Forum Index : Microcontroller and PC projects : Small options and setup pgm
| KeepIS Guru Joined: 13/10/2014 Location: AustraliaPosts: 2265 |
Fixed a programming language problem with COM Ports. I remembered from years ago that standard COM interface did not correctly indicate the port status, you can unplug a certain port and the port will still be returned as connected by the programming interface function, and it's still the same. I quickly rewrote the code for port detection and bypassed the inbuilt function. The detection now works correctly, but just not as fast, so a port connect / disconnect will take a second or so to shown up in the Port select window. I also included two default List files for someone trying the program for the first time, DISABLE.TXT and USER.TXT. If you already have these files with these names in the same directory as MM_Options then make sure to remove these from the ZIP first. NANO:Inverter V 8.4ks - Linux AvrDude GUI script V4.1 |
