Local Time 23:14 24 Oct 2026 Privacy Policy
     Page 21 of 31
toml_12953
Posted: 04:11pm 10 Jun 2026
  matherp said  V6.03.00RC17
PicoMiteRP2040V6.03.00RC17.zip
PicoMiteRP2350V6.03.00RC17.zip
Fixes bug in MEMORY SHARE and improves detection of incorrect wiring
Fixes bug in PORT command when using pins > GP32 on RP2350B processors
Adds support for additional TLS crypto methods
There still seems to be a problem with beautifying. Lines 100-120 should line up with line 20 since the FOR N=... loop is now finished.
10 ' Ahl's Simple Benchmark
15  TIMER =0
20  FOR N=1 TO 100: A=N
30    FOR I=1 TO 10
40      A=SQR(A): R=R+RND(1)
50    NEXT I
60    FOR I=1 TO 10
70      A=A^2: R=R+RND(1)
80    NEXT I
90    S=S+A: NEXT N
100     PRINT ABS(1010-S/5)
110     PRINT ABS(1000-R)
120     PRINT TIMER/1000;" seconds"
Posted: 04:39pm 10 Jun 2026
You need to put next n on a separate line. I won't comment on the programming style
Posted: 05:20pm 10 Jun 2026
  matherp said  Try this
PicoMite (2).zip
Sorry Peter,
That did not solve it.
toml_12953
Posted: 05:24pm 10 Jun 2026
  matherp said  I won't comment on the programming style
I wouldn't feel bad. It's David Ahl's code!
Posted: 05:26pm 10 Jun 2026
@Peter: I have a vague recollection that several months ago you provided an option or command which could vary the allocation of heap vs regular memory, but I can't find it in the manual or in my code or options or by searching posts. Do I imagine it? Once again, I need more heap. Webmite, no PSRam.
(Note: I asked Claude Code if it had introduced any string arrays without LENGTH values. It had, and adding LENGTH fixed the heap problem. But I'd still like to know if there is a way to adjust heap/regular.)
It did for me so I need absolutely explicit instructions as to how to get a RP2040 into the state where it fails. I nuked it, powered off, and then loaded and it ran your quadrature encoder S/W perfectly - I even wired up a real encoder to make sure the test was properly valid
There is no trade-off between heap and "ordinary memory". An amount of memory is allocated for global and local variables, the rest is heap. What you can do is trade between global and local within the total allowed variables
Edited 2026-06-11 03:29 by matherp
Posted: 06:58pm 10 Jun 2026
Peter,
The most obvious is when you start the program, and the count is not zero.
Posted: 09:38pm 10 Jun 2026
But I can't reproduce that. If I can't get a Pico into that state I can't possibly fix it.
Posted: 06:49am 11 Jun 2026
Peter,
I understand. Currently I am trying to try to find a relation between USB (console) and the problem. Repairing it happens by interacting with the pico (either MMCC or Putty) and editing (Either MMEdit or built in Editor). So repairing always involves (for me) with USB / USB console.
So I have a few Pico's set up with autorun enable. I power them every few days. When they show the problem again, I could try to power them from 5V on Vsys (not USB) and see if it repairs, or the problem persists (*).
Waiting for the problem to re-appear.
(*) When the problem shows, a cold boot (pulling/re-inserting USB power) does NOT repair. Let's see if repower without connecting USB repairs.
P.S. I see 2 explanations for this: #1=non initialized RAM, #2=overlapping buffers. #1 can be diagnozed by wiping all RAM at earliest start point with 0, or &hffffffff, before starting anything. Even before USB. #2 is what I am trying to analyze now.
Edited 2026-06-11 16:56 by Volhout
Posted: 07:14am 11 Jun 2026
You can try this version and see if it makes any difference. I have removed all MIN specific differences in optimisations levels compared to normal PicoMite
PicoMiteRP2040V6.03.00RC18.zip
Posted: 07:43am 11 Jun 2026
@Peter,
a/ rc18 does not fix it, so your speed optimizations are sound.
b/ once the problem shows, powering from 5V does not fix it.
c/ when the problem is not showing, powering from 5V does not change that.
b/ and c/ there is no obvious relation between USB and the problem.
P.S. tested on a pico zero with WS2812, green is PIO FIFO ok, red PIO FIFO wrong.
Edited 2026-06-11 17:45 by Volhout
terekgabor
Posted: 08:47am 12 Jun 2026
Hello Peter,
somewhere earlier I asked this, but it came up again during programming.
Is it possible in future versions to have possibility to jump forward/backward in a MP3/FLAC/WAV file which is currently playing?
For example with extra instructions like PLAY REWIND/FORWARD n (where n is in seconds).
