Local Time 08:57 18 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2: V5.05.06RC19: Scotty more power
     Page 3 of 4
CircuitGizmos
Posted: 09:05pm 15 Nov 2020
thinBasic, RobotBASIC, QB64 all return var as the true/false result of the test. PUREBASIC complains about syntax.
Posted: 09:18pm 15 Nov 2020
  CircuitGizmos said  thinBasic, RobotBASIC, QB64 all return var as the true/false result of the test. PUREBASIC complains about syntax.
In PUREBASIC you need bool()
b=7
c=7
a=Bool(b=c)
Debug a
It forces you to be clear about what yu are doing...
Posted: 09:19pm 15 Nov 2020
FWIW:
DOS MMBasic Ver 5.05.02
Copyright 2011-2019 Geoff Graham
> a=1: b=2: c=a=b: print a,b,c
1       2       0
> b=1: c=a=b: print a,b,c
1       1       1
> a=0: c=a=b: print a,b,c
0       1       0
> a=2: c=a=b: print a,b,c
2       1       0
2       2       1
Edited 2020-11-16 07:24 by lizby
CircuitGizmos
Posted: 10:25pm 15 Nov 2020
b=7
c=7
a=Bool(b=c)
Debug a
Nice! Thank you.
panky
Posted: 11:31pm 15 Nov 2020
From Mr. Scott,
if speed is important Captain, then
c = a = b  is fastest,
c = (a = b) is about 10% slower, and
if/then constructs are slower still!
.... but I do think that the a = b = c construct is not intuitively obvious, particularly to a newcomer to programming languages.
Doug.
Posted: 12:17am 16 Nov 2020
Further FWIW, MM2 MUP V3
> ?mm.ver
5.041
> dim integer a,b,c
1       2       0
1       1       1
0       1       0
0       2       0
And Armmite F4:
ARMmite MMBasic Version 5.05.08
Copyright 2016-2019 Peter Mather
> dim integer a,b,c
1       2       0
1       1       1
0       1       0
0       2       0
2       2       1
I agree that this is not a BASIC construction that I would ever have thought to use, and knowing about it, for the sake of clarity I would not use it. But that's a personal preference.
Edited 2020-11-16 10:19 by lizby
Posted: 05:16pm 16 Nov 2020
V5.05.06RC20 posted
Fixes bug when a program contains duplicate function names - now you will get the error message but the program won't be loaded so the message won't re-occur allowing you to edit the program to fix the bug
Fixed bug in calling string functions with a calculated string. This bug was introduced to try and improve the depth to which recursion could take place before the stack is used up but it was an "optimisation" too far.
Fixed typo in the RGB332 mapping table for blue
Changed MM.INFO(FILESIZE name$) to return -2 when the "name$" refers to a directory. This allows you to distinguish between a missing file and a directory.
Added CAT as a synonym for INC to make use with strings more obvious
e.g. CAT string1$, string2$ 'appends string2$ to string1$
Attempting to use a location in an array in MATH commands and functions that require an array as a parameter will now give an error.
Trying to use the same array for the output of MATH M_MULT or MATH V_MULT as one of the inputs now gives an error
Fixes a bug in the triangle drawing routine when the coordinates are co-linear and not ordered
A FILL of -1 no longer causes the TRIANGLE sub to give an error - code now matches the manual
Major rewrite of graphics primitives for BLIT to give significant performance improvement
Edited 2020-11-17 03:17 by matherp
Posted: 06:50pm 16 Nov 2020
Thanks Peter my tools are working again and my unit-tests passing
The enhancement to MM.INFO(FILESIZE name$) is also appreciated.
twofingers
Posted: 07:24pm 16 Nov 2020
Hi Peter,
thanks for your efforts!
The editor (colour coded syntax) does not recognize INC, CAT or MMDEBUG. Is that intentional?
It seems someone has changed the restrictions on the maximum number of commands (now 132).
Michael
Edited 2020-11-17 06:02 by twofingers
The lone and ...
Posted: 07:53pm 16 Nov 2020
  Quote  The editor does not recognize INC or CAT. Is that intentional?
Forgot to add them - will be in next version
  Quote  It seems someone has changed the restrictions on the maximum number of commands (now 132).
No, just some behind the scenes magic
Posted: 08:18pm 16 Nov 2020
As I understand it, if commands are synonyms of each other e.g. COLOUR and COLOR or INC and CAT they only require one command/token/slot.
Edited 2020-11-17 06:18 by thwill
twofingers
Posted: 08:25pm 16 Nov 2020
  thwill said
  matherp said  As I understand it, if commands are synonyms of each other e.g. COLOUR and COLOR or INC and CAT they only require one command/token/slot.
I doubt it, but peter will explain ... someday.
The lone and ...
Posted: 08:28pm 16 Nov 2020
  twofingers said
  thwill said  As I understand it, if commands are synonyms of each other e.g. COLOUR and COLOR or INC and CAT they only require one command/token/slot.
Suit yourself, it's not magic, plus he kindly told me how it was done in a PM Strictly speaking (again as I understood the explanation) he is pre-processing the source to handle the synonyms when it is loaded into the flash.
Edited 2020-11-17 06:29 by thwill
jirsoft
RC20,
LOCAL STRING dt = MM.INFO$(MODIFIED f)
not work, complaining about string needed (but f is also string, in RC19 works OK)... In command line somehow works
Jiri
Posted: 08:49pm 16 Nov 2020
@matherp
Are these performance improvements achievable for other platforms (MM2, MM+, ARMmite) possible ?
Posted: 09:34pm 16 Nov 2020
  jirsoft said  RC20,
Your problem is caused when you try to get the time of a directory.
It works as expected with files. but now returns a number with directories.
OPTION EXPLICIT
OPTION DEFAULT NONE
print NCdateTime("fm.bas") ' works as expected
print NCdateTime("test") ' test is a directory - gives an error
FUNCTION NCdateTime(f as string) AS STRING
 'prepare date and time of file
 IF dt<>"" THEN dt = MID$(dt, 3, 14)
 NCdateTime = dt
END FUNCTION
Nice program by the way.
Posted: 10:59pm 16 Nov 2020
  Quote  Your problem is caused when you try to get the time of a directory.
It used to return a blank string with directories but actually there is no reason it can't return a valid modified date so I'll make it do this in the next release
jirsoft
Posted: 11:16pm 16 Nov 2020
Thanks Peter,
I already sought for reason, why dirs have no time of change...
Jiri
bar1010
Posted: 04:27am 17 Nov 2020
  Turbo46 said  Please, please, please release it! Plus one.
I'd love to have an up-to-date printed manual.
For info this INC or += suggestion came up for MMBasic before and was rejected. I'm glad it finally made it.
I'd love to know which (if any) of these improvements Peter has made will make it to MMBasic for the Original Maximites and the Micromites.
Thank you Peter and Geoff.
Bill
Please, please, please release it! Plus two.
I also would like to have an up-to-date printed manual.
LeoNicolas
Posted: 05:03am 17 Nov 2020
Bill
Peter still working on the new version, adding new features and fixing bugs.
I like the Linux Mint release process and it can be applied here...
When will it be released? When ready
     Page 3 of 4
