine unit.
The Sub
Sub DS18B20
  TEMPR START 9,3
  TEMPR START 10,3
  DS1 = Cint(TEMPR(9)*10)/10
  DS2 = Cint(TEMPR(10)*10)/10
End Sub
But when loading options from .OPT file OPTION DISPLAY changed to 0,0 which was quite confusing.
For RP2350A VGA RC10. using TeraTerm.
Edited 2025-04-07 11:53 by phil99
JanVolk
Posted: 02:54pm 07 Apr 2025
Gentlemen,
The problem with option autorun on and off has become a bit clearer.
Program run with OPTION AUTORUN OFF works well with regard to outside temperature.
Program run with OPTION AUTORUN ON works well with regard to outside temperature.
If I restart the module with a reset, no problem yet.
If I disconnect the USB cable and reconnect it, no problem yet.
In both cases, Tera Term was active.
If I do not log in with Tera Term and give a reset, I have the problem that outside temperature measures 10 degrees higher than before.
This is also the case if I use a separate 5V adapter instead of a USB laptop and therefore have OPTION AUTORUN ON.
Unfortunately, the above is not always the case with Tera Term connected. Also did some tests for a second Tera Term connection, after which it all goes wrong. See further.
My suspicions are in the direction of data control via USB from Tera Term with OPTION AUTORUN ON? But still not clear why measure 10 degrees higher with OPTION AUTORUN ON and only a separate power supply?
Looked a bit further and now a blocking of the I2C bus.
> option heartbeat on
> option list
OPTION AUTORUN  ON
OPTION PICO OFF
> list system i2c
00: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
> run
Now heartbeat has also stopped.
Maybe I need to flash the firmware again?
To be continued.
Greetings,
Jan.
Posted: 03:12pm 07 Apr 2025
Try a short pause before doing the first temperature reading to allow everything to stabilise
JanVolk
Posted: 03:51pm 07 Apr 2025
Peter,
When starting up I already have a wait of 6 seconds for a welcome screen before the measurements start.
Another observation.
The program was stuck, no heartbeat and no I2C but I could still look into the controller.
> list pins
GP0      1      OFF
GP1      2      OFF
GP2      4      OFF
GP3      5      OFF
GP6      9      OFF
GP7      10     DIN
GP8      11     DIN
GP9      12     DIN
GP13     17     OFF
GP14     19     OFF
GP16     21     DOUT
GP17     22     DOUT
GP18     24     OFF
GP19     25     OFF
GP20     26     OFF
GP21     27     OFF
GP22     29     OFF
GP23     41     OFF
GP24     42     OFF
GP25     43     DOUT
GP26     31     AIN
GP27     32     AIN
GP28     34     OFF
GP29     44     OFF
> option list
OPTION AUTORUN  ON
OPTION PICO OFF
> list system i2c
But I thought the flashing went well but it really didn't because OPTION AUTORUN ON held everything up.
If I stop this with OPTION AUTORUN OFF the I2c works again and the flashing works again.
Does it all sound intense?
Greetings,
Jan.
JanVolk
Posted: 04:37pm 07 Apr 2025
Peter,
I deleted a few old OneWire lines which may have caused the problems?
Option autorun on
Option rtc auto enable.
HEARTBEAT GP25 had the same number in my program so changed to GP21.
At start Pause 2000
At welcome screen Pause 3000
At sub outside and sub inside temperature Pause 2000
Calculate every 60 seconds.
So far it works fine with an external USB power supply so only 2004 LCD 4x20 for checking and waiting.
Greetings,
Jan.
circuit
Posted: 07:52pm 07 Apr 2025
  matherp said
  Quote  It is also no longer possible to do simple BIT operations in an integer variable.
b%=1<<n
a% = a% or b%
a% = a% and inv b%
Peter, where are we with retaining the BIT() command and function?  I was overjoyed when you introduced this command/function because I mainly use my pico/micromites for embedded control.  The BIT command/function has made switching PORT outputs so much simpler in coding.  It is also simply fantastic for serial protocols using shift registers.  I am now stuck with having loaded up my picomites with the last code to retain the BIT command/function and it is not clear to me whether or not the latest download will have these available; I don't want to overwrite and find that I have lost these command/functions.  PLEASE, if it is at all possible, can we retain this most welcome functionality?  I realise that you were thinking originally only of a neat way to provide flags, but what you provided was a REALLY neat way of engaging serial protocols for shift registers.  The TPIC6595N Power Logic Shift Register provides 8 x 250mA switched outputs per chip and that is where I am using the BIT command/function.
     Page 21 of 52