G@bor
Posted: 08:56am 12 Jun 2026
  Quote  Is it possible in future versions to have possibility to jump forward/backward in a MP3/FLAC/WAV file which is currently playing?
No: the codec has to proceed linearly though the file
JanVolk
Posted: 12:27pm 12 Jun 2026
Peter,
I hadn't noticed this before.
Load a program with more than 100 lines.
Go to edit.
Go to line 100 or higher.
Use the arrow keys or mouse to position 9 and then to 10 or higher and look at the bottom info line. Fortunately, nothing shocking.
This only occurs with OPTION RESOLUTION 848.
Another point that may have been noted before, but I can't find it. If a program has been run in MODE 3, the mouse no longer works in EDIT. This is only the case for MODE 3; the others work normally.
> option list
PicoMiteHDMI MMBasic USB RP2350A Edition V6.03.00RC17
OPTION SERIAL CONSOLE COM1,GP0,GP1
OPTION SYSTEM I2C GP20,GP21
OPTION FLASH SIZE 16777216
OPTION COLOR CODE ON
OPTION MOUSE SENSITIVITY 1.0000
OPTION KEYBOARD US
OPTION HEARTBEAT OFF
OPTION PICO OFF
OPTION RESOLUTION 848x480 @ 336000KHz
OPTION DISPLAY 40, 106
OPTION HDMI PINS 1, 3, 7, 5
OPTION GUI CONTROLS 100
OPTION RTC CAR ENABLE
OPTION MODBUFF ENABLE 192
OPTION F1 help
OPTION F5 list commands
OPTION F6 list functions
OPTION F7 list pins
OPTION F8 option list
OPTION F9 fm
OPTION PLATFORM OLIMEX USB
Thanks for the nice and very useful additions to the current firmware.
Jan.
Posted: 01:40pm 12 Jun 2026
  Quote  I hadn't noticed this before.
Go to edit.
This behaviour is correct. The status line shows the most information that it can. When the combination of the line number and the column number increase that field enough to collide with the status line the next smallest version of the status line is then used.
  Quote  Another point that may have been noted before, but I can't find it. If a program has been run in MODE 3, the mouse no longer works in EDIT. This is only the case for MODE 3; the others work normally.
This is a S/W limitation. In the editor, the mouse works by flipping the tile colours. There is no such mechanism available in mode 3, the character would have to be rewritten. The workaround is to switch back to mode 1 before editing.
JanVolk
Posted: 02:01pm 12 Jun 2026
Peter,
Thanks for the explanation. I understand.
Jan.
Posted: 06:00pm 12 Jun 2026
V6.03.00RC18
PicoMiteRP2350V6.03.00RC18a.zip
PicoMiteRP2350V6.03.00RC18b.zip
New HDMIWEB build - Web, HDMI and USB host rolled into one
CPU SPEED command - change the cpu speed without a reboot
RESOLUTION command - change the HDMI resolution without a reboot
Various bugs fixed as identified previously in this thread
See the updated manual for full details
PicoMite_User_Manual.pdf
Use the HDMIWEB build with a touch screen 1024x600 HDMI monitor and the On screen keyboard, print a case and you have a fully functional self-contained MMBasic tablet computer
JanVolk
Posted: 09:58pm 12 Jun 2026
PicoMite MMBasic RP2040 V6.03.00RC18
> option list
OPTION COLOURCODE ON
OPTION PICO OFF
OPTION CPUSPEED (KHz) 200000
OPTION DISPLAY 50, 100
OPTION F1 help
OPTION F7 list pins
OPTION F8 list system i2c
OPTION F9 fm
> list pins
GP0      1      OFF
GP1      2      OFF
GP2      4      OFF
GP3      5      OFF
Press any key to continue
GP4      6      OFF
GP5      7      OFF
GP6      9      OFF
GP7      10     OFF
GP8      11     OFF
GP9      12     OFF
> list pins
[LIBRARY] Dim _q%
Error : _Q already declared
Jan.
JanVolk
Posted: 10:03pm 12 Jun 2026
> option list
OPTION PICO OFF
OPTION F1 help
OPTION F7 list pins
OPTION F9 fm
> list pins
GP0      1      OFF
GP1      2      OFF
GP2      4      OFF
GP3      5      OFF
GP4      6      OFF
GP5      7      OFF
GP6      9      OFF
GP7      10     OFF
GP8      11     OFF
GP9      12     OFF
> list pins
[LIBRARY] Dim _q%
Also with RP2350.
Jan.
Edited 2026-06-13 08:17 by JanVolk
toml_12953
Posted: 12:04am 13 Jun 2026
  JanVolk said
Also with RP2350.
Jan.
I can't make either of my PicoCalcs do that with the Web 2350 version.
     Page 21 of 31
