Local Time 08:06 22 Oct 2026 Privacy Policy
Forum Index : Electronics : Power Jack LF + 3kw Aerostar inverter ??kw @ 48v
     Page 3 of 3
BenandAmber
Posted: 05:05am 27 May 2021
i run one just like noneyabussiness in my bus
i have ran it for a year or two
there is a rental where i keep my bus and when power is out old renters would plug into bus also
it has been flawless runs very cool
i have never seen fans kick on but surly they did at least once
biggest load i have ran on it was a 6hp air compressor a small window ac and a few power tools for a few hours
i have a few of them the ones i have are good
all my egs002 control have been modified the way poida taught me
he may chime in some time
i have also been testing and running a genetry solar inverter at my home for some time
it is a amazing machine you can hook two together in a few diff ways really cool stuff
no extra stuff to buy you can set them up right out of the box that any way you would like
you can control it from your phone from any where
i used the built in display to down load the update  just a few clicks and i had a cooler screen layout and a built in oscilloscope free!!
it has taps inside for 12 24 36 48 volts so every inverter can do all four voltages
you can set anything to the way you like it i mean everything!!!!
i could go on forever about what it can do
you can order it at there web site
if not now soon it will be available as a pj upgrade
you will be able to buy just the wifi board "screen"
control board "8amp mos drivers" as the pj upgrade kit
this made it alot harder on him the designer programer "sid"
he is on here and is like minded i am pretty sure everything people like you guys on here said they wanted it can do
maybe even load share with a genny?
of course it is a business also so it has to follow some rules like a warranty seal on it
tust me they did not want that seal but china can get by with online sells a usa company can not
they are still trying or already have ul certification
for NOW i think the ben and amber mos boards kintfild made me will work on the gs
the little mos boards have had tons and tons of testing they are awesome thanks kint!!!!
i dont no if they are being sold separately yet if not it will be sold as pj upgrade kit soon
to have a very good price versus value the GS uses pwm high speed fans with a all new never done before tranny design
it dont break warpspeeds 4 amp per 1mm sq rule for the rated 6k it will do 8k
got to love the one and only worpspeed he has influenced the hole world and yet so kind and humble
many other greats on here also!
remember if they take the time to comment its worth going over many times
it may save you a blow up or at lest many hard ships
some "alot"of these guys get paid lots of money for what they are giving on here freely!!!!
some of the greatest in the world are on this site including the desinger of genetry solar inverter
most likely you already use electronics some of them had there hand in on
there are legends on here and also new up coming prodigies that will be legends
they are not going to beg you to listen or repeat them selfs over and over
i tell you this from LOTS of over eager under qualified and under estimating experience
your not going to make it unless you slow down and value every word written to you by these greats
even if one of your responses are not quite a great lots of good people on here that has been in your shoes
some can read your mind and come though for you with god like perfect timing
i hope you get a inverter going it is lots of fun and very satisfying to be able to fix your own things
i was successful only because of these guys your reading over quickly and several others who havent gave you the best advice in the world yet
have a blessed day
Edited 2021-05-27 15:11 by BenandAmber
     Page 3 of 3
