Local Time 16:14 19 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : LED matrix with CMM, am I going to break the latter?
     Page 3 of 3
Turbo46
Posted: 07:03am 10 Feb 2020
All these suggestions are very well and will help to keep the magic smoke inside the Maximite chip but I don't think there can be a universal interface because inputs an outputs can be anywhere. That is they can be adjacent pins and that can make it difficult to use a uni-directional buffer without patching.
I remember there was disagreement on which pins should be used for joysticks etc.
Bill
Posted: 08:34am 10 Feb 2020
  bigmik said
  thwill said
Also since I have an "audience" can I hijack my own thread and ask what the PCB mounted terminal for attaching to with a crocodile clip is called?
Test Points? ...
Thanks Mick, that is exactly what I was thinking of.
Posted: 08:37am 10 Feb 2020
  PeterB said
Tom. The reason you have so many people helping is because we Australians like to feel superior to poms so we take every opportunity. Sadly, in about a month after this steep learning curve, you will be feeling superior to us.
Peter
I wouldn't worry about that. Have you see the lying, right-wing populist wankers that we've just elected into what can laughably be called a government? That's revealed pom superiority as the crock of sh*t it always was :-( ... or at least has been since the Victorians ... and then we were just successful, but still not terribly nice.
Edited 2020-02-10 18:38 by thwill
PeterB
Posted: 08:59am 10 Feb 2020
Tom.
I was thinking microprocessors not politics. After you have played with this for a few weeks you will be quite at home.
Peter
Posted: 09:34am 10 Feb 2020
  PeterB said  Tom.
Peter
Thanks Peter, and to everyone else who's responded.
The matrix is soldered ... and a right rat's nest it is ... so listen out for the boom and the sweet smell of magic smoke ;-)
Posted: 08:35pm 24 Feb 2020
Just in case anyone is interested.
By putting 1K resistors on the columns/anodes I have successfully (and without any magic smoke) driven my LED panel bareback on the Colour Maximite. The LED's are a little dim and flickery, but it's perfectly serviceable, see video:
https://www.youtube.com/watch?v=iwy1vCu-SLg
It's still my intention to play about with the various options of transistors, the ICs recommended above and ultimately probably a MAX7219 to increase the brightness and in the latter case reduce the number of I/O pins.
But first I'm going to wire up an NES controller and a buzzer to it. Then all I need it a time machine to take me back to the 1970s and I can rake it in from the electronics entertainment market ;-)
Edited 2020-02-25 06:40 by thwill
Posted: 09:35pm 24 Feb 2020
  PeterB said  Tony
Do you remember when RS232 chips were plugged into sockets because people kept blowing them up? What I propose is 3 x 74LVC244 in DIP sockets and 19? 330 ohm resistors all with suitable connectors to be decided. It means the outputs and inputs are on different pins but would that matter?
It comes down to how many people are worried about damaging their MM?
Peter
I use IC sockets for absolutely everything wherever possible. When an experimental board eventually gets rebuilt or trashed, all the ICs can be unplugged and reused. I never solder in any integrated circuits. Much prefer big old through hole components and sockets to surface mount, especially when trying to diagnose and repair faults.
A two dollar Chinese PCB then becomes a throw away item if all the ICs and some of the larger parts can be easily removed and reused in the next attempt.
PeterB
Posted: 10:07pm 24 Feb 2020
Tom.
You are now hooked.
The rest of your life will be a disaster   .
Tony.
My idea for a MAXI MITE prophylactic seems to have fallen on deaf ears.
I don't always use sockets because a good socket costs about as much as a cheap IC but I did buy a reasonable desoldering tool and I don't make mistakes anyway
Peter
Posted: 01:42am 25 Feb 2020
I believe some kind of protective buffering for an MM is an excellent idea, if regularly playing around with breadboards and prototypes. Far too easy to blow something up and have the destruction travel back and kill something really expensive.
Have to agree about the cost of good sockets, but if you buy bulk Chinese its not too bad. Being able to reuse the same chips over and over again in different projects means I can always have a good supply on hand to build just about anything I want at very short notice, without having to order in a whole bunch of new stuff every time.
Its really frustrating having to go out in the car for an hour to buy a single two dollar part because I blew up the last one of that type a month ago and forgot to reorder.
Just went out to the shed and had a look. I was surprised to find there are about 240 different types of digital and analog ICs here, and typically five to ten of each type.  Its a lot, but I have been slowly expanding the range and quantity for about fifty years.
Turbo46
Posted: 05:23am 25 Feb 2020
Impressive demo! You have nailed the matrixing, not to mention the scrolling text and the snake game. I'd like to see the code. Maybe you could try the game of Life?
