Local Time 13:15 12 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite V6.00.00 release candidates - all versions
     Page 25 of 25
Posted: 10:46am 25 Nov 2024
  andreas said  Does it support wireless?
The combinatorial explosion of PicoMite firmware is only exceeded by that of PicoMite PCB designs .
Posted: 10:59am 25 Nov 2024
No
Posted: 11:07am 25 Nov 2024
It's apparently working in the development branch of the SDK, including Bluetooth 5.2.
info here
Here be dragons though....  lol
Edited 2024-11-25 21:08 by Mixtel90
mace
Posted: 08:49am 28 Nov 2024
PicoMite 5.08.00.
Pins all output.
Port(1,2,4,4,9,2)=255.Port all high.
missing parenthes(own typo)
Port(1,2,4,4,9,2=255.Bits 0-5 high,bits 6,7,low.
No error message.
Posted: 10:54am 28 Nov 2024
9 starts the final pair but the command is then abandoned as the second value is missing.
The variable "2" is set to 255  :)
Interesting...
Try it with OPTION EXPLICIT
Posted: 04:08pm 28 Nov 2024
The 2=255 is probably evaluated and if so will be false (0 I think)
Then... not sure what a Port on its own does?
javavi
Posted: 08:13am 29 Nov 2024
Good day!
I propose to consider such a mechanism for executing a chain of programs
End cmdline$
The operator End cmdline$ the program and passes the argument to the MM.CMDLINE$ variable, which in turn is entered in the command line of the prompt.
> cmdline$
Thus, upon completion the program can output the result, message, execute the command line, run the program with its arguments.
Posted: 08:33am 29 Nov 2024
Why not use RUN file$, cmdline$ in your program? That already exists.
You can't get back anyway as any new program will overwrite the previous one and its variables (unless it exists in a flash slot where you can use FLASH CHAIN).
Posted: 08:37am 29 Nov 2024
  Quote  Good day!
6.00.01 is closed for changes other than bug fixes
javavi
Posted: 08:43am 29 Nov 2024
  Mixtel90 said  Why not use RUN file$, cmdline$ in your program?
I would even be happy with a RUN cmdline$ command that would execute the line.
Posted: 09:00am 29 Nov 2024
RUN file$, cmdline$ exists now. You just have ro set it up:
RUN "A:/junkfiles/mynextprogram.bas","the,argument,string"
then retrieve MM.CMDLINE$ and parse the arguments when the program starts
javavi
Posted: 09:13am 29 Nov 2024
  Mixtel90 said  RUN file$, cmdline$ exists now.
I meant the
RUN [file$],[cmdline$]
RUN command in which the file name is an optional parameter and it could be skipped and the next line executed.
javavi
Posted: 09:14am 29 Nov 2024
I meant the
Posted: 09:32am 29 Nov 2024
No, not possible. You have to know what you are going to run as there can't be any environment variables. The best you could do would be to write your variables to a file either in flash or on A:, then anything can retrieve them.
You can't have environment variables as there's nowhere for them to be. The program and variables areas get wiped.
What you suggest would simply run the program currently in memory so there's not a lot of point.
javavi
Posted: 05:16pm 29 Nov 2024
  Mixtel90 said  No, not possible. You have to know what you are going to run as there can't be any environment variables.
I need a way that could execute any command line entered into a program as if it was entered at the command prompt.
For example, a user enters a command in FileManager and expects that any valid COMMAND including OPTION will be executed.
I don't see a way out yet, and the EXECUTE command doesn't suit me with its limitations.
RUN ,"FILES ,size"+Chr$(13)
That is why I suggested the following syntax for the RUN command, in which, if the file name is missing, the following command line parameter will be executed.
twofingers
Posted: 05:28pm 29 Nov 2024
I think this is something that used to be done on home computers by writing to the keyboard buffer. I don't know if the Picomite could still do this today.
Michael
The lone and ...
Posted: 05:33pm 29 Nov 2024
I can see what you are trying to do, but I can't see how it could be done as MMBasic has been designed from the ground up with a command line for humans to use, not programs. I suspect you'd have to rewrite fundamental parts of MMBasic to allow this. Even then, if someone made a mess of programming you could get a system that's in a continuous reboot loop. TBH I think this is wishful thinking as it's of very limited use.
javavi
Posted: 05:40pm 29 Nov 2024
Yes, in general the application is limited, but in my rare case I need it.
I think this is only needed for system programs.
Edited 2024-11-30 04:13 by javavi
     Page 25 of 25
