Local Time 09:36 18 Sep 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM2: V5.06.00b1 - Pages and Pages
     Page 3 of 3
Posted: 02:18pm 23 Nov 2020
  Quote  I already used built-in SOR() methods, but something stopped me from use it)
is that because the sort takes into account case? If so it would be easy to add an additional parameter to indicate ignore case
Posted: 02:21pm 23 Nov 2020
Yes please ...
... and a parameter to reverse the sort (descending vs. ascending)
... and a lower bound to start the sort from (default Option Base)
... and a number of elements to sort (default all)
If you'd like to make all my library work obsolete, and all my code faster I'd greatly appreciate it
Cheers,
Edited 2020-11-24 00:22 by thwill
Posted: 02:24pm 23 Nov 2020
Oh, and if you're looking for a use for that shiny new function slot:
' Case-sensitive binary search for a value in a SORTED array.
' @param  a$()    the array.
' @param  s$      the value to search for.
' @param  flags$  "i" to search case-insensitively,
' @param  lb%     the lower bound to search from,
'                 if 0/unset then search from the first element.
' @param  ub%     the upper bound to search from,
'                 if 0/unset then search from the last element.
' @return         the index of the element containing the value,
'                 or -1 if not present.
Function array.bsearch%(a$(), s$, flags$, lb%, ub%)
 Local lb_% = Max(Mm.Info(Option Base), lb%)
 Local ub_% = ub%
 If ub_% = 0 Then ub_% = Bound(a$(), 1)
 Local i%
 If InStr(UCase$(flags$), "I") Then
   Local us$ = UCase$(s$)
   Local ua$
   Do While ub_% >= lb_%
     i% = (lb_% + ub_%) \ 2
     ua$ = UCase$(a$(i%))
     If us$ > ua$ Then
       lb_% = i% + 1
     ElseIf us$ < ua$ Then
       ub_% = i% - 1
     Else
       Exit Do
     EndIf
 Else
     If s$ > a$(i%) Then
       lb_% = i% + 1
     ElseIf s$ < a$(i%) Then
       ub_% = i% - 1
     Else
       Exit Do
     EndIf
 EndIf
 If ub_% >= lb_% Then array.bsearch% = i% Else array.bsearch% = -1
End Function
I've definitely posted too many times today ... no more coffee for this man,
Posted: 02:28pm 23 Nov 2020
  jirsoft said  Another argument is listing DIRs before FILEs or mix it. On MacOS is standard sort it mixed, on Windows DIRs first...
At the command line it is also mixed on Windows (at least on Win 10), it's Explorer that puts directories first, though possibly that is configurable.
jirsoft
Posted: 02:40pm 23 Nov 2020
Yes, I had 2 reasons:
1. case sensitivity
2. half empty static array (but now I got an idea, I could fill it with CHR$(255) before and it will work)
But as Tom writes, SORT(array(), case insesitive, lower limit, upper limit will be just perfect...
Jiri
vegipete
Posted: 07:11pm 23 Nov 2020
  jirsoft said  2. half empty static array (but now I got an idea, I could fill it with CHR$(255) before and it will work)
Great idea!
What is the best method to set an array of strings to a default value, or clear all of the strings to "" (null) ?
     Page 3 of 3