It looks like you have resistors in both the columns and the rows. You could do away with one or the other now you know it works, depending on how you are handling the matrixing. Either the row or the column is only supplying one LED - that's where the resistor should be the other will be supplying 0 to 8 LEDs - that's where you could remove the resistor.
Bill
Posted: 09:56am 25 Feb 2020
Thanks Bill,
The additional resistors on the breadboard are some 470 ohms in series with the 330 ohms built onto the matrix board for a total of 800 ohms (the ~1K) on each column/anode.
I'm happy to share the code but give me a week to do some tweaks and cleanup. I also need to make sure I comply with the licensing for the "tom thumb" font it uses.
How would you like the code shared? Github or something else?
Edited 2020-02-25 19:57 by thwill
Turbo46
Posted: 12:08pm 25 Feb 2020
Sorry Tom,
Your arrangement with the resistors is evident when I have another look at the video. And the values are well chosen to keep the current drawn within safe limits (and the smoke in).
I was just thinking of you posting the code here in the forum but that's entirely up to you.
Bill
Posted: 12:28pm 25 Feb 2020
  Turbo46 said  Sorry Tom,
No worries.
  Quote  Your arrangement with the resistors is evident when I have another look at the video. And the values are well chosen to keep the current drawn within safe limits (and the smoke in).
Thanks for the double-check
  Quote  I was just thinking of you posting the code here in the forum but that's entirely up to you.
Bill
Will do, like I say I want to do some tweaking and cleaning and I need to check the licensing requirements of the 3rd party font.
Posted: 02:19pm 06 Mar 2020
Here's the code, hopefully better late than never:
The attached .tar.gz file includes the required font file (CC0 licensed).
snake-cmm.zip
Dim matrix(7)
row = 7
' The font contains 128 - 21 = 107 glyphs, each taking 3 bytes = 321 bytes
' Each float element of the array is 4 bytes => 81 * 4 = 324 bytes
Dim font4x6(80)
Dim snake(63)
demo = 0
diff = 1
UP = -8 : RIGHT = 1 : DOWN = 8 : LEFT = -1: SELECT = 10 : START = 20
Mode 2, 3
Cls
Print "SNAKE - Tom Williams 2020"
Print "Cursor keys to move"
Print "S to START"
Print "D to SELECT difficulty"
load_font()
matrix_init()
SetTick 1, matrix_draw
On Key on_key
main_loop()
End
Sub main_loop()
   matrix_clear()
   game_intro()
   game_init()
   game_loop()
   die()
End Sub
Sub game_intro()
 Local s$
 s$ = "SNAKE-Press START or SELECT to increase difficulty-Tom Williams 2020"
   If cmd = SELECT Then
     diff = 1 + diff Mod 4
     scroll_text(Str$(diff))
   Else
     scroll_text(s$)
     If cmd = 0 Then demo = 1 : cmd = START
   EndIf
 Loop Until cmd <> 0 And cmd <> SELECT
End Sub
Sub game_init()
 Local i
 For i = 0 To 63: snake(i) = 0 : Next i
 snake(0) = 35
 head = 0
 tail = 0
 dir = UP
 pill = 0
 score = 0
 cmd = 0
 matrix_set(snake(head), 1)
 place_pill()
End Sub
Sub game_loop()
 Local p
   Pause (5 - diff) * 50
   If cmd <> 0 And cmd < 10 Then dir = cmd : cmd = 0
   If demo Then demo_ai()
   If will_die() Then Exit Sub
   p = snake(head) + dir
   head = (head + 1) Mod 64
   snake(head) = p
   matrix_set(p, 1)
   If p <> pill Then
     matrix_set(snake(tail), 0)
     tail = (tail + 1) Mod 64
   Else
     score = score + 1
     pill = -5
   EndIf
   If pill = -1 Then place_pill()
   If pill < -1 Then pill = pill + 1
End Sub
Sub demo_ai()
 Local c, p, r
 p = snake(head)
 c = p Mod 8
 r = p \ 8
 If r = pill \ 8 Then
   If pill < p Then dir = LEFT
   If pill > p Then dir = RIGHT
 ElseIf c = pill Mod 8 Then
   If pill < p Then dir = UP
   If pill > p Then dir = DOWN
 ElseIf pill < p Then
   dir = UP
 Else
   dir = down
 EndIf
 If will_die() Then If (r > 3) Then dir = UP Else dir = DOWN
 If will_die() Then If (c > 3) Then dir = LEFT Else dir = RIGHT
 If will_die() Then If (r > 3) Then dir = DOWN Else dir = UP
 If will_die() Then If (c > 3) Then dir = RIGHT Else dir = LEFT
End Sub
Function will_die()
 Local p
 p = snake(head)
 If dir = UP And p < 8 Then
    will_die = 1
 ElseIf dir = DOWN And p > 55 Then
    will_die = 1
 ElseIf dir = LEFT And p Mod 8 = 0 Then
    will_die = 1
 ElseIf dir = RIGHT And p Mod 8 = 7 Then
    will_die = 1
 ElseIf matrix_get(p + dir) And (p + dir) <> pill Then
    will_die = 1
 EndIf
End Function
Sub die()
 Local i, j
 For i = 1 To 4
   matrix_fill()
   Pause 300
   matrix_clear()
   Pause 300
 Next i
 scroll_text("GAME OVER Score:" + Str$(score))
End Sub
Sub place_pill()
 pill = Int(Rnd() * 64)
 If matrix_get(pill) = 0 Then
   matrix_set(pill, 1)
 Else
   pill = -1
 EndIf
End Sub
Sub on_key()
 Local k
 k = KeyDown
 If k = &h64 Then
   cmd = SELECT
 ElseIf k = &h73 Then
   cmd = START
 ElseIf k = &h80 Then
   cmd = UP
 ElseIf k = &h81 Then
   cmd = DOWN
 ElseIf k = &h82 Then
   cmd = LEFT
 ElseIf k = &h83 Then
   cmd = RIGHT
 EndIf
End Sub
Sub matrix_init()
 Local i
 For i = 1 To 8 : SetPin i, dout : Next i
 For i = 11 To 18 : SetPin i, dout : Next i
 matrix_clear()
End Sub
Sub matrix_clear()
 Local i
 For i = 0 To 7 : matrix(i) = 0 : Next i
End Sub
Sub matrix_fill()
 Local i
 For i = 0 To 7 : matrix(i) = &hFF : Next i
End Sub
Function matrix_get(p)
 matrix_get = (matrix(p \ 8) And 2^(p Mod 8)) > 0
End Function
Sub matrix_set(p, x)
 matrix(p \ 8) = matrix(p \ 8) And (&hFF Xor 2^(p Mod 8)) Or x * 2^(p Mod 8)
End Sub
Sub matrix_left()
 Local i
 For i = 0 To 7 : matrix(i) = matrix(i) \ 2 And &hFF : Next i
End Sub
' Pins 1-8 source the columns.
' Pins 11-18 sink the rows.
Sub matrix_draw()
 row = (row + 1) Mod 8
 Port(1, 8, 11, 8) = &hFF00
 Port(1, 8, 11, 8) = matrix(row) Or &hFF00 - 2 ^ (row + 8)
End Sub
Sub load_font()
 Local end, height, i, j, s$, start, x, width
 Open "tt4x6.fnt" For Input As #1
 Input #1, height, width, start, end
 If height <> 6 Then Error
 If width <> 4  Then Error
 If start <> 20 Then Error
 If end <> 126  Then Error
 For i = 0 To (end - start) ' Iterate over glyphs
   For j = 0 To 5 Step 2 ' Iterate over rows, 2 at a time
     x = 0
     Line Input #1, s$
     If Len(s$) <> width Then Error
     If Peek(Var s$, 1) > 32 Then x = x Or &b00000001
     If Peek(Var s$, 2) > 32 Then x = x Or &b00000010
     If Peek(Var s$, 3) > 32 Then x = x Or &b00000100
     If Peek(Var s$, 4) > 32 Then x = x Or &b00001000
     Line Input #1, s$
     If Peek(Var s$, 1) > 32 Then x = x Or &b00010000
     If Peek(Var s$, 2) > 32 Then x = x Or &b00100000
     If Peek(Var s$, 3) > 32 Then x = x Or &b01000000
     If Peek(Var s$, 4) > 32 Then x = x Or &b10000000
     Poke Var font4x6(0), i * 3 + j \ 2, x
   Next j
 Next i
 Close #1
End Sub
Sub scroll_text(s$)
 Local c, ch, i
 cmd = 0
 For i = 1 To Len(s$)
   ch = Peek(Var s$, i)
   For c = 0 To 3
     ' Poor man's proportional spacing.
     If c = 0 And ch = 105 Then c = 1
     If c = 2 And ch = 105 Then c = 3
     If c = 1 And ch = 32  Then c = 4
     blit_font(Peek(Var s$, i), c)
     Pause 150
     matrix_left()
   Next c
   If cmd <> 0 Then i = Len(s$)
 Next i
 For i = 1 To 7 : Pause 100 : matrix_left() : Next i
End Sub
' Copies column 'c' of glyph 'a' to the last column of the matrix.
Sub blit_font(a, c)
 Local x, i, p, s
 p = 7
 s = (a - 20) * 3
 For i = s To s + 2
   x = Peek(Var font4x6(0), i)
   p = p + 8
   matrix_set(p, (x And 2^c) > 0)
   p = p + 8
   matrix_set(p, (x And 2^(c + 4)) > 0)
 Next i
End Sub
     Page 3 of 3
